[MM32软件] 用寄存器导致不能进入定时器中断
1870|12
 楼主| 州滁387 发表于 2022-1-14 08:42 | 显示全部楼层 |阅读模式
void TIM3_UPCount_Init(void)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
   // NVIC_InitTypeDef NVIC_StructInit;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
    TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
    TIM_TimeBaseStructure.TIM_Period = 50;
    TIM_TimeBaseStructure.TIM_Prescaler = 36000-1;
    //Sampling frequency of digital filter does not affect timer clock
    //Sampling Frequency Dividing Value
    TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
   // interrupt priority configuration
   //NVIC_StructInit.NVIC_IRQChannel = TIM3_IRQn;
   //NVIC_StructInit.NVIC_IRQChannelPriority = 1;
   //NVIC_StructInit.NVIC_IRQChannelCmd = ENABLE;
   //NVIC_Init(&NVIC_StructInit);
    TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
    TIM_ClearFlag(TIM3, TIM_FLAG_Update);
    TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
    TIM_ARRPreloadConfig(TIM3, ENABLE);
    TIM_Cmd(TIM3, ENABLE);
void NVIC_Configure(u8 ch, u8 pri, u8 sub)
    exNVIC_Init_TypeDef  NVIC_InitStruct;
    NVIC_InitStruct.NVIC_IRQChannel = ch;
    NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = pri;
    NVIC_InitStruct.NVIC_IRQChannelSubPriority = sub;
    NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
    exNVIC_Init(&NVIC_InitStruct);
s32 main(void)
          SystemInit();//36M
    LED_Init();
    DELAY_Init();
          NVIC_Configure(TIM3_IRQn, 0, 1);
          TIM3_UPCount_Init();
    while(1)
                         if(1 == j)
                          // GPIOB->BRR = 0x1000U;
                                GPIO_ResetBits(GPIOB,GPIO_Pin_12);
                         else
                         // GPIOB->BSRR = 0x1000U;
                                GPIO_SetBits(GPIOB,GPIO_Pin_12);
void TIM3_IRQHandler(void)
        if(TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
                i++;
                if(i>9)
                  i =0;
                        j = !j;
 楼主| 州滁387 发表于 2022-1-14 08:45 | 显示全部楼层
GPIOB->BRR      GPIOB->BSRR   2个寄存器直接赋值导致不能进去TIM3中断,请问怎么回事呢。芯片是MM32F0133C7P
huquanz711 发表于 2022-1-15 08:59 来自手机 | 显示全部楼层
那应该是寄存器配置有问题吧
豌豆爹 发表于 2022-1-17 10:06 来自手机 | 显示全部楼层
最好先检查一下你的寄存器
yangxiaor520 发表于 2022-1-17 20:56 来自手机 | 显示全部楼层
寄存器配置对没有
gouguoccc 发表于 2022-1-18 08:26 来自手机 | 显示全部楼层
那是没配对的原因
labasi 发表于 2022-2-4 09:32 | 显示全部楼层
可以直接对这两个寄存器赋值吗
tpgf 发表于 2022-2-4 09:35 | 显示全部楼层
仿真时候看一下寄存器状态
paotangsan 发表于 2022-2-4 09:41 | 显示全部楼层
寄存器配置有问题
renzheshengui 发表于 2022-2-4 09:55 | 显示全部楼层
这两个标志位是什么 意思来着?
wakayi 发表于 2022-2-4 10:02 | 显示全部楼层
都需要配置哪些寄存器呢
wowu 发表于 2022-2-4 10:09 | 显示全部楼层
这是将引脚配置成什么状态了啊
match007 发表于 2022-2-11 16:26 | 显示全部楼层
这不还是库么
