[应用相关] emwin控件尺寸,是不是有的不能改
1171|10
 楼主| asmine 发表于 2021-8-6 13:33 | 显示全部楼层 |阅读模式
  1. /*********************************************************************
  2. *
  3. *       _aDialogCreate
  4. */
  5. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
  6.         {
  7.           { FRAMEWIN_CreateIndirect,        "TestV10",         ID_FRAMEWIN_0, 0, 0, 800, 480, 0, 0x64, 0 },
  8.           { DROPDOWN_CreateIndirect,         "Dropdown", ID_DROPDOWN_0, 660, 30, 80, 50, 0, 0x0, 0},
  9.           { EDIT_CreateIndirect,                 "Edit", ID_EDIT_0, 30, 260, 480, 80, 0, 0x64, 0 },
  10. //          { TEXT_CreateIndirect,                 "RECEIVE",         ID_TEXT_0, 30, 30, 480, 200, 0, 0x64, 0 },
  11.           { MULTIEDIT_CreateIndirect,  "Multiedit", ID_TEXT_0, 30, 30, 480, 200, 0, 0x0, 0 },
  12.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_0, 520, 290, 75, 26, 0, 0x0, 0 },
  13.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_1, 680, 410, 100, 20, 0, 0x64, 0 },
  14.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_2, 690, 385, 80, 20, 0, 0x64, 0 },
  15.           { DROPDOWN_CreateIndirect,         "Dropdown", ID_DROPDOWN_1, 660, 70, 80, 50, 0, 0x0, 0 },
  16.           { DROPDOWN_CreateIndirect,         "Dropdown", ID_DROPDOWN_2, 660, 110, 80, 50, 0, 0x0, 0 },
  17.           { DROPDOWN_CreateIndirect,         "Dropdown", ID_DROPDOWN_3, 660, 150, 80, 50, 0, 0x0, 0 },
  18.           { DROPDOWN_CreateIndirect,         "Dropdown", ID_DROPDOWN_4, 660, 190, 80, 50, 0, 0x0, 0 },
  19.           { CHECKBOX_CreateIndirect,         "Checkbox", ID_CHECKBOX_0, 30, 370, 80, 20, 0, 0x0, 0 },
  20.           { CHECKBOX_CreateIndirect,         "Checkbox", ID_CHECKBOX_1, 30, 400, 80, 20, 0, 0x0, 0 },
  21.           { EDIT_CreateIndirect,                 "Edit",         ID_EDIT_1, 190, 370, 45, 20, 0, 0x64, 0 },
  22.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_3, 150, 370, 35, 20, 0, 0x64, 0 },
  23.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_4, 245, 370, 31, 20, 0, 0x64, 0 },
  24.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_1, 290, 370, 105, 30, 0, 0x0, 0 },
  25.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_2, 290, 410, 105, 30, 0, 0x0, 0 },
  26.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_3, 400, 370, 105, 30, 0, 0x0, 0 },
  27.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_4, 400, 410, 105, 30, 0, 0x0, 0 },
  28.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_5, 560, 30, 60, 20, 0, 0x64, 0 },
  29.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_6, 560, 70, 80, 20, 0, 0x64, 0 },
  30.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_7, 560, 110, 80, 20, 0, 0x64, 0 },
  31.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_8, 560, 150, 80, 20, 0, 0x64, 0 },
  32.           { TEXT_CreateIndirect,                 "Text",         ID_TEXT_9, 560, 190, 80, 20, 0, 0x64, 0 },
  33.           { CHECKBOX_CreateIndirect,         "Checkbox", ID_CHECKBOX_2, 560, 230, 80, 20, 0, 0x0, 0 },
  34.           // USER START
  35.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_USBTest, 510, 410, 105, 30, 0, 0x0, 0 },
  36.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_LcdTest, 510, 370, 105, 30, 0, 0x0, 0 },
  37.           { BUTTON_CreateIndirect,                 "Button",         ID_BUTTON_clearRVE, 660, 230, 75, 26, 0, 0x0, 0 },
  38.           // USER END
  39.         };
问一下,emwin创建的控件,后面的尺寸信息,是不是有些不能够更改?
占得人间第一春 发表于 2022-12-19 19:08 | 显示全部楼层
应该都可以修改吧
晚晚皆安 发表于 2022-12-19 19:40 | 显示全部楼层
这种东西为啥不让修改尺寸啊?
一枝香 发表于 2022-12-19 20:12 | 显示全部楼层
我记得是可以改,你想改那个,改不明白嘞?
討厭和人归類 发表于 2022-12-19 20:44 | 显示全部楼层
应该有的不能改吧,有可能不能改
林间有新绿 发表于 2022-12-19 21:16 | 显示全部楼层
你指的是哪个尺寸不能改?
热爱童话世界 发表于 2022-12-19 21:48 | 显示全部楼层
我觉得都可以改啊,这种不都是自己随意的么
岁月反驳 发表于 2022-12-19 22:20 | 显示全部楼层
你可以自己改的,但是有的控件尺寸属实不能改
漫过岁月 发表于 2022-12-19 22:52 | 显示全部楼层
尺寸信息你改改看呗,也许能改动呢
喜爱弄人 发表于 2022-12-19 23:24 | 显示全部楼层
试试吧,一般都是要尝试的,毕竟emwin也没有啥主要说明之类的
偷吻月亮 发表于 2022-12-19 23:56 | 显示全部楼层
这是尺寸吧,应该是能改动
