- static const uint32_t aDataBuffer[BUFFER_SIZE] = {
- 0x00001021, 0x20423063, 0x408450a5, 0x60c670e7, 0x9129a14a,
- 0xb16bc18c, 0xd1ade1ce, 0xf1ef1231, 0x32732252, 0x52b54294,
- 0x72f762d6, 0x93398318, 0xa35ad3bd, 0xc39cf3ff, 0xe3de2462,
- 0x34430420, 0x64e674c7, 0x44a45485, 0xa56ab54b, 0x85289509,
- 0xf5cfc5ac, 0xd58d3653, 0x26721611, 0x063076d7, 0x569546b4,
- 0xb75ba77a, 0x97198738, 0xf7dfe7fe, 0xc7bc48c4, 0x58e56886,
- 0x78a70840, 0x18612802, 0xc9ccd9ed, 0xe98ef9af, 0x89489969,
- 0xa90ab92b, 0x4ad47ab7, 0x6a961a71, 0x0a503a33, 0x2a12dbfd,
- 0xfbbfeb9e, 0x9b798b58, 0xbb3bab1a, 0x6ca67c87, 0x5cc52c22,
- 0x3c030c60, 0x1c41edae, 0xfd8fcdec, 0xad2abd0b, 0x8d689d49,
- 0x7e976eb6, 0x5ed54ef4, 0x2e321e51, 0x0e70ff9f, 0xefbedfdd,
- 0xcffcbf1b, 0x9f598f78, 0x918881a9, 0xb1caa1eb, 0xd10cc12d,
- 0xe16f1080, 0x00a130c2, 0x20e35004, 0x40257046, 0x83b99398,
- 0xa3fbb3da, 0xc33dd31c, 0xe37ff35e, 0x129022f3, 0x32d24235,
- 0x52146277, 0x7256b5ea, 0x95a88589, 0xf56ee54f, 0xd52cc50d,
- 0x34e224c3, 0x04817466, 0x64475424, 0x4405a7db, 0xb7fa8799,
- 0xe75ff77e, 0xc71dd73c, 0x26d336f2, 0x069116b0, 0x76764615,
- 0x5634d94c, 0xc96df90e, 0xe92f99c8, 0xb98aa9ab, 0x58444865,
- 0x78066827, 0x18c008e1, 0x28a3cb7d, 0xdb5ceb3f, 0xfb1e8bf9,
- 0x9bd8abbb, 0x4a755a54, 0x6a377a16, 0x0af11ad0, 0x2ab33a92,
- 0xed0fdd6c, 0xcd4dbdaa, 0xad8b9de8, 0x8dc97c26, 0x5c644c45,
- 0x3ca22c83, 0x1ce00cc1, 0xef1fff3e, 0xdf7caf9b, 0xbfba8fd9,
- 0x9ff86e17, 0x7e364e55, 0x2e933eb2, 0x0ed11ef0
- uint32_t uCRCValue = 0;
- USART_Config_T usartConfigStruct; /* USART configuration */
- USART_ConfigStructInit(&usartConfigStruct);
- usartConfigStruct.baudRate = 115200;
- usartConfigStruct.mode = USART_MODE_TX_RX;
- usartConfigStruct.parity = USART_PARITY_NONE;
- usartConfigStruct.stopBits = USART_STOP_BIT_1;
- usartConfigStruct.wordLength = USART_WORD_LEN_8B;
- usartConfigStruct.hardwareFlow = USART_HARDWARE_FLOW_NONE;
3.2.2 启用 CRC 外设时钟
在开始使用 CRC 前,需要先通过 RCC 外设启用 CRC 外设时钟。
- RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_CRC);
3.2.3 配置初始 CRC 值
将 CRC_CTRL 寄存器 RST 位置 1,配置初始 CRC 值寄存器(CRC_DATA) 将 CRC 数据寄存器设置为初始 CRC 值 0xFFFFFFF。
3.2.4 CRC 数据校验
完成了开启时钟,初始值的配置后,调用 CRC 计算函数,利用 while 循环往数据寄存器里以 32 位为单位写入数据。当 BUFFER_SIZE 等于零时,意味着数据写入完毕,读取数据寄存器的值,得到的即为输出校验值。可以通过串口助手观察 到标准校验值和输出校验值,当输出校验值与标准校验值相等时,证明数据传输没有出错。
其中32 位数据(32bit Data)作为输入寄存器是写入时存储 CRC 计算器的 新数据。作为输出寄存器是读取时返回 CRC 计算的结果。
- CRC_ResetDATA();
- uCRCValue=CRC_CalculateBlockCRC((uint32_t*)aDataBuffer,BUFFER_SIZE);
- printf("BlockCRC = 0x379E9F06 \r\n");
- printf("CalculateBlockCRC = 0x%08X \r\n", uCRCValue);
CRC_CalcBlockCRC 函数代码如下:
- uint_t CRC_CalculateBlockCRC(uint32_t *buf,uint32_t bufLen)
- While(bufLen--)
- CRC->DATA = *buf++;
- return (CRC->DATA);
