[N32G430] 国民技术N32G430C8开发笔记之UART驱动开发
1233|0
 楼主| drer 发表于 2024-2-18 17:25 | 显示全部楼层 |阅读模式
参考demo
E:\tfs\data\smartsafe\N32G430\Nations.N32G430_Library.1.0.0\projects\n32g430_EVAL\examples\USART\Interrupt开发uart1和uart3驱动。Uart1用于通信,uart3用于调试。
参考用户手册5.2.5复用功能。Uart1_tx引脚使用PA9,重映射使用AF5,Uart1_rx引脚使用PA10,重映射使用AF5,Uart3_tx引脚使用PB10,重映射使用AF10,Uart3_Rx引脚使用PB11,重映射使用AF10。
串口使用ringbuffer,中断方式接收和发送。
1、配置时钟
包括GPIO时钟和uart时钟。
void RCC_Configuration(void)
    /* Enable GPIO clock */
        RCC_AHB_Peripheral_Clock_Enable(USARTy_GPIO_CLK | USARTz_GPIO_CLK);
    /* Enable USARTy and USARTz Clock */
    USARTy_APBxClkCmd(USARTy_CLK);
    USARTz_APBxClkCmd(USARTz_CLK);
2、配置IO
配置IO的复用功能为UART。
void GPIO_Configuration(void)
    GPIO_InitType GPIO_InitStructure;
    /* Initialize GPIO_InitStructure */
    GPIO_Structure_Initialize(&GPIO_InitStructure);
    /* Configure USARTy Tx as alternate function push-pull */
    GPIO_InitStructure.Pin            = USARTy_TxPin;
    GPIO_InitStructure.GPIO_Mode      = GPIO_MODE_AF_PP;
    GPIO_InitStructure.GPIO_Alternate = USARTy_Tx_GPIO_AF;
    GPIO_Peripheral_Initialize(USARTy_GPIO, &GPIO_InitStructure);
    /* Configure USARTz Tx as alternate function push-pull */
    GPIO_InitStructure.Pin            = USARTz_TxPin;
    GPIO_InitStructure.GPIO_Alternate = USARTz_Tx_GPIO_AF;
    GPIO_Peripheral_Initialize(USARTz_GPIO, &GPIO_InitStructure);
    /* Configure USARTx Rx as alternate function push-pull */
    GPIO_InitStructure.Pin            = USARTy_RxPin;
    GPIO_InitStructure.GPIO_Alternate = USARTy_Rx_GPIO_AF;
    /* Configure USARTz Rx as alternate function push-pull */
    GPIO_InitStructure.Pin            = USARTz_RxPin;
    GPIO_InitStructure.GPIO_Alternate = USARTz_Rx_GPIO_AF;
3、配置UART
包括初始化uart,使能uart中断,使能uart外设等。
    /* USARTy and USARTz configuration ------------------------------------------------------*/
    USART_InitStructure.BaudRate            = 115200;
    USART_InitStructure.WordLength          = USART_WL_8B;
    USART_InitStructure.StopBits            = USART_STPB_1;
    USART_InitStructure.Parity              = USART_PE_NO;
    USART_InitStructure.HardwareFlowControl = USART_HFCTRL_NONE;
    USART_InitStructure.Mode                = USART_MODE_RX | USART_MODE_TX;
    /* Configure USARTy and USARTz */
    USART_Initializes(USARTy, &USART_InitStructure);
    USART_Initializes(USARTz, &USART_InitStructure);
    /* Enable USARTy Receive and Transmit interrupts */
    USART_Interrput_Enable(USARTy, USART_INT_RXDNE);
    USART_Interrput_Enable(USARTy, USART_INT_TXDE);
    /* Enable USARTz Receive and Transmit interrupts */
    USART_Interrput_Enable(USARTz, USART_INT_RXDNE);
    USART_Interrput_Enable(USARTz, USART_INT_TXDE);
    /* Enable the USARTy and USARTz */
    USART_Enable(USARTy);
    USART_Enable(USARTz);
4、uart中断响应函数
void COM_UART_IRQHandler(void)
    uint8_t data;
    if (USART_Interrupt_Status_Get(COM_UART, USART_INT_RXDNE) != RESET)
        data = USART_Data_Receive(COM_UART);
        ringBuffer_write(pcomUartRxRingBuffer,data);
    if (USART_Interrupt_Status_Get(COM_UART, USART_INT_TXDE) != RESET)
        if (ringBuffer_is_empty(p_comUartTxRingBuffer))
            /*没有发送数据时要关闭串口发送中断*/
            /* Disable the COM_UART Transmit interrupt */
            USART_Interrput_Disable(COM_UART, USART_INT_TXDE);
        else
            ringBuffer_read(p_comUartTxRingBuffer,&data);
            USART_Data_Send(COM_UART, data);
原文链接:https://blog.csdn.net/sscb0521/article/details/135825482
