[8/16-bit MCU] MC9S12HY32 的DFLASH的一个扇区是多少?
2503|5
 楼主| win2000_li 发表于 2014-4-17 08:41 | 显示全部楼层 |阅读模式
MC9S12G是4个!
FSL_TICS_ZJJ 发表于 2014-4-17 09:33 | 显示全部楼层
你好,根据MC9S12HY/HA Reference Manual文档:http://cache.freescale.com/files ... df?fromsite=zh-Hans
第514页, 15.1.1可以知道一个扇区也是4个字节。
 楼主| win2000_li 发表于 2014-4-18 13:10 | 显示全部楼层
谢谢您的回复,我按您的提示查看了手册,发现是这样描述的:
15.1.1 Glossary
Command Write Sequence — An MCU instruction sequence to execute built-in algorithms (including
program and erase) on the Flash memory.
D-Flash Memory — The D-Flash memory constitutes the nonvolatile memory store for data.
D-Flash Sector—The D-Flash sector is the smallest portion of the D-Flash memory that can be erased.
The D-Flash sector consists of four 64 byte rows for a total of 256 bytes.
NVMCommand Mode—AnNVMmode using the CPU to setup the FCCOB register to pass parameters
required for Flash command execution.
Phrase — An aligned group of four 16-bit words within the P-Flash memory. Each phrase includes two
sets of aligned double words with each set including 7 ECC bits for single bit fault correction and double
bit fault detection within each double word.
P-Flash Memory—The P-Flash memory constitutes the main nonvolatile memory store for applications.
P-Flash Sector — The P-Flash sector is the smallest portion of the P-Flash memory that can be erased.
Each P-Flash sector contains 512 bytes.
Program IFR — Nonvolatile information register located in the P-Flash block that contains the Device
ID, Version ID, and the Program Once field.
FSL_TICS_ZJJ 发表于 2014-4-18 15:08 | 显示全部楼层
那么你还有问题吗?
 楼主| win2000_li 发表于 2014-4-18 15:12 | 显示全部楼层
谢谢您的支持!
FSL_TICS_ZJJ 发表于 2014-4-18 15:15 | 显示全部楼层
谢谢您的支持!
不客气,以后有问题就直接发帖问,我不是8位的工程师,但是也会尽力帮你找答案。
