找到原因了:
setup_memory_map()
GEL_MapOn();
GEL_MapReset();
/* On-chip memory map */
GEL_MapAdd(0x00000000,0,0x00040000,1,1); /* Internal RAM (L2) mem */
GEL_MapAdd(0x01800000,0,0x00000024,1,1); /* EMIF control regs */
GEL_MapAdd(0x01840000,0,0x00000004,1,1); /* Cache configuration reg */
GEL_MapAdd(0x01844000,0,0x00000020,1,1); /* L2 base addr & count regs*/
GEL_MapAdd(0x01844020,0,0x00000020,1,1); /* L1 base addr & count regs*/
GEL_MapAdd(0x01845000,0,0x00000008,1,1); /* L2 flush & clean regs */
GEL_MapAdd(0x01848200,0,0x00000010,1,1); /* CE0 mem attribute regs */
GEL_MapAdd(0x01848240,0,0x00000010,1,1); /* CE1 mem attribute regs */
GEL_MapAdd(0x01848280,0,0x00000010,1,1); /* CE2 mem attribute regs */
GEL_MapAdd(0x018482c0,0,0x00000010,1,1); /* CE3 mem attribute regs */
GEL_MapAdd(0x01880000,0,0x00000004,1,1); /* HPI control reg */
GEL_MapAdd(0x018c0000,0,0x00000028,1,1); /* McBSP0 regs */
GEL_MapAdd(0x01900000,0,0x00000028,1,1); /* McBSP1 regs */
GEL_MapAdd(0x01940000,0,0x0000000c,1,1); /* Timer0 regs */
GEL_MapAdd(0x01980000,0,0x0000000c,1,1); /* Timer1 regs */
GEL_MapAdd(0x019c0000,0,0x0000000c,1,1); /* Interrupt selector regs */
GEL_MapAdd(0x019c0200,0,0x00000004,1,1); /* Device configuration */
GEL中setup_memory_map()的第一行即“ GEL_MapAdd(0x00000000,0,0x00040000,1,1); /* Internal RAM (L2) mem */”我设置错了,以前0x00040000设置成了0x00030000。
贴出来,希望大家不要犯我这样的错了哈
