#1 ERROR(ORCAP-36004): Conflicting values of part name found on different sections of "U3".Conflicting values: S3C2440AL_3_BGA289_S3C2440AL_ & S3C2440AL_2_BGA289_S3C2440AL_ Property values of "Device","PCB FootPrint", "Class" and "Value" should be identical on all sections of the part.生成网表的时候,这个问题如何解决?我的U3是分成三个部分的(A,B,C),我觉得主要问题估计是在Conflicting values of part name found on different sections of "U3".这一句上,后面几个值我看了应该都是一致的,请哪位好心人帮忙解答一下。。 |
