谢谢,已经有了调试信息,但是读取不到image,报错信息如下:
MA35D1 IBR 20211029
RTC power on
SD0 Boot
header0 CRC OK!
TSI Connected
ECC authenticate fail!
SD read image fail
USBD Boot
TSI Connected
这是0= Secure Boot Disabled.的调试信息。
感觉是编译的images有问题,但是又不知怎么解决,编译的时候也没有报错信息啊.
下面是1 = Secure Boot Disabled.的调试信息
MA35D1 IBR 20211029
RTC power on
SD0 Boot
header0 CRC OK!
finish
INFO: ma35d1 config setup
INFO: 1.25V
INFO: CA-PLL is 800000000 Hz
INFO:
>>>>> AXI Port Priority Finish: 0x1500f, 0x1500f, 0x1500f, 0x1500f
INFO:
>>>>> AXI Port Priority Finish: 0x1502f, 0x1510f, 0x1520f, 0x153ef
INFO:
DDR init Finish: 0x0, 0x2675, 0x0
POR: 0x500
INFO: Boot from SDHC0
NOTICE: BL2: v2.3(release):tc_v1.00-25-g5c183c0077
NOTICE: BL2: Built : 23:21:17, Apr 23 2023
INFO: BL2: Doing platform setup
INFO: BL2: Loading image id 3
INFO: Loading image id=3 at address 0x28025000
INFO: Image id=3 loaded: 0x28025000 - 0x280331a2
INFO: BL2: Loading image id 4
INFO: Loading image id=4 at address 0x8f800000
INFO: Image id=4 loaded: 0x8f800000 - 0x8f80001c
INFO: OPTEE ep=0x8f800000
INFO: OPTEE header info:
INFO: magic=0x4554504f
INFO: version=0x2
INFO: arch=0x1
INFO: flags=0x0
INFO: nb_images=0x1
INFO: BL2: Loading image id 21
INFO: Loading image id=21 at address 0x8f900000
INFO: Image id=21 loaded: 0x8f900000 - 0x8f960558
INFO: BL2: Skip loading image id 22
INFO: BL2: Loading image id 5
INFO: Loading image id=5 at address 0x85500000
INFO: Image id=5 loaded: 0x85500000 - 0x855d8737
NOTICE: BL2: Booting BL31
INFO: Entry point address = 0x28025000
INFO: SPSR = 0x3cd
INFO: 1.25V
NOTICE: BL31: v2.3(release):tc_v1.00-25-g5c183c0077
NOTICE: BL31: Built : 23:21:17, Apr 23 2023
INFO: ARM GICv2 driver initialized
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x85500000
INFO: SPSR = 0x3c9
U-Boot 2020.07 (Apr 23 2023 - 23:17:41 -0700)
CPU: Nuvoton MA35D1
Model: Nuvoton MA35D1 U-boot
DRAM: 112 MiB
WDT: Not found!
MMC: sdhci@40190000: 0
Loading Environment from UBI... Volume uboot-vol not found!
** Unable to read env from uboot-env:uboot-vol **
In: serial@40700000
Out: serial@40700000
Err: serial@40700000
Net:
Warning: ethernet@40120000 using MAC address from DT
eth0: ethernet@40120000 [PRIME]
Warning: ethernet@40130000 using MAC address from DT
, eth1: ethernet@40130000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
** No partition table - mmc 0 **
MMC Device 1 not found
no mmc device at slot 1
UBIFS error (pid: 1): cannot open "ubi0:rootfs", error -19
Error reading superblock on volume 'ubi0:rootfs' errno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
- mount 'volume-name' volume
Booting form mmc ... ...
MMC read: dev # 0, block # 6144, count 32768 ... 32768 blocks read: OK
MMC read: dev # 0, block # 5632, count 128 ... 128 blocks read: OK
Bad Linux ARM64 Image magic!
Booting from spinand ... ...
List of MTD devices:
* spi-nand0
- device: spi-nand@0
- parent: qspi@40680000
- driver: spi_nand
- type: NAND flash
- block size: 0x20000 bytes
- min I/O: 0x800 bytes
- OOB size: 64 bytes
- OOB available: 24 bytes
- 0x000000000000-0x000020000000 : "spi-nand0"
- 0x000000000000-0x000000300000 : "uboot"
- 0x000000300000-0x0000003c0000 : "uboot-env"
- 0x0000003c0000-0x000000400000 : "device-tree"
- 0x000000400000-0x000001c00000 : "kernel"
- 0x000001c00000-0x000008000000 : "rootfs"
Reading 25165824 byte(s) (12288 page(s)) at offset 0x00000000
Reading 262144 byte(s) (128 page(s)) at offset 0x00000000
