现在的显示器件实在是太丰富了,且价格也不很贵,这为应用带来了极大的方便。
为了便于图片的显示,这里使用的是一款0.96寸的显示屏,其分辨率为160*80,别开其尺寸不大,但其显示的清晰度很高。
为使用的灵活性,这里是采用GPIO模拟SPI的方式来驱动该显示屏。
该显示屏与开发板的连接关系为:
BLK-------PB8
CS--------PB7
RS--------PB6
RESET---PB5
SCL-------PA5
SDA------PA7
实现高低电平的引脚定义为:
#define OLED_SCLK_Set() GPIO_Pins_Set(GPIOA, GPIO_PIN_5) //CLK
#define OLED_SCLK_Clr() GPIO_Pins_Reset(GPIOA, GPIO_PIN_5)
#define OLED_SDIN_Set() GPIO_Pins_Set(GPIOA, GPIO_PIN_7) //DIN
#define OLED_SDIN_Clr() GPIO_Pins_Reset(GPIOA, GPIO_PIN_7)
#define OLED_RST_Set() GPIO_Pins_Set(GPIOB, GPIO_PIN_5) //RES
#define OLED_RST_Clr() GPIO_Pins_Reset(GPIOB, GPIO_PIN_5)
#define OLED_DC_Set() GPIO_Pins_Set(GPIOB, GPIO_PIN_6) //DC
#define OLED_DC_Clr() GPIO_Pins_Reset(GPIOB, GPIO_PIN_6)
#define OLED_CS_Set() GPIO_Pins_Set(GPIOB, GPIO_PIN_7) //CS
#define OLED_CS_Clr() GPIO_Pins_Reset(GPIOB, GPIO_PIN_7)
#define OLED_BLK_Set() GPIO_Pins_Set(GPIOB, GPIO_PIN_8) //BLK
#define OLED_BLK_Clr() GPIO_Pins_Reset(GPIOB, GPIO_PIN_8)
为显示屏所用引脚的配置函数为:
- void LCD_Initialize()
- GPIO_InitTypeGPIO_InitStructure;
- RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOA);
- GPIO_Structure_Initialize(&GPIO_InitStructure);
- GPIO_InitStructure.Pin = GPIO_PIN_5|GPIO_PIN_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT_PP;
- GPIO_InitStructure.GPIO_Current= GPIO_DS_4MA;
- GPIO_Peripheral_Initialize(GPIOA,&GPIO_InitStructure);
- RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOB);
- GPIO_InitStructure.Pin = GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7|GPIO_PIN_8;
- GPIO_Peripheral_Initialize(GPIOB,&GPIO_InitStructure);
模拟SPI方式发送字节数据的函数为:
- void LCD_Writ_Bus(u8 dat)
- u8 i;
- OLED_CS_Clr();
- for(i=0;i<8;i++)
- OLED_SCLK_Clr();
- if(dat&0x80)
- OLED_SDIN_Set();
- else
- OLED_SDIN_Clr();
- OLED_SCLK_Set();
- dat<<=1;
- OLED_CS_Set();
该显示屏的初始化函数为:
- void Lcd_Init(void)
- OLED_RST_Clr();
- SysTick_Delay_Ms(200);
- OLED_RST_Set();
- LCD_WR_REG(0x11);
- SysTick_Delay_Ms(100);
- LCD_WR_REG(0x21);
- LCD_WR_REG(0xB1);
- LCD_WR_DATA8(0x05);
- LCD_WR_DATA8(0x3A);
- LCD_WR_REG(0xB2);
- LCD_WR_REG(0xB3);
- LCD_WR_REG(0xB4);
- LCD_WR_DATA8(0x03);
- LCD_WR_REG(0xC0);
- LCD_WR_DATA8(0x62);
- LCD_WR_DATA8(0x02);
- LCD_WR_DATA8(0x04);
- LCD_WR_REG(0xC1);
- LCD_WR_DATA8(0xC0);
- LCD_WR_REG(0xC2);
- LCD_WR_DATA8(0x0D);
- LCD_WR_DATA8(0x00);
- LCD_WR_REG(0xC3);
- LCD_WR_DATA8(0x8D);
- LCD_WR_DATA8(0x6A);
- LCD_WR_REG(0xC4);
- LCD_WR_DATA8(0xEE);
- LCD_WR_REG(0xC5);
- LCD_WR_DATA8(0x0E);
- LCD_WR_REG(0xE0);
- LCD_WR_DATA8(0x10);
- LCD_WR_DATA8(0x07);
- LCD_WR_DATA8(0x0A);
- LCD_WR_DATA8(0x12);
- LCD_WR_DATA8(0x27);
- LCD_WR_DATA8(0x37);
- LCD_WR_REG(0xE1);
- LCD_WR_DATA8(0x0F);
- LCD_WR_DATA8(0x06);
- LCD_WR_DATA8(0x08);
- LCD_WR_DATA8(0x13);
- LCD_WR_DATA8(0x26);
- LCD_WR_DATA8(0x36);
- LCD_WR_REG(0x3A);
- LCD_WR_REG(0x36);
- LCD_WR_DATA8(0x78);
- LCD_WR_REG(0x29);
- OLED_BLK_Set();
以色彩清屏的函数为:
- void LCD_Clear(u16 Color)
- u16 i,j;
- LCD_Address_Set(0,0,LCD_W-1,LCD_H-1);
- for(i=0;i<LCD_W;i++)
- for (j=0;j<LCD_H;j++)
- LCD_WR_DATA(Color);
实现字符串显示的函数为:
- void LCD_ShowString(u16 x,u16 y,const u8 *p,u16 color)
- while(*p!='\0')
- if(x>LCD_W-16)
- x=0;
- y+=16;
- if(y>LCD_H-16)
- y=x=0;
- LCD_Clear(RED);
- LCD_ShowChar(x,y,*p,0,color);
- x+=8;
- p++;
进行图片显示的函数为:
- void LCD_ShowPicturea(u16 x1,u16 y1,u16 x2,u16 y2)
- int i;
- LCD_Address_Set(x1,y1,x2,y2);
- for(i=0;i<12800;i++)
- LCD_WR_DATA8(gImage_FJ[i*2]);
- LCD_WR_DATA8(gImage_FJ[i*2+1]);
实现图1至图3所示效果的主程序为:
- int main(void)
- LCD_Initialize();
- Lcd_Init();
- LCD_Clear(BLACK);
- LCD_ShowString(20,10,"N32G430 TEST",RED);
- LCD_ShowString(20,30,"0.96' OLED",YELLOW);
- SysTick_Delay_Ms(2000);
- LCD_ShowPicturea(0,0,159,79);
- LCD_ShowPictureb(0,0,159,79);
- while(1);
经程序的编译与下载,其显示效果如下:
图1显示字符串
图2显示风景图片
图3显示人物图片
