-   .syntax unified
-   .cpu cortex-m4
-   .fpu softvfp
-   .thumb
- .global  g_pfnVectors
- .global  Default_Handler
- /* start address for the initialization values of the .data section.
- defined in linker script */
- .word  _sidata
- /* start address for the .data section. defined in linker script */
- .word  _sdata
- /* end address for the .data section. defined in linker script */
- .word  _edata
- /* start address for the .bss section. defined in linker script */
- .word  _sbss
- /* end address for the .bss section. defined in linker script */
- .word  _ebss
- /* stack used for SystemInit_ExtMemCtl; always internal RAM used */
-  * [url=home.php?mod=space&uid=247401]@brief[/url]  This is the code that gets called when the processor first
-  *          starts execution following a reset event. Only the absolutely
-  *          necessary set is performed, after which the application
-  *          supplied main() routine is called.
-  * @param  None
-  * @retval : None
-     .section  .text.Reset_Handler
-   .weak  Reset_Handler
-   .type  Reset_Handler, %function
- Reset_Handler:
-   ldr   sp, =_estack     /* set stack pointer */
- /* Copy the data segment initializers from flash to SRAM */
-   movs  r1, #0
-   b  LoopCopyDataInit
- CopyDataInit:
-   ldr  r3, =_sidata
-   ldr  r3, [r3, r1]
-   str  r3, [r0, r1]
-   adds  r1, r1, #4
- LoopCopyDataInit:
-   ldr  r0, =_sdata
-   ldr  r3, =_edata
-   adds  r2, r0, r1
-   cmp  r2, r3
-   bcc  CopyDataInit
-   ldr  r2, =_sbss
-   b  LoopFillZerobss
- /* Zero fill the bss segment. */
- FillZerobss:
-   movs  r3, #0
-   str  r3, [r2], #4
- LoopFillZerobss:
-   ldr  r3, = _ebss
-   cmp  r2, r3
-   bcc  FillZerobss
- /* Call the clock system intitialization function.*/
-   bl  SystemInit
- /* Call static constructors */
- /*     bl __libc_init_array */
- /* Call the application's entry point.*/
-   bl  entry
-   bx  lr
- .size  Reset_Handler, .-Reset_Handler
-  * @brief  This is the code that gets called when the processor receives an
-  *         unexpected interrupt.  This simply enters an infinite loop, preserving
-  *         the system state for examination by a debugger.
-  * @param  None
-  * @retval None
-     .section  .text.Default_Handler,"ax",%progbits
- Default_Handler:
- Infinite_Loop:
-   b  Infinite_Loop
-   .size  Default_Handler, .-Default_Handler
- * The minimal vector table for a Cortex M3. Note that the proper constructs
- * must be placed on this to ensure that it ends up at physical address
- * 0x0000.0000.
-    .section  .isr_vector,"a",%progbits
-   .type  g_pfnVectors, %object
-   .size  g_pfnVectors, .-g_pfnVectors
- g_pfnVectors:
-   .word  _estack
-   .word  Reset_Handler
-   .word  NMI_Handler
-   .word  HardFault_Handler
-   .word  MemManage_Handler
-   .word  BusFault_Handler
-   .word  UsageFault_Handler
-   .word  0
-   .word  0
-   .word  0
-   .word  0
-   .word  SVC_Handler
-   .word  DebugMon_Handler
-   .word  0
-   .word  PendSV_Handler
-   .word  SysTick_Handler
-   /* External Interrupts */
-   .word     WWDG_IRQHandler                   /* Window WatchDog              */
-   .word     PVD_IRQHandler                    /* PVD through EXTI Line detection */
-   .word     TAMP_STAMP_IRQHandler             /* Tamper and TimeStamps through the EXTI line */
-   .word     RTC_WKUP_IRQHandler               /* RTC Wakeup through the EXTI line */
-   .word     FLASH_IRQHandler                  /* FLASH                        */
-   .word     RCC_IRQHandler                    /* RCC                          */
-   .word     EXTI0_IRQHandler                  /* EXTI Line0                   */
-   .word     EXTI1_IRQHandler                  /* EXTI Line1                   */
-   .word     EXTI2_IRQHandler                  /* EXTI Line2                   */
-   .word     EXTI3_IRQHandler                  /* EXTI Line3                   */
-   .word     EXTI4_IRQHandler                  /* EXTI Line4                   */
-   .word     DMA1_Stream0_IRQHandler           /* DMA1 Stream 0                */
-   .word     DMA1_Stream1_IRQHandler           /* DMA1 Stream 1                */
-   .word     DMA1_Stream2_IRQHandler           /* DMA1 Stream 2                */
-   .word     DMA1_Stream3_IRQHandler           /* DMA1 Stream 3                */
-   .word     DMA1_Stream4_IRQHandler           /* DMA1 Stream 4                */
-   .word     DMA1_Stream5_IRQHandler           /* DMA1 Stream 5                */
-   .word     DMA1_Stream6_IRQHandler           /* DMA1 Stream 6                */
-   .word     ADC_IRQHandler                    /* ADC1, ADC2 and ADC3s         */
-   .word     CAN1_TX_IRQHandler                /* CAN1 TX                      */
-   .word     CAN1_RX0_IRQHandler               /* CAN1 RX0                     */
-   .word     CAN1_RX1_IRQHandler               /* CAN1 RX1                     */
-   .word     CAN1_SCE_IRQHandler               /* CAN1 SCE                     */
-   .word     EXTI9_5_IRQHandler                /* External Line[9:5]s          */
-   .word     TIM1_BRK_TIM9_IRQHandler          /* TIM1 Break and TIM9          */
-   .word     TIM1_UP_TIM10_IRQHandler          /* TIM1 Update and TIM10        */
-   .word     TIM1_TRG_COM_TIM11_IRQHandler     /* TIM1 Trigger and Commutation and TIM11 */
-   .word     TIM1_CC_IRQHandler                /* TIM1 Capture Compare         */
-   .word     TIM2_IRQHandler                   /* TIM2                         */
-   .word     TIM3_IRQHandler                   /* TIM3                         */
-   .word     TIM4_IRQHandler                   /* TIM4                         */
-   .word     I2C1_EV_IRQHandler                /* I2C1 Event                   */
-   .word     I2C1_ER_IRQHandler                /* I2C1 Error                   */
-   .word     I2C2_EV_IRQHandler                /* I2C2 Event                   */
-   .word     I2C2_ER_IRQHandler                /* I2C2 Error                   */
-   .word     SPI1_IRQHandler                   /* SPI1                         */
-   .word     SPI2_IRQHandler                   /* SPI2                         */
-   .word     USART1_IRQHandler                 /* USART1                       */
-   .word     USART2_IRQHandler                 /* USART2                       */
-   .word     USART3_IRQHandler                 /* USART3                       */
-   .word     EXTI15_10_IRQHandler              /* External Line[15:10]s        */
-   .word     RTC_Alarm_IRQHandler              /* RTC Alarm (A and B) through EXTI Line */
-   .word     OTG_FS_WKUP_IRQHandler            /* USB OTG FS Wakeup through EXTI line */
-   .word     TIM8_BRK_TIM12_IRQHandler         /* TIM8 Break and TIM12         */
-   .word     TIM8_UP_TIM13_IRQHandler          /* TIM8 Update and TIM13        */
-   .word     TIM8_TRG_COM_TIM14_IRQHandler     /* TIM8 Trigger and Commutation and TIM14 */
-   .word     TIM8_CC_IRQHandler                /* TIM8 Capture Compare         */
-   .word     DMA1_Stream7_IRQHandler           /* DMA1 Stream7                 */
-   .word     FSMC_IRQHandler                   /* FSMC                         */
-   .word     SDIO_IRQHandler                   /* SDIO                         */
-   .word     TIM5_IRQHandler                   /* TIM5                         */
-   .word     SPI3_IRQHandler                   /* SPI3                         */
-   .word     UART4_IRQHandler                  /* UART4                        */
-   .word     UART5_IRQHandler                  /* UART5                        */
-   .word     TIM6_DAC_IRQHandler               /* TIM6 and DAC1&2 underrun errors */
-   .word     TIM7_IRQHandler                   /* TIM7                         */
-   .word     DMA2_Stream0_IRQHandler           /* DMA2 Stream 0                */
-   .word     DMA2_Stream1_IRQHandler           /* DMA2 Stream 1                */
-   .word     DMA2_Stream2_IRQHandler           /* DMA2 Stream 2                */
-   .word     DMA2_Stream3_IRQHandler           /* DMA2 Stream 3                */
-   .word     DMA2_Stream4_IRQHandler           /* DMA2 Stream 4                */
-   .word     ETH_IRQHandler                    /* Ethernet                     */
-   .word     ETH_WKUP_IRQHandler               /* Ethernet Wakeup through EXTI line */
-   .word     CAN2_TX_IRQHandler                /* CAN2 TX                      */
-   .word     CAN2_RX0_IRQHandler               /* CAN2 RX0                     */
-   .word     CAN2_RX1_IRQHandler               /* CAN2 RX1                     */
-   .word     CAN2_SCE_IRQHandler               /* CAN2 SCE                     */
-   .word     OTG_FS_IRQHandler                 /* USB OTG FS                   */
-   .word     DMA2_Stream5_IRQHandler           /* DMA2 Stream 5                */
-   .word     DMA2_Stream6_IRQHandler           /* DMA2 Stream 6                */
-   .word     DMA2_Stream7_IRQHandler           /* DMA2 Stream 7                */
-   .word     USART6_IRQHandler                 /* USART6                       */
-   .word     I2C3_EV_IRQHandler                /* I2C3 event                   */
-   .word     I2C3_ER_IRQHandler                /* I2C3 error                   */
-   .word     OTG_HS_EP1_OUT_IRQHandler         /* USB OTG HS End Point 1 Out   */
-   .word     OTG_HS_EP1_IN_IRQHandler          /* USB OTG HS End Point 1 In    */
-   .word     OTG_HS_WKUP_IRQHandler            /* USB OTG HS Wakeup through EXTI */
-   .word     OTG_HS_IRQHandler                 /* USB OTG HS                   */
-   .word     DCMI_IRQHandler                   /* DCMI                         */
-   .word     0                                 /* CRYP crypto                  */
-   .word     HASH_RNG_IRQHandler               /* Hash and Rng                 */
-   .word     FPU_IRQHandler                    /* FPU                          */
- * Provide weak aliases for each Exception handler to the Default_Handler.
- * As they are weak aliases, any function with the same name will override
- * this definition.
-    .weak      NMI_Handler
-    .thumb_set NMI_Handler,Default_Handler
-    .weak      HardFault_Handler
-    .thumb_set HardFault_Handler,Default_Handler
-    .weak      MemManage_Handler
-    .thumb_set MemManage_Handler,Default_Handler
-    .weak      BusFault_Handler
-    .thumb_set BusFault_Handler,Default_Handler
-    .weak      UsageFault_Handler
-    .thumb_set UsageFault_Handler,Default_Handler
-    .weak      SVC_Handler
-    .thumb_set SVC_Handler,Default_Handler
-    .weak      DebugMon_Handler
-    .thumb_set DebugMon_Handler,Default_Handler
-    .weak      PendSV_Handler
-    .thumb_set PendSV_Handler,Default_Handler
-    .weak      SysTick_Handler
-    .thumb_set SysTick_Handler,Default_Handler
-    .weak      WWDG_IRQHandler
-    .thumb_set WWDG_IRQHandler,Default_Handler
-    .weak      PVD_IRQHandler
-    .thumb_set PVD_IRQHandler,Default_Handler
-    .weak      TAMP_STAMP_IRQHandler
-    .thumb_set TAMP_STAMP_IRQHandler,Default_Handler
-    .weak      RTC_WKUP_IRQHandler
-    .thumb_set RTC_WKUP_IRQHandler,Default_Handler
-    .weak      FLASH_IRQHandler
-    .thumb_set FLASH_IRQHandler,Default_Handler
-    .weak      RCC_IRQHandler
-    .thumb_set RCC_IRQHandler,Default_Handler
-    .weak      EXTI0_IRQHandler
-    .thumb_set EXTI0_IRQHandler,Default_Handler
-    .weak      EXTI1_IRQHandler
-    .thumb_set EXTI1_IRQHandler,Default_Handler
-    .weak      EXTI2_IRQHandler
-    .thumb_set EXTI2_IRQHandler,Default_Handler
-    .weak      EXTI3_IRQHandler
-    .thumb_set EXTI3_IRQHandler,Default_Handler
-    .weak      EXTI4_IRQHandler
-    .thumb_set EXTI4_IRQHandler,Default_Handler
-    .weak      DMA1_Stream0_IRQHandler
-    .thumb_set DMA1_Stream0_IRQHandler,Default_Handler
-    .weak      DMA1_Stream1_IRQHandler
-    .thumb_set DMA1_Stream1_IRQHandler,Default_Handler
-    .weak      DMA1_Stream2_IRQHandler
-    .thumb_set DMA1_Stream2_IRQHandler,Default_Handler
-    .weak      DMA1_Stream3_IRQHandler
-    .thumb_set DMA1_Stream3_IRQHandler,Default_Handler
-    .weak      DMA1_Stream4_IRQHandler
-    .thumb_set DMA1_Stream4_IRQHandler,Default_Handler
-    .weak      DMA1_Stream5_IRQHandler
-    .thumb_set DMA1_Stream5_IRQHandler,Default_Handler
-    .weak      DMA1_Stream6_IRQHandler
-    .thumb_set DMA1_Stream6_IRQHandler,Default_Handler
-    .weak      ADC_IRQHandler
-    .thumb_set ADC_IRQHandler,Default_Handler
-    .weak      CAN1_TX_IRQHandler
-    .thumb_set CAN1_TX_IRQHandler,Default_Handler
-    .weak      CAN1_RX0_IRQHandler
-    .thumb_set CAN1_RX0_IRQHandler,Default_Handler
-    .weak      CAN1_RX1_IRQHandler
-    .thumb_set CAN1_RX1_IRQHandler,Default_Handler
-    .weak      CAN1_SCE_IRQHandler
-    .thumb_set CAN1_SCE_IRQHandler,Default_Handler
-    .weak      EXTI9_5_IRQHandler
-    .thumb_set EXTI9_5_IRQHandler,Default_Handler
-    .weak      TIM1_BRK_TIM9_IRQHandler
-    .thumb_set TIM1_BRK_TIM9_IRQHandler,Default_Handler
-    .weak      TIM1_UP_TIM10_IRQHandler
-    .thumb_set TIM1_UP_TIM10_IRQHandler,Default_Handler
-    .weak      TIM1_TRG_COM_TIM11_IRQHandler
-    .thumb_set TIM1_TRG_COM_TIM11_IRQHandler,Default_Handler
-    .weak      TIM1_CC_IRQHandler
-    .thumb_set TIM1_CC_IRQHandler,Default_Handler
-    .weak      TIM2_IRQHandler
-    .thumb_set TIM2_IRQHandler,Default_Handler
-    .weak      TIM3_IRQHandler
-    .thumb_set TIM3_IRQHandler,Default_Handler
-    .weak      TIM4_IRQHandler
-    .thumb_set TIM4_IRQHandler,Default_Handler
-    .weak      I2C1_EV_IRQHandler
-    .thumb_set I2C1_EV_IRQHandler,Default_Handler
-    .weak      I2C1_ER_IRQHandler
-    .thumb_set I2C1_ER_IRQHandler,Default_Handler
-    .weak      I2C2_EV_IRQHandler
-    .thumb_set I2C2_EV_IRQHandler,Default_Handler
-    .weak      I2C2_ER_IRQHandler
-    .thumb_set I2C2_ER_IRQHandler,Default_Handler
-    .weak      SPI1_IRQHandler
-    .thumb_set SPI1_IRQHandler,Default_Handler
-    .weak      SPI2_IRQHandler
-    .thumb_set SPI2_IRQHandler,Default_Handler
-    .weak      USART1_IRQHandler
-    .thumb_set USART1_IRQHandler,Default_Handler
-    .weak      USART2_IRQHandler
-    .thumb_set USART2_IRQHandler,Default_Handler
-    .weak      USART3_IRQHandler
-    .thumb_set USART3_IRQHandler,Default_Handler
-    .weak      EXTI15_10_IRQHandler
-    .thumb_set EXTI15_10_IRQHandler,Default_Handler
-    .weak      RTC_Alarm_IRQHandler
-    .thumb_set RTC_Alarm_IRQHandler,Default_Handler
-    .weak      OTG_FS_WKUP_IRQHandler
-    .thumb_set OTG_FS_WKUP_IRQHandler,Default_Handler
-    .weak      TIM8_BRK_TIM12_IRQHandler
-    .thumb_set TIM8_BRK_TIM12_IRQHandler,Default_Handler
-    .weak      TIM8_UP_TIM13_IRQHandler
-    .thumb_set TIM8_UP_TIM13_IRQHandler,Default_Handler
-    .weak      TIM8_TRG_COM_TIM14_IRQHandler
-    .thumb_set TIM8_TRG_COM_TIM14_IRQHandler,Default_Handler
-    .weak      TIM8_CC_IRQHandler
-    .thumb_set TIM8_CC_IRQHandler,Default_Handler
-    .weak      DMA1_Stream7_IRQHandler
-    .thumb_set DMA1_Stream7_IRQHandler,Default_Handler
-    .weak      FSMC_IRQHandler
-    .thumb_set FSMC_IRQHandler,Default_Handler
-    .weak      SDIO_IRQHandler
-    .thumb_set SDIO_IRQHandler,Default_Handler
-    .weak      TIM5_IRQHandler
-    .thumb_set TIM5_IRQHandler,Default_Handler
-    .weak      SPI3_IRQHandler
-    .thumb_set SPI3_IRQHandler,Default_Handler
-    .weak      UART4_IRQHandler
-    .thumb_set UART4_IRQHandler,Default_Handler
-    .weak      UART5_IRQHandler
-    .thumb_set UART5_IRQHandler,Default_Handler
-    .weak      TIM6_DAC_IRQHandler
-    .thumb_set TIM6_DAC_IRQHandler,Default_Handler
-    .weak      TIM7_IRQHandler
-    .thumb_set TIM7_IRQHandler,Default_Handler
-    .weak      DMA2_Stream0_IRQHandler
-    .thumb_set DMA2_Stream0_IRQHandler,Default_Handler
-    .weak      DMA2_Stream1_IRQHandler
-    .thumb_set DMA2_Stream1_IRQHandler,Default_Handler
-    .weak      DMA2_Stream2_IRQHandler
-    .thumb_set DMA2_Stream2_IRQHandler,Default_Handler
-    .weak      DMA2_Stream3_IRQHandler
-    .thumb_set DMA2_Stream3_IRQHandler,Default_Handler
-    .weak      DMA2_Stream4_IRQHandler
-    .thumb_set DMA2_Stream4_IRQHandler,Default_Handler
-    .weak      ETH_IRQHandler
-    .thumb_set ETH_IRQHandler,Default_Handler
-    .weak      ETH_WKUP_IRQHandler
-    .thumb_set ETH_WKUP_IRQHandler,Default_Handler
-    .weak      CAN2_TX_IRQHandler
-    .thumb_set CAN2_TX_IRQHandler,Default_Handler
-    .weak      CAN2_RX0_IRQHandler
-    .thumb_set CAN2_RX0_IRQHandler,Default_Handler
-    .weak      CAN2_RX1_IRQHandler
-    .thumb_set CAN2_RX1_IRQHandler,Default_Handler
-    .weak      CAN2_SCE_IRQHandler
-    .thumb_set CAN2_SCE_IRQHandler,Default_Handler
-    .weak      OTG_FS_IRQHandler
-    .thumb_set OTG_FS_IRQHandler,Default_Handler
-    .weak      DMA2_Stream5_IRQHandler
-    .thumb_set DMA2_Stream5_IRQHandler,Default_Handler
-    .weak      DMA2_Stream6_IRQHandler
-    .thumb_set DMA2_Stream6_IRQHandler,Default_Handler
-    .weak      DMA2_Stream7_IRQHandler
-    .thumb_set DMA2_Stream7_IRQHandler,Default_Handler
-    .weak      USART6_IRQHandler
-    .thumb_set USART6_IRQHandler,Default_Handler
-    .weak      I2C3_EV_IRQHandler
-    .thumb_set I2C3_EV_IRQHandler,Default_Handler
-    .weak      I2C3_ER_IRQHandler
-    .thumb_set I2C3_ER_IRQHandler,Default_Handler
-    .weak      OTG_HS_EP1_OUT_IRQHandler
-    .thumb_set OTG_HS_EP1_OUT_IRQHandler,Default_Handler
-    .weak      OTG_HS_EP1_IN_IRQHandler
-    .thumb_set OTG_HS_EP1_IN_IRQHandler,Default_Handler
-    .weak      OTG_HS_WKUP_IRQHandler
-    .thumb_set OTG_HS_WKUP_IRQHandler,Default_Handler
-    .weak      OTG_HS_IRQHandler
-    .thumb_set OTG_HS_IRQHandler,Default_Handler
-    .weak      DCMI_IRQHandler
-    .thumb_set DCMI_IRQHandler,Default_Handler
-    .weak      HASH_RNG_IRQHandler
-    .thumb_set HASH_RNG_IRQHandler,Default_Handler
-    .weak      FPU_IRQHandler
-    .thumb_set FPU_IRQHandler,Default_Handler
