[STM32L4] L432+AD7792,全0
1610|19
 楼主| wyjie 发表于 2021-10-11 23:11 | 显示全部楼层 |阅读模式
使用L432的SPI3接AD7792,AD7792的/CS接地。
工程使用CUBE生成
SPI配置如下
static void MX_SPI3_Init(void)
  hspi3.Instance = SPI3;
  hspi3.Init.Mode = SPI_MODE_MASTER;
  hspi3.Init.Direction = SPI_DIRECTION_2LINES;
  hspi3.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi3.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi3.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi3.Init.NSS = SPI_NSS_SOFT;
  hspi3.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
  hspi3.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi3.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi3.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi3.Init.CRCPolynomial = 7;
  hspi3.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
  hspi3.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
  if (HAL_SPI_Init(&hspi3) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
void HAL_SPI_MspInit(SPI_HandleTypeDef* hspi)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(hspi->Instance==SPI3)
  /* USER CODE BEGIN SPI3_MspInit 0 */
  /* USER CODE END SPI3_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_SPI3_CLK_ENABLE();
    /**SPI3 GPIO Configuration
    PB3 (JTDO-TRACESWO)     ------> SPI3_SCK
    PB4 (NJTRST)     ------> SPI3_MISO
    PB5     ------> SPI3_MOSI
    GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF6_SPI3;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  /* USER CODE BEGIN SPI3_MspInit 1 */
  /* USER CODE END SPI3_MspInit 1 */
自己写的:
读写:
void USER_SPI3_Write(uint8_t Tx_Len)
// HAL_SPI_Transmit_IT(&hspi3, gSPI3WriteBuff, Tx_Len);
HAL_SPI_Transmit(&hspi3, gSPI3WriteBuff, Tx_Len,1000);
void USER_SPI3_Read(uint8_t Rx_Len)
uint8_t i = 0;
uint8_t m_SPI3ReadWriteBuff[Rx_Len];
for(i = 0; i < Rx_Len;i++)
  m_SPI3ReadWriteBuff = 0x00;
HAL_SPI_TransmitReceive(&hspi3, m_SPI3ReadWriteBuff, gSPI3ReadBuff, Rx_Len,1000);
初始化
void USER_InitAD7792(void)
gSPI3WriteBuff[0] = 0xFF;
gSPI3WriteBuff[1] = 0xFF;
gSPI3WriteBuff[2] = 0xFF;
gSPI3WriteBuff[3] = 0xFF;
USER_SPI3_Write(4);
USER_SPI3_Write(4);
while(1)
  gSPI3WriteBuff[0] = 0x40;
  gSPI3ReadBuff[0] = 0;
  gSPI3ReadBuff[1] = 0;
  USER_SPI3_Write(1);
  USER_SPI3_Read(1);
  if(gSPI3ReadBuff[0] == 0x80)
   break;
uint8_t USER_ReadDataFromAD7792(void)
uint8_t i = 0;
for(i = 0; i < 8; i++)
  gADData = 0;
gSPI3WriteBuff[0] = 0x28;
gSPI3WriteBuff[1] = 0x01;
USER_SPI3_Write(2);
gSPI3WriteBuff[0] = 0x10;
gSPI3WriteBuff[1] = 0x10;
gSPI3WriteBuff[2] = 0x86;//这里应该是AD7792片上的温度传感器
USER_SPI3_Write(3);
gSPI3WriteBuff[0] = 0x08;
gSPI3WriteBuff[1] = 0x20;
gSPI3WriteBuff[2] = 0x01;
USER_SPI3_Write(3);
while(1)
  USER_SPI3_Write(1);
  USER_SPI3_Read(1);
  if(gSPI3ReadBuff[0] == 0x06)
   break;
HAL_Delay(20);
gSPI3WriteBuff[0] = 0x58;
USER_SPI3_Write(1);
USER_SPI3_Read(2); //这里始终是0
gADData[0] = gSPI3ReadBuff[0];
gADData[1] = gSPI3ReadBuff[1];
xxrs 发表于 2021-10-11 23:13 | 显示全部楼层
除了这点有问题外,其它功能是否都正常了。
chenjunt 发表于 2021-10-11 23:15 | 显示全部楼层
首先检查下 硬件线路有没有问题。
dengdc 发表于 2021-10-11 23:17 | 显示全部楼层
那些芯片都有参考电路的。
 楼主| wyjie 发表于 2021-10-11 23:19 | 显示全部楼层
gSPI3WriteBuff[0] = 0x48;
        USER_SPI3_Write(1);
        USER_SPI3_Read(2);
读取数据的时候改成这样,读取模式寄存器,可以读出0x6001来,
 楼主| wyjie 发表于 2021-10-11 23:22 | 显示全部楼层
可以读取状态寄存器呀,标志位指示转换完了呀,而且我采集的是片上的温度传感器呀,这个外部电路应该没有影响吧
dingy 发表于 2021-10-11 23:26 | 显示全部楼层
如果确定硬件没问题,那就检查下SPI相关配置
spark周 发表于 2021-10-11 23:29 | 显示全部楼层
比方相位、极性等两边是否一致
 楼主| wyjie 发表于 2021-10-11 23:31 | 显示全部楼层
可是我能读出状态寄存器什么的呀
huangchui 发表于 2021-10-11 23:36 | 显示全部楼层
检查硬件和时序问题
dengdc 发表于 2021-10-11 23:37 | 显示全部楼层
先排除硬件问题
chuxh 发表于 2021-10-11 23:40 | 显示全部楼层
帮楼主顶一下
dingy 发表于 2021-10-11 23:42 | 显示全部楼层
没用过这个芯片
renyaq 发表于 2021-10-11 23:45 | 显示全部楼层
硬件上怎么接的啊
keaibukelian 发表于 2021-11-3 13:41 | 显示全部楼层
是没有电平的变化吗
labasi 发表于 2021-11-3 13:43 | 显示全部楼层
可以读一下寄存器的值
paotangsan 发表于 2021-11-3 13:45 | 显示全部楼层
读出来的数据有问题啊
tpgf 发表于 2021-11-3 13:47 | 显示全部楼层
用示波器看看波形吧
renzheshengui 发表于 2021-11-3 13:49 | 显示全部楼层
二者之间使用spi吗
wakayi 发表于 2021-11-3 13:49 | 显示全部楼层
硬件连接可靠吗
