[STM32U3] STM32U385RG 测评】+通过IIC驱动OLED显示中英文
743|0
 楼主| LiuDW091 发表于 2025-8-5 22:10 | 显示全部楼层 |阅读模式
#申请原创# #有奖活动# #申请开发板#@21小跑堂
本次实验通过IIC驱动OLED屏,显示中英文字符。
使用的是1.3寸的OLED。
一、首先通原理图、数据手册,找到IIC接口的SDA、SCL
二、IDE软件配置
RCC配置
IIC配置
debug配置
三、代码调试
添加OLED的代码
oled.c代码
#include "oled.h"
#include "i2c.h"
#include "oledfont.h"
#include "stm32u3xx_hal.h"
void WriteCmd(unsigned char I2C_Command)//写命令
   HAL_I2C_Mem_Write(&hi2c2,OLED0561_ADD,COM,I2C_MEMADD_SIZE_8BIT,&I2C_Command,1,100);
void WriteDat(unsigned char I2C_Data)//写数据
    HAL_I2C_Mem_Write(&hi2c2,OLED0561_ADD,DAT,I2C_MEMADD_SIZE_8BIT,&I2C_Data,1,100);
void OLED_Init(void)
        HAL_Delay(100); //这里的延时很重要
        WriteCmd(0xAE); //display off
        WriteCmd(0x20);        //Set Memory Addressing Mode
        WriteCmd(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
        WriteCmd(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
        WriteCmd(0xc8);        //Set COM Output Scan Direction
        WriteCmd(0x00); //---set low column address
        WriteCmd(0x10); //---set high column address
        WriteCmd(0x40); //--set start line address
        WriteCmd(0x81); //--set contrast control register
        WriteCmd(0xff); //亮度调节 0x00~0xff
        WriteCmd(0xa1); //--set segment re-map 0 to 127
        WriteCmd(0xa6); //--set normal display
        WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
        WriteCmd(0x3F); //
        WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
        WriteCmd(0xd3); //-set display offset
        WriteCmd(0x00); //-not offset
        WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
        WriteCmd(0xf0); //--set divide ratio
        WriteCmd(0xd9); //--set pre-charge period
        WriteCmd(0x22); //
        WriteCmd(0xda); //--set com pins hardware configuration
        WriteCmd(0x12);
        WriteCmd(0xdb); //--set vcomh
        WriteCmd(0x20); //0x20,0.77xVcc
        WriteCmd(0x8d); //--set DC-DC enable
        WriteCmd(0x14); //
        WriteCmd(0xaf); //--turn on oled panel
void OLED_SetPos(unsigned char x, unsigned char y) //设置起始点坐标
        WriteCmd(0xb0+y);
        WriteCmd(((x&0xf0)>>4)|0x10);
        WriteCmd((x&0x0f)|0x01);
void OLED_Fill(unsigned char fill_Data)//全屏填充
        unsigned char m,n;
        for(m=0;m<8;m++)
                WriteCmd(0xb0+m);                //page0-page1
                WriteCmd(0x00);                //low column start address
                WriteCmd(0x10);                //high column start address
                for(n=0;n<128;n++)
                                WriteDat(fill_Data);
void OLED_CLS(void)//清屏
        OLED_Fill(0x00);
void OLED_ON(void)
        WriteCmd(0X8D);  //设置电荷泵
        WriteCmd(0X14);  //开启电荷泵
        WriteCmd(0XAF);  //OLED唤醒
void OLED_OFF(void)
        WriteCmd(0X10);  //关闭电荷泵
        WriteCmd(0XAE);  //OLED休眠
// Parameters     : x,y -- 起始点坐标(x:0~127, y:0~7); ch[] -- 要显示的字符串; TextSize -- 字符大小(1:6*8 ; 2:8*16)
// Description    : 显示codetab.h中的ASCII字符,有6*8和8*16可选择
void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
        unsigned char c = 0,i = 0,j = 0;
        switch(TextSize)
                case 1:
                        while(ch[j] != '\0')
                                c = ch[j] - 32;
                                if(x > 126)
                                        x = 0;
                                        y++;
                                OLED_SetPos(x,y);
                                for(i=0;i<6;i++)
                                        WriteDat(F6x8[c]);
                                x += 6;
                                j++;
                }break;
                case 2:
                                c = ch[j] - 32;
                                if(x > 120)
                                        x = 0;
                                        y++;
                                OLED_SetPos(x,y);
                                for(i=0;i<8;i++)
                                        WriteDat(F8X16[c*16+i]);
                                OLED_SetPos(x,y+1);
                                for(i=0;i<8;i++)
                                        WriteDat(F8X16[c*16+i+8]);
                                x += 8;
                                j++;
                }break;
// Parameters     : x,y -- 起始点坐标(x:0~127, y:0~7); N:汉字在.h中的索引
// Description    : 显示ASCII_8x16.h中的汉字,16*16点阵
void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N)
        unsigned char wm=0;
        unsigned int  adder=32*N;
        OLED_SetPos(x , y);
        for(wm = 0;wm < 16;wm++)
                WriteDat(F16x16[adder]);
                adder += 1;
        OLED_SetPos(x,y + 1);
                adder += 1;
// Parameters     : x0,y0 -- 起始点坐标(x0:0~127, y0:0~7); x1,y1 -- 起点对角线(结束点)的坐标(x1:1~128,y1:1~8)
// Description    : 显示BMP位图
void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[])
        unsigned int j=0;
        unsigned char x,y;
  if(y1%8==0)
                y = y1/8;
  else
                y = y1/8 + 1;
        for(y=y0;y<y1;y++)
                OLED_SetPos(x0,y);
    for(x=x0;x<x1;x++)
                        WriteDat(BMP[j++]);
void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size)
        unsigned char c=0,i=0;
                c=chr-' ';//得到偏移后的值
                if(x>128-1){x=0;y=y+2;}
                if(Char_Size ==16)
                        OLED_SetPos(x,y);
                        for(i=0;i<8;i++)
                        OLED_SetPos(x,y+1);
                        for(i=0;i<8;i++)
                        else {
                                OLED_SetPos(x,y);
                                for(i=0;i<6;i++)
                                WriteDat(F6x8[c]);
u32 oled_pow(u8 m,u8 n)
        u32 result=1;
        while(n--)result*=m;
        return result;
//显示2个数字
//x,y :起点坐标
//len :数字的位数
//size:字体大小
//mode:模式        0,填充模式;1,叠加模式
//num:数值(0~4294967295);
void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2)
        u8 t,temp;
        u8 enshow=0;
        for(t=0;t<len;t++)
                temp=(num/oled_pow(10,len-t-1))%10;
                if(enshow==0&&t<(len-1))
                        if(temp==0)
                                OLED_ShowChar(x+(size2/2)*t,y,' ',size2);
                                continue;
                        }else enshow=1;
                 OLED_ShowChar(x+(size2/2)*t,y,temp+'0',size2);
oled.h代码
#ifndef __OLED_H
#define __OLED_H
#include "i2c.h"
#define u8 uint8_t
#define u32 uint32_t
#define OLED0561_ADD        0x78  // OLED的I2C地址(禁止修改)
#define COM                                0x00  // OLED 指令(禁止修改)
#define DAT                         0x40  // OLED 数据(禁止修改)
void WriteCmd(unsigned char I2C_Command);//写命令
void WriteDat(unsigned char I2C_Data);//写数据
void OLED_Init(void);//初始化
void OLED_SetPos(unsigned char x, unsigned char y);
void OLED_Fill(unsigned char fill_Data);//全屏填充
void OLED_CLS(void);
void OLED_ON(void);
void OLED_OFF(void);
void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize);//显示字符串
void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N);//显示汉字
void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[]);//显示图片
void OLED_ShowChar(u8 x,u8 y,u8 chr,u8 Char_Size);
u32 oled_pow(u8 m,u8 n);
void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2);//size2(16|12)
#endif
字模代码oledfont.h
    #ifndef __OLEDFONT_H
    #define __OLEDFONT_H
    // ------------------  ASCII字模的数据表 ------------------------ //
    // 码表从0x20~0x7e                                                //
    // 字库:  纵向取模下高位// (调用时要减512)
            unsigned char F16x16[] =
        0x04,0x24,0x44,0x84,0x64,0x9C,0x40,0x30,0x0F,0xC8,0x08,0x08,0x28,0x18,0x00,0x00,
        0x10,0x08,0x06,0x01,0x82,0x4C,0x20,0x18,0x06,0x01,0x06,0x18,0x20,0x40,0x80,0x00,/*"欢",0*/
        0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x04,0x02,0x00,0xFC,0x04,0x04,0xFC,0x00,0x00,
        0x00,0x40,0x20,0x1F,0x20,0x40,0x4F,0x44,0x42,0x40,0x7F,0x42,0x44,0x43,0x40,0x00,//迎1
        0x40,0x40,0x42,0x44,0x58,0xC0,0x40,0x7F,0x40,0xC0,0x50,0x48,0x46,0x40,0x40,0x00,
        0x80,0x80,0x40,0x20,0x18,0x07,0x00,0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x78,0x00,/*"光",2*/
        0x00,0xF8,0x00,0x00,0xFF,0x40,0x20,0x18,0x0F,0x18,0x68,0x08,0x08,0x08,0x08,0x00,
        0x00,0x1F,0x00,0x00,0xFF,0x00,0x00,0x7F,0x21,0x21,0x3F,0x21,0x21,0x7F,0x00,0x00,/*"临",3*/
        0x40,0x40,0x42,0xCC,0x00,0x40,0x20,0x90,0x0C,0x03,0x0C,0x90,0x20,0x40,0x40,0x00,
        0x00,0x00,0x00,0x7F,0x20,0x10,0x00,0x3F,0x44,0x42,0x41,0x40,0x40,0x70,0x00,0x00,/*论",4*/
        0x20,0x20,0x20,0xFF,0x20,0x20,0x40,0x44,0x44,0x44,0xC4,0x44,0x44,0x44,0x40,0x00,
        0x10,0x30,0x10,0x0F,0x08,0x08,0x20,0x70,0x28,0x26,0x21,0x20,0x28,0x30,0x60,0x00,/*"坛",5*/
    /************************************6*8的点阵************************************/
    const unsigned char F6x8[][6] =
            0x00, 0x00, 0x00, 0x00, 0x00, 0x00,// sp
            0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,// !
            0x00, 0x00, 0x07, 0x00, 0x07, 0x00,// "
            0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14,// #
            0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12,// $
            0x00, 0x62, 0x64, 0x08, 0x13, 0x23,// %
            0x00, 0x36, 0x49, 0x55, 0x22, 0x50,// &
            0x00, 0x00, 0x05, 0x03, 0x00, 0x00,// '
            0x00, 0x00, 0x1c, 0x22, 0x41, 0x00,// (
            0x00, 0x00, 0x41, 0x22, 0x1c, 0x00,// )
            0x00, 0x14, 0x08, 0x3E, 0x08, 0x14,// *
            0x00, 0x08, 0x08, 0x3E, 0x08, 0x08,// +
            0x00, 0x00, 0x00, 0xA0, 0x60, 0x00,// ,
            0x00, 0x08, 0x08, 0x08, 0x08, 0x08,// -
            0x00, 0x00, 0x60, 0x60, 0x00, 0x00,// .
            0x00, 0x20, 0x10, 0x08, 0x04, 0x02,// /
            0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E,// 0
            0x00, 0x00, 0x42, 0x7F, 0x40, 0x00,// 1
            0x00, 0x42, 0x61, 0x51, 0x49, 0x46,// 2
            0x00, 0x21, 0x41, 0x45, 0x4B, 0x31,// 3
            0x00, 0x18, 0x14, 0x12, 0x7F, 0x10,// 4
            0x00, 0x27, 0x45, 0x45, 0x45, 0x39,// 5
            0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30,// 6
            0x00, 0x01, 0x71, 0x09, 0x05, 0x03,// 7
            0x00, 0x36, 0x49, 0x49, 0x49, 0x36,// 8
            0x00, 0x06, 0x49, 0x49, 0x29, 0x1E,// 9
            0x00, 0x00, 0x36, 0x36, 0x00, 0x00,// :
            0x00, 0x00, 0x56, 0x36, 0x00, 0x00,// ;
            0x00, 0x08, 0x14, 0x22, 0x41, 0x00,// <
            0x00, 0x14, 0x14, 0x14, 0x14, 0x14,// =
            0x00, 0x00, 0x41, 0x22, 0x14, 0x08,// >
            0x00, 0x02, 0x01, 0x51, 0x09, 0x06,// ?
            0x00, 0x32, 0x49, 0x59, 0x51, 0x3E,// @
            0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C,// A
            0x00, 0x7F, 0x49, 0x49, 0x49, 0x36,// B
            0x00, 0x3E, 0x41, 0x41, 0x41, 0x22,// C
            0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C,// D
            0x00, 0x7F, 0x49, 0x49, 0x49, 0x41,// E
            0x00, 0x7F, 0x09, 0x09, 0x09, 0x01,// F
            0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A,// G
            0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F,// H
            0x00, 0x00, 0x41, 0x7F, 0x41, 0x00,// I
            0x00, 0x20, 0x40, 0x41, 0x3F, 0x01,// J
            0x00, 0x7F, 0x08, 0x14, 0x22, 0x41,// K
            0x00, 0x7F, 0x40, 0x40, 0x40, 0x40,// L
            0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F,// M
            0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F,// N
            0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E,// O
            0x00, 0x7F, 0x09, 0x09, 0x09, 0x06,// P
            0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E,// Q
            0x00, 0x7F, 0x09, 0x19, 0x29, 0x46,// R
            0x00, 0x46, 0x49, 0x49, 0x49, 0x31,// S
            0x00, 0x01, 0x01, 0x7F, 0x01, 0x01,// T
            0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F,// U
            0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F,// V
            0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F,// W
            0x00, 0x63, 0x14, 0x08, 0x14, 0x63,// X
            0x00, 0x07, 0x08, 0x70, 0x08, 0x07,// Y
            0x00, 0x61, 0x51, 0x49, 0x45, 0x43,// Z
            0x00, 0x00, 0x7F, 0x41, 0x41, 0x00,// [
            0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55,// 55
            0x00, 0x00, 0x41, 0x41, 0x7F, 0x00,
            0x00, 0x04, 0x02, 0x01, 0x02, 0x04,// ^
            0x00, 0x40, 0x40, 0x40, 0x40, 0x40,// _
            0x00, 0x00, 0x01, 0x02, 0x04, 0x00,// '
            0x00, 0x20, 0x54, 0x54, 0x54, 0x78,// a
            0x00, 0x7F, 0x48, 0x44, 0x44, 0x38,// b
            0x00, 0x38, 0x44, 0x44, 0x44, 0x20,// c
            0x00, 0x38, 0x44, 0x44, 0x48, 0x7F,// d
            0x00, 0x38, 0x54, 0x54, 0x54, 0x18,// e
            0x00, 0x08, 0x7E, 0x09, 0x01, 0x02,// f
            0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,// g
            0x00, 0x7F, 0x08, 0x04, 0x04, 0x78,// h
            0x00, 0x00, 0x44, 0x7D, 0x40, 0x00,// i
            0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,// j
            0x00, 0x7F, 0x10, 0x28, 0x44, 0x00,// k
            0x00, 0x00, 0x41, 0x7F, 0x40, 0x00,// l
            0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,// m
            0x00, 0x7C, 0x08, 0x04, 0x04, 0x78,// n
            0x00, 0x38, 0x44, 0x44, 0x44, 0x38,// o
            0x00, 0xFC, 0x24, 0x24, 0x24, 0x18,// p
            0x00, 0x18, 0x24, 0x24, 0x18, 0xFC,// q
            0x00, 0x7C, 0x08, 0x04, 0x04, 0x08,// r
            0x00, 0x48, 0x54, 0x54, 0x54, 0x20,// s
            0x00, 0x04, 0x3F, 0x44, 0x40, 0x20,// t
            0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C,// u
            0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C,// v
            0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C,// w
            0x00, 0x44, 0x28, 0x10, 0x28, 0x44,// x
            0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,// y
            0x00, 0x44, 0x64, 0x54, 0x4C, 0x44,// z
            0x14, 0x14, 0x14, 0x14, 0x14, 0x14,// horiz lines
    /****************************************8*16的点阵************************************/
    const unsigned char F8X16[]=
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 0
      0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00,//! 1
      0x00,0x10,0x0C,0x06,0x10,0x0C,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" 2
      0x40,0xC0,0x78,0x40,0xC0,0x78,0x40,0x00,0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00,//# 3
      0x00,0x70,0x88,0xFC,0x08,0x30,0x00,0x00,0x00,0x18,0x20,0xFF,0x21,0x1E,0x00,0x00,//$ 4
      0xF0,0x08,0xF0,0x00,0xE0,0x18,0x00,0x00,0x00,0x21,0x1C,0x03,0x1E,0x21,0x1E,0x00,//% 5
      0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,0x1E,0x21,0x23,0x24,0x19,0x27,0x21,0x10,//& 6
      0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//' 7
      0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x00,0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x00,//( 8
      0x00,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x40,0x20,0x18,0x07,0x00,0x00,0x00,//) 9
      0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00,//* 10
      0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00,//+ 11
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00,//, 12
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,//- 13
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//. 14
      0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00,/// 15
      0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//0 16
      0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//1 17
      0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//2 18
      0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//3 19
      0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//4 20
      0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//5 21
      0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//6 22
      0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//7 23
      0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//8 24
      0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//9 25
      0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//: 26
      0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00,//; 27
      0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00,//< 28
      0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00,//= 29
      0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00,//> 30
      0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00,//? 31
      0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,0x07,0x18,0x27,0x24,0x23,0x14,0x0B,0x00,//@ 32
      0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,//A 33
      0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,//B 34
      0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00,//C 35
      0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//D 36
      0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,//E 37
      0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00,//F 38
      0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00,//G 39
      0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//H 40
      0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//I 41
      0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00,//J 42
      0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00,//K 43
      0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00,//L 44
      0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00,//M 45
      0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//N 46
      0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,//O 47
      0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00,//P 48
      0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00,//Q 49
      0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//R 50
      0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//S 51
      0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//T 52
      0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//U 53
      0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//V 54
      0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00,//W 55
      0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20,//X 56
      0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//Y 57
      0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00,//Z 58
      0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00,//[ 59
      0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00,//\ 60
      0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00,//] 61
      0x00,0x00,0x04,0x02,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//^ 62
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,//_ 63
      0x00,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//` 64
      0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,//a 65
      0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00,//b 66
      0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00,//c 67
      0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20,//d 68
      0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,//e 69
      0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//f 70
      0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,//g 71
      0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//h 72
      0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//i 73
      0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,//j 74
      0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00,//k 75
      0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//l 76
      0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,//m 77
      0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,//n 78
      0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00,//o 79
      0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00,//p 80
      0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80,//q 81
      0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,//r 82
      0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00,//s 83
      0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,//t 84
      0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20,//u 85
      0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00,//v 86
      0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00,//w 87
      0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00,//x 88
      0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00,//y 89
      0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00,//z 90
      0x00,0x00,0x00,0x00,0x80,0x7C,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x3F,0x40,0x40,//{ 91
      0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,//| 92
      0x00,0x02,0x02,0x7C,0x80,0x00,0x00,0x00,0x00,0x40,0x40,0x3F,0x00,0x00,0x00,0x00,//} 93
      0x00,0x06,0x01,0x01,0x02,0x02,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//~ 94
    unsigned char BMP1[] =
            0x00,0x03,0x05,0x09,0x11,0xFF,0x11,0x89,0x05,0xC3,0x00,0xE0,0x00,0xF0,0x00,0xF8,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x28,0xFF,0x11,0xAA,0x44,0x00,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x83,0x01,0x38,0x44,0x82,0x92,
            0x92,0x74,0x01,0x83,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x44,0xC7,0x01,0x7D,
            0x7D,0x7D,0x7D,0x01,0x7D,0x7D,0x7D,0x7D,0x01,0x7D,0x7D,0x7D,0x7D,0x01,0xFF,0x00,
            0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,
            0x00,0x00,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,
            0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x40,0x40,0x00,0x00,
            0x6D,0x6D,0x6D,0x6D,0x6D,0x00,0x00,0x60,0x60,0x60,0x60,0x60,0x00,0x00,0x40,0x40,
            0x40,0x40,0x40,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xDB,0xDB,0xDB,0xDB,0xDB,0x00,0x00,
            0xDB,0xDB,0xDB,0xDB,0xDB,0x00,0x00,0xDB,0xDB,0xDB,0xDB,0xDB,0x00,0x00,0xDB,0xDB,
            0xDB,0xDB,0xDB,0x00,0x00,0xDA,0xDA,0xDA,0xDA,0xDA,0x00,0x00,0xD8,0xD8,0xD8,0xD8,
            0xD8,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,
            0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,0x00,0x80,
            0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x00,0x00,
            0x06,0x06,0x06,0x06,0x06,0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x00,0x00,0x06,0x06,
            0x06,0x06,0x06,0x00,0x00,0x06,0x06,0x06,0xE6,0x66,0x20,0x00,0x06,0x06,0x86,0x06,
            0x06,0x00,0x00,0x06,0x06,0x06,0x06,0x86,0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x00,
            0x00,0x86,0x86,0x86,0x86,0x86,0x80,0x80,0x86,0x86,0x06,0x86,0x86,0xC0,0xC0,0x86,
            0x86,0x86,0x06,0x06,0xD0,0x30,0x76,0x06,0x06,0x06,0x06,0x00,0x00,0x06,0x06,0x06,
            0x06,0x06,0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x00,0x00,0x06,0x06,0x06,0x06,0x06,
            0x00,0x00,0x06,0x06,0x06,0x06,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x1C,0x00,0xFE,0x00,0x01,
            0x02,0x00,0xC4,0x18,0x20,0x02,0x9E,0x63,0xB2,0x0E,0x00,0xFF,0x81,0x81,0xFF,0x00,
            0x00,0x80,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0xFF,0x00,0x23,0xEA,0xAA,0xBF,0xAA,
            0xEA,0x03,0x3F,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
            0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x0C,0x08,0x00,0x00,0x01,0x01,0x01,
            0x01,0x01,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x01,0x00,0x81,0x80,0x80,0x81,0x80,
            0x81,0x80,0x80,0x80,0x80,0x01,0x01,0x01,0x01,0x00,0x00,0x00,0x01,0x00,0x00,0x00,
            0x01,0x00,0x01,0x01,0x09,0x0C,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,
            0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0xC0,0x00,
            0x00,0x1E,0x21,0x40,0x40,0x50,0x21,0x5E,0x00,0x1E,0x21,0x40,0x40,0x50,0x21,0x5E,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xC1,0xC1,0xFF,
            0xFF,0xC1,0xC1,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
            0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x80,0xFC,0xF3,0xEF,0xF3,0xFC,
            0x80,0xFF,0x80,0xEE,0xEE,0xEE,0xF5,0xFB,0xFF,0x9C,0xBE,0xB6,0xB6,0x88,0xFF,0x00,
    #endif
主函数main.c
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2025 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "i2c.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "oled.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_I2C2_Init();
  /* USER CODE BEGIN 2 */
   OLED_Init();
   OLED_CLS();
   OLED_ShowCN(8,0,0);
   OLED_ShowCN(24,0,1);
   OLED_ShowCN(40,0,2);
   OLED_ShowCN(56,0,3);
   OLED_ShowStr(5,2,"21IC",2);
   OLED_ShowCN(40,10,4);
   OLED_ShowCN(56,10,5);
        OLED_ON();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE2) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSIS;
  RCC_OscInitStruct.MSISState = RCC_MSI_ON;
  RCC_OscInitStruct.MSISSource = RCC_MSI_RC0;
  RCC_OscInitStruct.MSISDiv = RCC_MSI_DIV8;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_PCLK3;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSIS;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
四、实验效果
视频:
代码:
Src.zip (17.87 KB, 下载次数: 0)
