SDK:L2.6.35_1.1.0_130130_source.gz
ubuntu 9.04
按照文档说明一步一步来操作的,还是报如下的错,请问是什么原因呢?
/bin/sh ./mkinstalldirs /mnt/shared/IMX28/new/ltib/tmp/rpm-fs/opt/freescale/ltib/usr/bin
/bin/sh ./libtool --mode=install /usr/bin/install -c rpm /mnt/shared/IMX28/new/ltib/tmp/rpm-fs/opt/freescale/ltib/usr/bin/rpm
mkdir /mnt/shared/IMX28/new/ltib/tmp/rpm-fs/opt/freescale/ltib/var
mkdir /mnt/shared/IMX28/new/ltib/tmp/rpm-fs/opt/freescale/ltib/var/lib
mkdir /mnt/shared/IMX28/new/ltib/tmp/rpm-fs/opt/freescale/ltib/var/lib/rpm
ln: creating symbolic link `/mnt/shared/IMX28/new/ltib/tmp/rpm-fs/opt/freescale/ltib/usr/lib/rpmrc': Read-only file system
make[2]: *** [install-data-local] Error 1
make[2]: Leaving directory `/tmp/rpm-phenix/BUILD/rpm-4.0.4'
make[1]: *** [install-am] Error 2
make[1]: Leaving directory `/tmp/rpm-phenix/BUILD/rpm-4.0.4'
make: *** [install-recursive] Error 1
error: Bad exit status from /mnt/shared/IMX28/new/ltib/tmp/rpm-tmp.70346 (%install)
RPM build errors:
Build time for rpm-fs: 230 seconds
Failed building rpm-fs
could not glob rpm in: /tmp/rpm-phenix/RPMS/i686/rpm-fs-* at ./ltib line 2427.
traceback:
main::check_rpm_setup:2427
main::host_checks:1435
main:554
Started: Sat May 3 11:41:37 2014
Ended: Sat May 3 11:45:31 2014
Elapsed: 234 seconds
These packages failed to build:
rpm-fs
Build Failed
