[技术讨论] 【Mini-F5265-OB】硬件SPI驱动ST7735OLED屏
585|0
 楼主| ttianyer 发表于 2025-4-6 21:16 | 显示全部楼层 |阅读模式
这篇跟大家分享如何使用硬件SPI驱动LCD屏。
【硬件环境】
1、灵动Mini-F5265-OB 开发板
2、ST7735LCD屏
【连接方式】
1 GND       GND2 3.3V      VCC  3 PA5      SCL 4 PA7      SDA 7 PA4      CS     5 PA1      RES6 PA3      DC8 VCC      BL
【代码实现】
1、开发板的示例提供了基于flash的代码,他使用了硬件片选的功能,因为ST7735相比Flash示例,多了两个引脚即数据/命令脚DC,复位RES(其中的背光我这里直连VCC),因此我对LCD的硬件初始如下:
void LcdIoInit(void){      GPIO_InitTypeDef GPIO_InitStruct;    SPI_InitTypeDef  SPI_InitStruct;    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);    SPI_StructInit(&SPI_InitStruct);    SPI_InitStruct.SPI_Mode      = SPI_Mode_Master;    SPI_InitStruct.SPI_DataSize  = SPI_DataSize_8b;    SPI_InitStruct.SPI_DataWidth = 8;    SPI_InitStruct.SPI_CPOL      = SPI_CPOL_Low;    SPI_InitStruct.SPI_CPHA      = SPI_CPHA_1Edge;    SPI_InitStruct.SPI_NSS       = SPI_NSS_Soft;    SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;    SPI_InitStruct.SPI_FirstBit  = SPI_FirstBit_MSB;    SPI_Init(SPI1, &SPI_InitStruct);    SPI_BiDirectionalLineConfig(SPI1, SPI_Enable_RX);    SPI_BiDirectionalLineConfig(SPI1, SPI_Enable_TX);    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);    GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_5);    GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_5);    GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_5);    GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_5);    GPIO_StructInit(&GPIO_InitStruct);    GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7 ;    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;    GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF_PP;    GPIO_Init(GPIOA, &GPIO_InitStruct);    GPIO_StructInit(&GPIO_InitStruct);    GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_6;    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;    GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_IPU;    GPIO_Init(GPIOA, &GPIO_InitStruct);        SPI_Cmd(SPI1, ENABLE);    //初始化复位、数据引脚     GPIO_StructInit(&GPIO_InitStruct);    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_3;    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;    GPIO_Init(GPIOA, &GPIO_InitStruct);}
初始化这里要特别提一句,如果分频系数过大会造成与LCD通信对不上,我最起先使用256分频,结果点不亮,查找原因好久,后面使用64分频就亮了。
2、接着修改驱动中的写入数据、写命令:
void LCD_Writ_Bus(uint8_t dat) {      SPI_SendData(SPI1, dat);    while (RESET == SPI_GetFlagStatus(SPI1, SPI_FLAG_TXEPT))    {    }    }void LCD_WR_DATA8(uint8_t dat){    SPI_FLASH_CS_L();    LCD_DC_HIGH();//дÊý¾Ý    LCD_Writ_Bus(dat);    SPI_FLASH_CS_H();}void LCD_WR_DATA(uint16_t dat){    SPI_FLASH_CS_L();    LCD_DC_HIGH();//дÊý¾Ý    LCD_Writ_Bus(dat>>8);    LCD_Writ_Bus(dat);    SPI_FLASH_CS_H();}void LCD_WR_REG(uint8_t  dat){    SPI_FLASH_CS_L();    LCD_DC_LOW();//дÃüÁî    LCD_Writ_Bus(dat);    LCD_DC_HIGH();//дÊý¾Ý    SPI_FLASH_CS_H();}
4、当然我还需要声明一些宏命令:
#define SPI_FLASH_CS_H() SPI_CSInternalSelected(SPI1, DISABLE)#define SPI_FLASH_CS_L() SPI_CSInternalSelected(SPI1, ENABLE)#define LCD_DC_LOW()       GPIO_WriteBit(GPIOA, GPIO_Pin_3, Bit_RESET)#define LCD_DC_HIGH()      GPIO_WriteBit(GPIOA, GPIO_Pin_3, Bit_SET)#define LCD_RES_LOW()      GPIO_WriteBit(GPIOA, GPIO_Pin_1, Bit_RESET)#define LCD_RES_HIGH()     GPIO_WriteBit(GPIOA, GPIO_Pin_1, Bit_SET)
这样我们的代码移植就完成了。(注:代码我附)
