| 单片机学习板上用的是16个管脚的12864,按照20个管脚的datasheet写了一段程序,但12864不起作用,是程序写的不对,还是datasheet不对,找不到16个管脚的datasheet,以下是我写的程序:
 #include<reg52.h>
 #define uchar unsigned char
 #define uint unsigned int
 uchar code dis1[]={"welcome"};
 uchar code dis2[]={"2016-08-11"};
 sbit lcde=P2^7;     // 使能,下降沿写数据,为1的时候读数据
 sbit rd=P2^6;     //rd=0 指令,rd=1 数据
 sbit wr=P2^5;     //wr=0 往lcd写,wr=1 读lcd
 uchar busy,j;
 void delay(uchar z)
 uchar x,y;
 for(x=z;x>0;x--)
 for(y=110;y>0;y--);
 void write_com(uchar com)
 rd=0;
 wr=0;
 lcde=0;
 delay(10);
 P0=com;
 delay(10);
 lcde=1;
 delay(10);
 lcde=0;
 delay(10);
 void write_date(uchar date)
 rd=1;
 wr=0;
 lcde=0;
 delay(10);
 P0=date;
 delay(10);
 lcde=1;
 delay(10);
 lcde=0;
 delay(10);
 uchar lcd_busy()
 uchar busy;
 rd=0;
 wr=1;
 lcde=1;
 delay(1);
 lcde=0;
 busy=P0&0x80;  //P0.7为BF位,得到BF位
 return busy;
 void init()
 //    delay(10);
 //    write_com(0x38);     //数据总线为8位,显示2行
 delay(10);
 write_com(0x0c);    //显示功能开,无光标,不闪烁
 delay(10);
 write_com(0x06);    //写入后光标右移,屏幕不动
 delay(10);
 write_com(0x01);    //清屏
 delay(10);
 void lcd_disp_pos(uchar x,y)    //显示位置函数
 uchar address;
 switch(x)
 case 1:address=0x80+y;
 break;
 case 2:address=0x90+y;
 break;
 case 3:address=0x88+y;
 break;
 case 4:address=0x98+y;
 break;
 delay(5);
 write_com(address);
 void main()
 init();
 delay(10);
 lcd_disp_pos(1,2);
 j=0;
 while(dis1[j]!='\0')
 delay(10);
 write_date(dis1[j]);
 j++;
 lcd_disp_pos(2,2);
 j=0;
 while(dis2[j]!='\0')
 delay(10);
 write_date(dis2[j]);
 j++;
