| 大佬们,请问KEIL5无法编译怎么办?*** Target 'HT32' uses ARM-Compiler 'Default Compiler Version 5' which is not available. *** Please review the installed ARM Compiler Versions:
 'Manage Project Items - Folders/Extensions' to manage ARM Compiler Versions.
 'Options for Target - Target' to select an ARM Compiler Version for the target.
 *** Build aborted.
 Build Time Elapsed:  00:00:01
