mplab ide 用pickit3烧录报错
917|0
 楼主| zzzzzzzzzzzzch 发表于 2024-5-11 12:13 来自手机 | 显示全部楼层 |阅读模式
编译什么的都没错,然后在烧录时会出现caution:check that the device selected in mplab ide is the same one that is physically attached to the debug tool.selecting a device when a 3.3v device is connected can result in damage to the device when the debugger checks the device id.
这个窗口弹出之后会弹出id not match的窗口
求help!!
