我也出现类似的问题,只要加上一句:TIM2_ClearFlag(TIM2_FLAG_UPDATE);//清除中断标志就会出现如下的错误提示,无法编译
Running Linker
clnk -m Debug\aaaa.map -l"C:\Documents and Settings\Administrator\桌面\多定时器\驱动" -o Debug\aaaa.sm8 Debug\aaaa.lkf
#error clnk Debug\aaaa.lkf:1 Program too large for LIMITED version The command: "clnk -m Debug\aaaa.map -l"C:\Documents and Settings\Administrator\桌面\多定时器\驱动" -o Debug\aaaa.sm8 Debug\aaaa.lkf " has failed, the returned value is: 1
exit code=1.
aaaa.elf - 2 error(s), 0 warning(s)
