今天捣鼓了一下按键控制灯,用microchip studio自动生成代码,然后自己再增加一部分代码。
代码如下:
- #include <atmel_start.h>
- int main(void)
- /* Initializes MCU, drivers and middleware */
- atmel_start_init();
- _gpio_set_level(GPIO_PORTC,0x00040000,1);
- /* Replace with your application code */
- while (1) {
- if((gpio_get_port_level(GPIO_PORTB)&0x80000000)==0x00000000)
- _gpio_set_level(GPIO_PORTC,0x00040000,0);
- else
初始化部分代码:
- * Initializes MCU, drivers and middleware in the project
- void atmel_start_init(void)
- system_init();
- * Code generated from Atmel Start.
- * This file will be overwritten when reconfiguring your Atmel Start project.
- * Please copy examples or other code you want to keep to a separate file
- * to avoid losing it when reconfiguring.
- #include "driver_init.h"
- #include <peripheral_clk_config.h>
- #include <utils.h>
- #include <hal_init.h>
- void system_init(void)
- init_mcu();
- // GPIO on PB31
- // Set pin direction to input
- gpio_set_pin_direction(KEY, GPIO_DIRECTION_IN);
- gpio_set_pin_pull_mode(KEY,
- // <y> Pull configuration
- // <id> pad_pull_config
- // <GPIO_PULL_OFF"> Off
- // <GPIO_PULL_UP"> Pull-up
- // <GPIO_PULL_DOWN"> Pull-down
- GPIO_PULL_UP);
- gpio_set_pin_function(KEY, GPIO_PIN_FUNCTION_OFF);
- // GPIO on PC18
- gpio_set_pin_level(LED,
- // <y> Initial level
- // <id> pad_initial_level
- // <false"> Low
- // <true"> High
- true);
- // Set pin direction to output
- gpio_set_pin_direction(LED, GPIO_DIRECTION_OUT);
- gpio_set_pin_function(LED, GPIO_PIN_FUNCTION_OFF);
效果图:
