 #每日话题# #申请原创# 手头上有一块乐鑫科技的ESP8266,空置了好久了,上周收到STM32U385RG开发板,今天突然想起来这个ESP8266还有服役的机会,于是就出来了这篇文章获取国内城市天气预报。
 下面是板子连接图如下:
   按照上图连接好ESP8266和STM32U385RG开发板就可以。
 下面开始进入正题。
 1.创建cubemx工程
     2.配置好时钟96MHZ
   3.配置好串口,串口1用来调试,串口5用来和ESP8266通信
       4.生成代码
     5.打开KEIL工程
   6.修改核心代码
 /* USER CODE BEGIN Header */
 * @file           : main.c
 * @brief          : Main program body
 * @attention
 * Copyright (c) 2025 STMicroelectronics.
 * All rights reserved.
 * This software is licensed under terms that can be found in the LICENSE file
 * in the root directory of this software component.
 * If no LICENSE file comes with this software, it is provided AS-IS.
 /* USER CODE END Header */
 /* Includes ------------------------------------------------------------------*/
 #include "main.h"
 #include "adc.h"
 #include "usart.h"
 #include "gpio.h"
 /* Private includes ----------------------------------------------------------*/
 /* USER CODE BEGIN Includes */
 #include "ESP8266.h"
 #include "cJSON.h"
 /* USER CODE END Includes */
 /* Private typedef -----------------------------------------------------------*/
 /* USER CODE BEGIN PTD */
 /* USER CODE END PTD */
 /* Private define ------------------------------------------------------------*/
 /* USER CODE BEGIN PD */
 /* USER CODE END PD */
 /* Private macro -------------------------------------------------------------*/
 /* USER CODE BEGIN PM */
 /* USER CODE END PM */
 /* Private variables ---------------------------------------------------------*/
 /* USER CODE BEGIN PV */
 /* USER CODE END PV */
 /* Private function prototypes -----------------------------------------------*/
 void SystemClock_Config(void);
 /* USER CODE BEGIN PFP */
 char TX_Data[]="GET https://api.seniverse.com/v3/weather/now.json?key=SfobYEEioM5L6dRce&location=shanghai&language=zh-Hans&unit=c\r\n";
 char Data[]="AT+CIPSEND\r\n";
 /* USER CODE END PFP */
 /* Private user code ---------------------------------------------------------*/
 /* USER CODE BEGIN 0 */
 #define TEMP_AVG_SLOPE 0.0025//2.5mV/°C
 #define TEMP_V25 0.76  //752mV    Voltage at 30° C (± 1 ° C)
 #define TEMP_VSENSE 3.3/4096
 uint32_t temperature_adc_value = 0;
 float temperature_in_c = 0.0;
 void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
 temperature_adc_value = HAL_ADC_GetValue(hadc);
 temperature_in_c = ((TEMP_VSENSE * temperature_adc_value - TEMP_V25) / TEMP_AVG_SLOPE) + 25;
 HAL_ADC_Start_IT(&hadc1);
 /* USER CODE END 0 */
 * @brief  The application entry point.
 * @retval int
 int main(void)
 /* USER CODE BEGIN 1 */
 char *dataPtr = NULL;
 unsigned char           wifi_flag = 0;
 char                                  ipaddr[16];
 char                                  gateway[16];
 uint32_t                          latest_time = 0;
 int                                  rv = -1;
 /* USER CODE END 1 */
 /* MCU Configuration--------------------------------------------------------*/
 /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 MX_UART5_Init();
 MX_USART1_UART_Init();
 MX_ADC1_Init();
 /* USER CODE BEGIN 2 */
 printf("很高兴使用STM32U385RG开发板********\r\n");
 printf("串口输出打印 波特率115200\r\n\r\n");
 #if 1
 printf("\r\nESP8266城市天气预报 \r\n\r\n");
 ESP8266_Init();
 printf("INFO:Enable  ESP8266_Init successfully ==================初始化完成\r\n");
 while(ESP8266_SendCmd("AT+CIPSTART=\"TCP\",\"api.seniverse.com\",80\r\n", "CONNECT\r\n"));
 //while(ESP8266_SendCmd("AT+CIPSTART=\"TCP\",\"api.openweathermap.org\",80\r\n", "OK"));
 while(ESP8266_SendCmd("AT+CIPMODE=1\r\n", "OK"));
 ESP8266_SendData(TX_Data,strlen(TX_Data));
 HAL_Delay(500);
 printf("%d\r\n",esp8266_cnt);
 printf("%d\r\n",strlen(esp8266_buf));
 printf("原始天气数据\r\n");
 printf("*****************************************************************************\r\n");
 printf("%s\r\n",esp8266_buf);
 //***********************************JSON解析数据
 cJSON *json;
 cJSON *Array_obj1;
 cJSON *Array_obj2;
 cJSON *Array_obj3;
 cJSON *Array_obj4;
 cJSON *Array_obj5;
 cJSON *Array_obj6;
 cJSON *Array_obj7;
 cJSON *Array_obj8;
 cJSON *Array;
 json = cJSON_Parse((const char *) esp8266_buf );
 Array_obj1=cJSON_GetObjectItem(json,"results");
 int size=cJSON_GetArraySize(Array_obj1);
 //printf("\n%d",size);
 printf("\r\nCJSON解析后的数据\r\n");
 printf("=============================================================================\r\n");
 if(json == NULL)
 printf("\njson fmt error:%s\n.", cJSON_GetErrorPtr());
 else
 Array=cJSON_GetArrayItem(Array_obj1,0);
 Array_obj2=cJSON_GetObjectItem(Array,"now");
 Array_obj3=cJSON_GetObjectItem(Array_obj2,"code");
 Array_obj4=cJSON_GetObjectItem(Array_obj2,"temperature");
 Array_obj5=cJSON_GetObjectItem(Array_obj2,"text");
 Array_obj6=cJSON_GetObjectItem(Array,"location");
 Array_obj7=cJSON_GetObjectItem(Array_obj6,"name");
 Array_obj8=cJSON_GetObjectItem(Array,"last_update");
 printf("城市: %s         ",Array_obj7->valuestring);
 printf("天气: %s         ",Array_obj5->valuestring);
 //printf("\r\n%s\r\n",Array_obj3->valuestring);                                 //天气代码
 printf("气温: %s度          ",Array_obj4->valuestring);                                //气温
 printf("时间: %s\r\n",Array_obj8->valuestring);
 cJSON_Delete(json);//释放json
 ESP8266_Send("+++");
 #endif
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
 /* USER CODE END WHILE */
 /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
 * @brief System Clock Configuration
 * @retval None
 RCC_OscInitTypeDef RCC_OscInitStruct = {0};
 RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
 /** Enable Epod Booster
 if (HAL_RCCEx_EpodBoosterClkConfig(RCC_EPODBOOSTER_SOURCE_MSIS, RCC_EPODBOOSTER_DIV1) != HAL_OK)
 Error_Handler();
 if (HAL_PWREx_EnableEpodBooster() != HAL_OK)
 Error_Handler();
 /** Configure the main internal regulator output voltage
 if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
 Error_Handler();
 /** Set Flash latency before increasing MSIS
 __HAL_FLASH_SET_LATENCY(FLASH_LATENCY_2);
 /** Initializes the CPU, AHB and APB buses clocks
 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSIS;
 RCC_OscInitStruct.MSISState = RCC_MSI_ON;
 RCC_OscInitStruct.MSISSource = RCC_MSI_RC0;
 RCC_OscInitStruct.MSISDiv = RCC_MSI_DIV1;
 if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
 Error_Handler();
 RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
 |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
 |RCC_CLOCKTYPE_PCLK3;
 RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSIS;
 RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
 RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
 RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
 RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN 4 */
 /* USER CODE END 4 */
 * @brief  This function is executed in case of error occurrence.
 * @retval None
 void Error_Handler(void)
 /* USER CODE BEGIN Error_Handler_Debug */
 /* User can add his own implementation to report the HAL error return state */
 __disable_irq();
 while (1)
 /* USER CODE END Error_Handler_Debug */
 #ifdef USE_FULL_ASSERT
 * @brief  Reports the name of the source file and the source line number
 *         where the assert_param error has occurred.
 * @param  file: pointer to the source file name
 * @param  line: assert_param error line source number
 * @retval None
 void assert_failed(uint8_t *file, uint32_t line)
 /* USER CODE BEGIN 6 */
 /* User can add his own implementation to report the file name and line number,
 ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
 /* USER CODE END 6 */
 #endif /* USE_FULL_ASSERT */
 默认修改城市为广州
 char TX_Data[]="GET https://api.seniverse.com/v3/weather/now.json?key=SfobYEEioM5L6dRce&location=guangzhou&language=zh-Hans&unit=c\r\n";
 编译代码,烧录到STM32U385RG板子,
 打开串口调试助手,查看打印数据
   {"results":[{"location":{"id":"WS0E9D8WN298","name":"广州","country":"CN","path":"广州,广州,广东,中国","timezone":"Asia/Shanghai","timezone_offset":"+08:00"},"now":{"text":"晴","code":"0","temperature":"32"},"last_update":"2025-07-25T10:02:17+08:00"}]}
 打开手机,查看广州天气预报
   可以看到气温非常的准确
 下面再来换一个城市,选择北京,
 char TX_Data[]="GET https://api.seniverse.com/v3/weather/now.json?key=SfobYEEioM5L6dRce&location=beijing&language=zh-Hans&unit=c\r\n";
 烧录到板子,查看串口助手
   {"results":[{"location":{"id":"WX4FBXXFKE4F","name":"北京","country":"CN","path":"北京,北京,中国","timezone":"Asia/Shanghai","timezone_offset":"+08:00"},"now":{"text":"小雨","code":"13","temperature":"25"},"last_update":"2025-07-25T10:07:29+08:00"}]}
 打开手机,查看北京天气预报
