[技术讨论] 初次使用HC32F460,问问内部HRC时钟使用问题
3494|5
 楼主| yxl12345678 发表于 2021-6-6 19:44 | 显示全部楼层 |阅读模式
使用外部晶振例子太多了。如果使用内部HRC作为PLL的输入时钟源,然后倍频分频的配置如下,看看还有什么需要纠正地方吗?
 楼主| yxl12345678 发表于 2021-6-6 19:45 | 显示全部楼层
/** \file system_hc32f46x.c
** A detailed description is available at
** @link Hc32f46xSystemGroup Hc32f46xSystem description @endlink
**   - 2018-10-15  1.0  Zhangxl First version
* Include files
#include "hc32_common.h"
#include "hc32_ddl.h"
** \addtogroup Hc32f46xSystemGroup
* Global pre-processor symbols/macros ('define')
** System Clock Frequency (Core Clock) Variable according CMSIS
uint32_t HRC_VALUE = HRC_16MHz_VALUE;
//uint32_t SystemCoreClock = MRC_VALUE;
uint32_t SystemCoreClock = HRC_16MHz_VALUE;
** \brief  Setup the microcontroller system. Initialize the System and update
** the SystemCoreClock variable.
** \param  None
** \return None
void SystemInit(void)
#if (__FPU_PRESENT == 1) && (__FPU_USED == 1)
    SCB->CPACR |= ((3UL << 20) | (3UL << 22)); /* set CP10 and CP11 Full Access */
#endif
    stc_clk_mpll_cfg_t   stcMpllCfg;
    en_clk_sys_source_t  enSysClkSrc;
    stc_clk_sysclk_cfg_t stcSysClkCfg;
    MEM_ZERO_STRUCT(enSysClkSrc);//清零初始化
    MEM_ZERO_STRUCT(stcSysClkCfg);//清零初始化
    MEM_ZERO_STRUCT(stcMpllCfg);//清零初始化
    ///设置总线时钟 Set bus clk div
    stcSysClkCfg.enHclkDiv  = ClkSysclkDiv1;
    stcSysClkCfg.enExclkDiv = ClkSysclkDiv2;
    stcSysClkCfg.enPclk0Div = ClkSysclkDiv1;
    stcSysClkCfg.enPclk1Div = ClkSysclkDiv2;
    stcSysClkCfg.enPclk2Div = ClkSysclkDiv4;
    stcSysClkCfg.enPclk3Div = ClkSysclkDiv4;
    stcSysClkCfg.enPclk4Div = ClkSysclkDiv2;
    CLK_SysClkConfig(&stcSysClkCfg);
    ///切换系统时钟源送入到MPLL  Switch system clock source to MPLL.
    CLK_HrcCmd(Enable);//使能HRC振荡器
    //CLK_MrcCmd(Enable);//使能MRC振荡器
    while(Set != CLK_GetFlagStatus(ClkFlagHRCRdy)) //等待HRC定
    stcMpllCfg.pllmDiv = 2u; // 输入分频
    stcMpllCfg.plln    = 24u;   // 锁相倍频
    stcMpllCfg.PllpDiv = 4u; // 输出分频P
    stcMpllCfg.PllqDiv = 4u; // 输出分频Q
    stcMpllCfg.PllrDiv = 4u; // 输出分频R
    CLK_SetPllSource(ClkPllSrcHRC);//选择HRC为PLL时钟源
    CLK_MpllConfig(&stcMpllCfg);//配置MPLL
    /* flash read wait cycle setting */
    EFM_Unlock();
    EFM_SetLatency(EFM_LATENCY_4);
    EFM_Lock();
    CLK_MpllCmd(Enable);//使能MPLL
    while(Set != CLK_GetFlagStatus(ClkFlagMPLLRdy)) //等待PLL稳定
    /* Switch system clock source to MPLL. */
    CLK_SetSysClkSource(CLKSysSrcMPLL);
   //CLK_SetSysClkSource(ClkSysSrcMRC);
     //CLK_SetSysClkSource(ClkSysSrcHRC);
    SystemCoreClockUpdate();
void SystemCoreClockUpdate(void)  // Update SystemCoreClock variable
    uint8_t tmp = 0u;
    uint32_t plln = 19u, pllp = 1u, pllm = 0u, pllsource = 0u;
    /* Select proper HRC_VALUE according to ICG1.HRCFREQSEL bit */
    /* ICG1.HRCFREQSEL = '0' represent HRC_VALUE = 20000000UL   */
    /* ICG1.HRCFREQSEL = '1' represent HRC_VALUE = 16000000UL   */
    if (1UL == (HRC_FREQ_MON() & 1UL))
    else
        HRC_VALUE = HRC_20MHz_VALUE;
    tmp = M4_SYSREG->CMU_CKSWR_f.CKSW;
    switch (tmp)
        case 0x00:  /* use internal high speed RC */
            SystemCoreClock = HRC_VALUE;
            break;
        case 0x01:  /* use internal middle speed RC */
            break;
        case 0x02:  /* use internal low speed RC */
            SystemCoreClock = LRC_VALUE;
            break;
        case 0x03:  /* use external high speed OSC */
            SystemCoreClock = XTAL_VALUE;
            break;
        case 0x04:  /* use external low speed OSC */
            SystemCoreClock = XTAL32_VALUE;
            break;
        case 0x05:  /* use MPLL */
            /* PLLCLK = ((pllsrc / pllm) * plln) / pllp */
            pllsource = M4_SYSREG->CMU_PLLCFGR_f.PLLSRC;
            plln = M4_SYSREG->CMU_PLLCFGR_f.MPLLN;
            pllp = M4_SYSREG->CMU_PLLCFGR_f.MPLLP;
            pllm = M4_SYSREG->CMU_PLLCFGR_f.MPLLM;
            /* use exteranl high speed OSC as PLL source */
            if (0ul == pllsource)
               SystemCoreClock = (XTAL_VALUE) / (pllm + 1ul) * (plln + 1ul) / (pllp + 1ul);
            /* use interanl high RC as PLL source */
            else if (1ul == pllsource)
                SystemCoreClock = (HRC_VALUE) / (pllm + 1ul) * (plln + 1ul) / (pllp + 1ul);
            else
                /* Reserved */
            break;
//@} // UsartGroup
* EOF (not truncated)
 楼主| yxl12345678 发表于 2021-6-6 19:49 | 显示全部楼层
可能我是哪里没有配置对,使用串口通信的时候,有点问题,收发不是很正常。
 楼主| yxl12345678 发表于 2021-6-6 19:55 | 显示全部楼层
以下是和串口相关的,使用了串口超时中断接收数据帧。这个应该没有问题的。
  ////////////////外设时钟设置//////////////////////////
   /// Enable peripheral clock
   PWC_Fcg1PeriphClockCmd(PWC_FCG1_PERIPH_USART1, Enable);
   PWC_Fcg1PeriphClockCmd(PWC_FCG1_PERIPH_USART2, Enable);
   PWC_Fcg1PeriphClockCmd(PWC_FCG1_PERIPH_USART3, Enable);
       /* Timer0 peripheral enable */
    PWC_Fcg2PeriphClockCmd(PWC_FCG2_PERIPH_TIM01, Enable);
    PWC_Fcg2PeriphClockCmd(PWC_FCG2_PERIPH_TIM02, Enable);
void TimeInit(void)  //定时器初始化
    stc_clk_freq_t stcClkTmp;
    stc_tim0_base_init_t stcTimerCfg;
    stc_tim0_trigger_init_t StcTimer0TrigInit;
    MEM_ZERO_STRUCT(stcClkTmp);
    MEM_ZERO_STRUCT(stcTimerCfg);
    MEM_ZERO_STRUCT(StcTimer0TrigInit);
    /* Clear CNTAR register for channel A */
    TIMER0_WriteCntReg(M4_TMR01, Tim0_ChannelA, 0u);
    TIMER0_WriteCntReg(M4_TMR01, Tim0_ChannelB, 0u);
    TIMER0_WriteCntReg(M4_TMR02, Tim0_ChannelA, 0u);
    /* Config register for channel A */
    stcTimerCfg.Tim0_CounterMode = Tim0_Async;
    stcTimerCfg.Tim0_AsyncClockSource = Tim0_LRC;
    stcTimerCfg.Tim0_ClockDivision = Tim0_ClkDiv8;
    stcTimerCfg.Tim0_CmpValue = 800u;
    TIMER0_BaseInit(M4_TMR01, Tim0_ChannelA, &stcTimerCfg);
    TIMER0_BaseInit(M4_TMR01, Tim0_ChannelB, &stcTimerCfg);
    TIMER0_BaseInit(M4_TMR02, Tim0_ChannelA, &stcTimerCfg);
    /* Clear compare flag */
    TIMER0_ClearFlag(M4_TMR01, Tim0_ChannelA);
    TIMER0_ClearFlag(M4_TMR01, Tim0_ChannelB);
    TIMER0_ClearFlag(M4_TMR02, Tim0_ChannelA);
    /* Config timer0 hardware trigger */
    StcTimer0TrigInit.Tim0_InTrigEnable = false;
    StcTimer0TrigInit.Tim0_InTrigClear = true;
    StcTimer0TrigInit.Tim0_InTrigStart = true;
    StcTimer0TrigInit.Tim0_InTrigStop = false;
    TIMER0_HardTriggerInit(M4_TMR01, Tim0_ChannelA, &StcTimer0TrigInit);
    TIMER0_HardTriggerInit(M4_TMR01, Tim0_ChannelB, &StcTimer0TrigInit);
    TIMER0_HardTriggerInit(M4_TMR02, Tim0_ChannelA, &StcTimer0TrigInit);
* 函 数 名: UART_Init
* 函数功能: 串口初始化
* 输    入: 无
* 输    出: 无
void UART_Init(void)
   //USART_DeInit(M4_USART1);
   //USART_DeInit(M4_USART2);
   // USART_DeInit(M4_USART3);
    en_result_t enRet = Ok;
    stc_irq_regi_conf_t stcIrqRegiCfg;
    const stc_usart_uart_init_t stcInitCfg = {
        UsartIntClkCkNoOutput,
        UsartClkDiv_1,
        UsartDataBits8,
        UsartDataLsbFirst,
        UsartOneStopBit,
        UsartParityNone,
        UsartSamleBit8,
        UsartStartBitFallEdge,
        UsartRtsEnable,
    const stc_usart_uart_init_t stcInitCfg1 = {
        UsartClkDiv_1,
        UsartDataBits9,
        UsartDataLsbFirst,
        UsartOneStopBit,
        UsartParityEven,
        UsartSamleBit8,
        UsartRtsEnable,
    /////////配置串口参数/////////////////////////
     enRet = USART_UART_Init(M4_USART1, &stcInitCfg1);
    if (enRet != Ok)
        while (1)
    enRet = USART_UART_Init(M4_USART2, &stcInitCfg1);
    if (enRet != Ok)
        while (1)
   enRet = USART_UART_Init(M4_USART3, &stcInitCfg);
    if (enRet != Ok)
        while (1)
    ///////////配置波特率///////////////////
    enRet = USART_SetBaudrate(M4_USART3, 9600u);
    if (enRet != Ok)
        while (1)
    enRet = USART_SetBaudrate(M4_USART1, 9600u);
    if (enRet != Ok)
        while (1)
    enRet = USART_SetBaudrate(M4_USART2, 9600u);
    if (enRet != Ok)
        while (1)
        ///Set USART RX IRQ
    stcIrqRegiCfg.enIRQn = Int000_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart1RxIrqCallback;
    stcIrqRegiCfg.enIntSrc = INT_USART1_RI;
    enIrqRegistration(&stcIrqRegiCfg);
    NVIC_SetPriority(stcIrqRegiCfg.enIRQn, DDL_IRQ_PRIORITY_DEFAULT);
    NVIC_ClearPendingIRQ(stcIrqRegiCfg.enIRQn);
    NVIC_EnableIRQ(stcIrqRegiCfg.enIRQn);
    // Set USART RX error IRQ
    stcIrqRegiCfg.enIRQn = Int001_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart1ErrIrqCallback;
        ///Set USART RX IRQ
    stcIrqRegiCfg.enIRQn = Int002_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart2RxIrqCallback;
    stcIrqRegiCfg.enIntSrc = INT_USART2_RI;
    stcIrqRegiCfg.enIRQn = Int003_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart2ErrIrqCallback;
    ///Set USART RX IRQ
    stcIrqRegiCfg.enIRQn = Int004_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart3RxIrqCallback;
    stcIrqRegiCfg.enIntSrc = INT_USART3_RI;
    stcIrqRegiCfg.enIRQn = Int005_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart3ErrIrqCallback;
    ///Set USART1 RX timeout error IRQ
    stcIrqRegiCfg.enIRQn = Int006_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart1TimeoutIrqCallback;
    stcIrqRegiCfg.enIntSrc = INT_USART1_RTO;
    /// Set USART1 RX timeout error IRQ
    stcIrqRegiCfg.enIRQn = Int007_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart2TimeoutIrqCallback;
    stcIrqRegiCfg.enIntSrc = INT_USART2_RTO;
    stcIrqRegiCfg.enIRQn = Int008_IRQn;
    stcIrqRegiCfg.pfnCallback = &Usart3TimeoutIrqCallback;
    stcIrqRegiCfg.enIntSrc = INT_USART3_RTO;
    ///Enable RX && TX function
    USART_FuncCmd(M4_USART1, UsartRx, Enable);
    USART_FuncCmd(M4_USART1, UsartTx, Enable);
    USART_FuncCmd(M4_USART2, UsartRx, Enable);
    USART_FuncCmd(M4_USART2, UsartTx, Enable);
    USART_FuncCmd(M4_USART3, UsartRx, Enable);
    USART_FuncCmd(M4_USART3, UsartTx, Enable);
    //Enable RX && RX interupt function*/
    USART_FuncCmd(M4_USART1, UsartRxInt, Enable);
    USART_FuncCmd(M4_USART2, UsartRxInt, Enable);
    USART_FuncCmd(M4_USART3, UsartRxInt, Enable);
    USART_FuncCmd(M4_USART1, UsartTimeOut, Enable);
    USART_FuncCmd(M4_USART1, UsartTimeOutInt, Enable);
    USART_FuncCmd(M4_USART2, UsartTimeOut, Enable);
    USART_FuncCmd(M4_USART2, UsartTimeOutInt, Enable);
    USART_FuncCmd(M4_USART3, UsartTimeOut, Enable);
    USART_FuncCmd(M4_USART3, UsartTimeOutInt, Enable);
///////////////////////////接收中断//////////////////////////////////////
void Usart1RxIrqCallback(void)
  m_u16RxData=USART_RecData(M4_USART1);
  USART_FuncCmd(M4_USART1, UsartTxAndTxEmptyInt, Enable);
void Usart2RxIrqCallback(void)
void Usart3RxIrqCallback(void)
////////////////////////////接收超时中断/////////////////////////////////////
void Usart1TimeoutIrqCallback(void)
   TIMER0_Cmd(M4_TMR01, Tim0_ChannelA,Disable);
   USART_ClearStatus(M4_USART1, UsartRxTimeOut);
void Usart2TimeoutIrqCallback(void)
   TIMER0_Cmd(M4_TMR01, Tim0_ChannelB,Disable);
   USART_ClearStatus(M4_USART2, UsartRxTimeOut);
void Usart3TimeoutIrqCallback(void)
   cmcc=1;
   TIMER0_Cmd(M4_TMR02, Tim0_ChannelA,Disable);
   USART_ClearStatus(M4_USART3, UsartRxTimeOut);
////////////////////错误中断////////////////////////////////
void Usart1ErrIrqCallback(void)
  if (Set == USART_GetStatus(M4_USART1, UsartFrameErr))
      USART_ClearStatus(M4_USART1, UsartFrameErr);
  else
  if (Set == USART_GetStatus(M4_USART1, UsartParityErr))
      USART_ClearStatus(M4_USART1, UsartParityErr);
  else
  if (Set == USART_GetStatus(M4_USART1, UsartOverrunErr))
      USART_ClearStatus(M4_USART1, UsartOverrunErr);
  else
void Usart2ErrIrqCallback(void)
  if (Set == USART_GetStatus(M4_USART2, UsartFrameErr))
      USART_ClearStatus(M4_USART2, UsartFrameErr);
  else
  if (Set == USART_GetStatus(M4_USART2, UsartParityErr))
      USART_ClearStatus(M4_USART2, UsartParityErr);
  else
  if (Set == USART_GetStatus(M4_USART2, UsartOverrunErr))
      USART_ClearStatus(M4_USART2, UsartOverrunErr);
  else
void Usart3ErrIrqCallback(void)
  if (Set == USART_GetStatus(M4_USART3, UsartFrameErr))
      USART_ClearStatus(M4_USART3, UsartFrameErr);
  else
  if (Set == USART_GetStatus(M4_USART3, UsartParityErr))
      USART_ClearStatus(M4_USART3, UsartParityErr);
  else
  if (Set == USART_GetStatus(M4_USART3, UsartOverrunErr))
      USART_ClearStatus(M4_USART3, UsartOverrunErr);
  else
 楼主| yxl12345678 发表于 2021-6-6 19:56 | 显示全部楼层
一不小心发错版面了。
Luckk0517 发表于 2024-4-16 10:50 | 显示全部楼层
博主请问你解决问题了吗?
