[STM32F1] 各位帮忙看一下这段串口通信程序!!用的是USART3
1798|1
 楼主| ljhya 发表于 2013-12-7 18:01 | 显示全部楼层 |阅读模式
请问一下这个程序,用USART3的传送数据有没有问题???
volatile u8 USART_Received_Flag=0;
u8 USART_RX_BUF[64];     //接收缓冲,最大64个字节.
//接收状态
//bit7,接收完成标志
//bit6,接收到0x0d
//bit5~0,接收到的有效字节数目
u8 USART_RX_STA=0;       //接收状态标记
void uart_init(u32 bound){
    //GPIO端口设置
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE); //使能UART3所在GPIOB的时钟
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE); //串口时钟配置
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOB,   &GPIO_InitStructure);
      // Configure USART3 Rx (PB.11) as input floating
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_11;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
   //Usart1 NVIC 配置
    NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器USART3
   //USART 初始化设置
        USART_InitStructure.USART_BaudRate = bound;//一般设置为9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART3, &USART_InitStructure);
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);//开启中断
    USART_Cmd(USART3, ENABLE);                    //使能串口
void USART3_SendBytes(u8 * str,u32 DataLen)         //传送一组字符
    while(DataLen)
                delay_us(10);
        USART_SendData(USART3, *str++);
        while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET);
                DataLen--;
void USART3_IRQHandler(void)                        //串口3中断服务程序
        u8 Res;
        if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)  //接收中断(接收到的数据必须是0x0d 0x0a结尾)
                Res =USART_ReceiveData(USART3);//(USART3->DR);        //读取接收到的数据
                USART_RX_BUF[USART_RX_STA]=Res ;
                USART_RX_STA++;
                if(USART_RX_STA>63)
                        USART_RX_STA=0;//接收数据错误,重新开始接收
                      USART_Received_Flag=1;
mmuuss586 发表于 2014-4-21 09:36 | 显示全部楼层
啥问题呢?
