为什么定时器已初始化但51单片机不工作?
5621|1
 楼主| jcky001 发表于 2021-8-23 11:45 | 显示全部楼层 |阅读模式
/*--------函数申明--------*/
void mode_change();
void Init_timer0(void);
void Init_Timer1(void);
int main()
        LCD_Init();
        WRITE_Str(1,3,"Hello World",11);
        WRITE_Str(2,1,"Welcome to Use",14);
        sys_delays(5);
        LCD_Clear();
        WRITE_Str(1,3,"Choose mode",11);
        mode_change();
        WRITE_Str(2,3,"Tempture:",9);
        WRITE_COM(0x80+0x40+12);
        WRITE_DATA(0xdf);
        WRITE_DATA(0x43);
        Init_Timer0();
        Init_Timer1();
        while(1)
                while(mode == 1)
                        IF(GD == 0)
                                sys_delayxms(200);
                                Counter=0;
                                L1=0;
                                L2=1;
                                L3=1;
                                TR1=1;
                                FS=0;
                                while(Flag_5s == 0);
                                TR1=0;
                                FS=1;
                                Flag_5s=0;
                        if(K1 == 0)
                          sys_delayxms(10);
                          if(K1 == 0)
                                  mode=1;
                                        LCD_Clear();
                WRITE_Str(1,7,"Mode:1",6);
            if(K2 == 0)
                          sys_delayxms(10);
                    if(K2 == 0)
                                  mode=2;
                                        LCD_Clear();
                WRITE_Str(1,7,"Mode:2",6);
                  if(K3 == 0)
                          sys_delayxms(10);
                          if(K3 == 0)
                                  mode=3;
                                        LCD_Clear();
                WRITE_Str(1,7,"Mode:3",6);
                while(mode == 2)
                        if(GD == 0)
                                sys_delayxms(200);
                                Counter=0;
                                L1=0;
                                L2=0;
                                L3=1;
                                TR1=1;
                                FS=0;
                                while(Flag_10s == 0);
                                TR1=0;
                                FS=1;
                                Flag_10s=0;
                        if(K1 == 0)
                          sys_delayxms(10);
                          if(K1 == 0)
                                  mode=1;
                                        LCD_Clear();
            if(K2 == 0)
                          sys_delayxms(10);
                    if(K2 == 0)
                                  mode=2;
                                        LCD_Clear();
                  if(K3 == 0)
                          sys_delayxms(10);
                          if(K3 == 0)
                                  mode=3;
                                        LCD_Clear();
                while(mode == 3)
                        if(GD == 0)
                                sys_delayxms(200);
                                Counter=0;
                                L1=0;
                                L2=0;
                                L3=0;
                                TR1=1;
                                FS=0;
                                while(Flag_15s == 0);
                                TR1=0;
                                FS=1;
                                Flag_15s=0;
                        if(K1 == 0)
                          sys_delayxms(10);
                          if(K1 == 0)
                                  mode=1;
                                        LCD_Clear();
            if(K2 == 0)
                          sys_delayxms(10);
                    if(K2 == 0)
                                  mode=2;
                                        LCD_Clear();
                  if(K3 == 0)
                          sys_delayxms(10);
                          if(K3 == 0)
                                  mode=3;
                                        LCD_Clear();
//模式选择
void mode_change()
        mode=0;
        while(mode == 0)
                if(K1 == 0)
                        sys_delayxms(10);
                        if(K1 == 0)
                                mode=1;
                                LCD_Clear();
                if(K2 == 0)
                        sys_delayxms(10);
                        if(K2 == 0)
                                mode=2;
                                LCD_Clear();
                if(K3 == 0)
                        sys_delayxms(10);
                        if(K3 == 0)
                                mode=3;
                                LCD_Clear();
void Init_Timer0(void)
        TMOD |= 0x01 ;          //使用模式1,16位计数器,使用"|"符号可以在使用多个定时器时不受影响
  TH0=(65535-50000)/256;                //给定初值
  TL0=(65535-50000)%256;
  EA=1;                    //总中断打开
  ET0=1;                   //定时器中断打开
  TR0=1;                   //定时器开关关闭
void Timer0_IRS() interrupt 1
        TH0=(65535-60000)/256;                //给定初值
  TL0=(65535-60000)%256;
  Tem_Counter++;
        if(Tem_Counter >= 25)
                Tem_Counter=0;
                ReadTemperature();
                WRITE_Num(2,10,Tempture%100/10);
                WRITE_Num(2,11,Tempture%10);
                if(Tempture > 30)
                        BZ=0;
                else
                        BZ=1;
        TMOD |= 0x10 ;          //使用模式1,16位计数器,使用"|"符号可以在使用多个定时器时不受影响
  TH1=(65535-50000)/256;                //给定初值
  TL1=(65535-50000)%256;
  EA=1;                    //总中断打开
  ET1=1;                   //定时器中断打开
  TR1=0;                   //定时器开关关闭
void Timer1_IRS() interrupt 3
        Counter++;
        if(mode == 1 && Counter == 100)
                Counter=0;
                Flag_5s=1;
        if(mode == 2 && Counter == 200)
                Counter=0;
                Flag_10s=1;
        if(mode == 3 && Counter == 300)
                Counter=0;
                Flag_15s=1;
下面是仿真
rankey 发表于 2021-8-24 19:58 | 显示全部楼层
看了一遍代码,发现T1定时器,初始化后 TR1=0;就是说没开定时器1
   然后在大循环while里,T1定时器也是开一会,马上又关掉了。
       T1定时器,基本上没正常开启。
   对T1定时器的使用,与我在用的T1不一样。
  我一般这样用,比如说:
      void Timer1Interrupt(void) interrupt 3  //8位自动重载定时到250us
         static  unsigned char  scan_K1_CNT;
         TF1=0;  //清定时器中断标志
         TR1=0;   //关定时器1
           scan_K1_CNT++;
          if(scan_K1_CNT>=40)
                        scan_K1_CNT=0;
                        scan_K1_key();        //做一次按键扫描
         if(Encoder_enable==0)  //不扫描编码器时,做定时累加等待
                 Time_count_Encoder++;
         if(SEG_Blink_enable)   //数码要闪烁,使能打开
                 SEG_Blink_timeCnt++;
                 if(SEG_Blink_timeCnt>=const_SEG_Blink_all)
                   {SEG_Blink_timeCnt=0; }
   TR1=1;   //开定时器1
