[i.MX] iMX6Q SD开发板nfs挂载文件系统问题,请版主解答一下
2520|6
 楼主| ffbiao 发表于 2014-7-2 17:26 | 显示全部楼层 |阅读模式
egulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-02 02:45:19 UTC (96319)
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
PHY: 1:01 - Link is Up - 1000/Full
IP-Config: Guessing netmask 255.0.0.0
IP-Config: Complete:
     device=eth0, addr=10.6.8.108, mask=255.0.0.0, gw=255.255.255.255,
     host=10.6.8.108, domain=, nis-domain=(none),
     bootserver=255.255.255.255, rootserver=10.6.8.107, rootpath=
VFS: Mounted root (nfs filesystem) on device 0:12.
Freeing init memory: 208K
Failed to execute /linuxrc.  Attempting defaults...
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[<80048854>] (unwind_backtrace+0x0/0xf8) from [<8050ac74>] (panic+0x74/0x18c)
[<8050ac74>] (panic+0x74/0x18c) from [<8050a988>] (init_post+0xa0/0xc4)
[<8050a988>] (init_post+0xa0/0xc4) from [<800089b4>] (kernel_init+0x10c/0x13c)
[<800089b4>] (kernel_init+0x10c/0x13c) from [<80042aa4>] (kernel_thread_exit+0x0/0x8)
CPU3: stopping
[<80048854>] (unwind_backtrace+0x0/0xf8) from [<8003c324>] (do_IPI+0x150/0x17c)
[<8003c324>] (do_IPI+0x150/0x17c) from [<80041a0c>] (__irq_svc+0x4c/0xe8)
Exception stack(0xbff01d08 to 0xbff01d50)
1d00:                   00000200 003ffc00 00000200 00000400 bffc1860 00000000
1d20: 00000000 bffc1910 00000002 00000000 00000001 bff01e34 bffd1800 bff01d50
1d40: 8007037c 8022f0d0 80000113 ffffffff
[<80041a0c>] (__irq_svc+0x4c/0xe8) from [<8022f0d0>] (__aeabi_uidiv+0x54/0x9c)
[<8022f0d0>] (__aeabi_uidiv+0x54/0x9c) from [<8007037c>] (find_busiest_group+0x618/0xa30)
[<8007037c>] (find_busiest_group+0x618/0xa30) from [<80070854>] (load_balance+0xc0/0x67c)
[<80070854>] (load_balance+0xc0/0x67c) from [<80070eb0>] (rebalance_domains+0xa0/0x18c)
[<80070eb0>] (rebalance_domains+0xa0/0x18c) from [<80070fe0>] (run_rebalance_domains+0x44/0x11c)
[<80070fe0>] (run_rebalance_domains+0x44/0x11c) from [<8007b554>] (__do_softirq+0xac/0x140)
[<8007b554>] (__do_softirq+0xac/0x140) from [<8007ba90>] (irq_exit+0x94/0x9c)
[<8007ba90>] (irq_exit+0x94/0x9c) from [<8003c2e0>] (do_IPI+0x10c/0x17c)
[<8003c2e0>] (do_IPI+0x10c/0x17c) from [<80041a0c>] (__irq_svc+0x4c/0xe8)
Exception stack(0xbff01f90 to 0xbff01fd8)
1f80:                                     80afb380 80000093 00000001 00000000
1fa0: bff00000 80af3f24 80aa5a70 80513180 80aa8e7c 412fc09a 00000000 00000000
1fc0: 00000000 bff01fd8 8005076c 80042b04 40000013 ffffffff
[<80041a0c>] (__irq_svc+0x4c/0xe8) from [<80042b04>] (default_idle+0x24/0x28)
[<80042b04>] (default_idle+0x24/0x28) from [<80042d20>] (cpu_idle+0xe0/0x124)
[<80042d20>] (cpu_idle+0xe0/0x124) from [<10507ab4>] (0x10507ab4)
CPU2: stopping
FSL_TICS_Rita 发表于 2014-7-2 18:00 | 显示全部楼层
楼主你好,请问你文档系统是自己编译的还是官网上的?
 楼主| ffbiao 发表于 2014-7-2 19:17 | 显示全部楼层
自己编译的,但是没有改动过源码
FSL_TICS_Rita 发表于 2014-7-3 09:26 | 显示全部楼层
自己编译的,但是没有改动过源码
楼主你好,你把你u-boot中的参数设置发给我看一下哈~~
FSL_TICS_Rita 发表于 2014-7-3 09:31 | 显示全部楼层
在ltib菜单中,Target Image Option---------->Options选项中Target image中你有选择NFS only吗?
 楼主| ffbiao 发表于 2014-7-3 10:57 | 显示全部楼层
在ltib菜单中,Target Image Option---------->Options选项中Target image中你有选择NFS only吗? ...
是不是下载的文件格式:u-boot.bin,uImage,rootfs.jffs2???
FSL_TICS_Rita 发表于 2014-7-7 11:03 | 显示全部楼层
楼主你好,关于nfs启动的话,只有将uboot写到Flash中,uImage和文件系统是通过NFS启动的,在文档中有介绍的哦~~如果还有不明白的,欢迎继续在这里讨论哈~~
