整个函数如下:
- void SysClockConfig_48MHz(void)
- ErrStatus ClockStatus;
- /* Reset CKCU, SYSCLK = HSI */
- CKCU_DeInit();
- /* Enable HSE */
- CKCU_HSECmd(ENABLE);
- /* Wait until HSE is ready or time-out */
- ClockStatus = CKCU_WaitHSEReady();
- if(ClockStatus == SUCCESS)
- /* PLL configuration, PLLCLK = 48 MHz */
- PLLInit.ClockSource = CKCU_PLLSRC_HSE;
- #if defined(HTCFG_HSE_12MHZ)
- PLLInit.CFG = CKCU_PLL_12M_48M;
- #else
- PLLInit.CFG = CKCU_PLL_8M_48M;
- #endif
- PLLInit.BYPASSCmd = DISABLE;
- CKCU_PLLInit(&PLLInit);
- CKCU_PLLCmd(ENABLE);
- /* Wait until PLL is ready */
- while(CKCU_GetClockReadyStatus(CKCU_FLAG_PLLRDY) == RESET);
- /* FLASH wait state configuration */
- FLASH_SetWaitState(FLASH_WAITSTATE_1); /* FLASH one wait clock */
- /* HCLK = SYSCLK/1 */
- CKCU_SetHCLKPrescaler(CKCU_SYSCLK_DIV1);
- /* Configure PLL as system clock */
- ClockStatus = CKCU_SysClockConfig(CKCU_SW_PLL);
- if(ClockStatus != SUCCESS)
- while(1);
- else
- /* HSE is failed. User can handle this situation here. */
- while(1);
