[工具和软件] Codewarrior(已解决)
1653|9
 楼主| g_mark 发表于 2014-7-21 08:55 | 显示全部楼层 |阅读模式
codewarrior报价,代理商远高于freescale官网;
北京有代理商以接近官网的价格销售该软件吗?
盼知情者相告。
谢谢!
FSL_TICS_ZJJ 发表于 2014-7-21 09:13 | 显示全部楼层
楼主你好,你可以直接去官网购买CW软件。
 楼主| g_mark 发表于 2014-7-21 09:29 | 显示全部楼层
官网购买,是否需要支付美元?
 楼主| g_mark 发表于 2014-7-21 09:57 | 显示全部楼层
CWA方式购买后,每年都要续购吗?续购费用多少?
何处可以找到续购说明?
请知情者提示,谢谢!
FSL_TICS_ZJJ 发表于 2014-7-21 10:13 | 显示全部楼层
楼主你好,关于这个问题的详细情况,请拨打我们的非技术类电话支持:
他们会给你提供详细的解答。
 楼主| g_mark 发表于 2014-7-21 11:57 | 显示全部楼层
收到,谢谢!
FSL_TICS_ZJJ 发表于 2014-7-21 16:04 | 显示全部楼层
收到,谢谢!
不客气,如果还有问题欢迎继续交流。
购买方面的,你都可以去找代理以及打电话咨询。
FSL_TICS_ZJJ 发表于 2014-7-29 10:23 | 显示全部楼层
楼主如果问题解决了,还请帮我们结贴啊。
FSL_TICS_Lunmin 发表于 2014-9-26 14:23 | 显示全部楼层
你好,具体续费方式请参照下面说明:
Q: How do I renew the subscription for my annual subscription model CodeWarrior Suite?
Renewals for the annual subscription suite can be purchased on the Freescale web store or through an authorized Freescale distributor.
1. If you wish to purchase your annual subscription renewal online
a.Log in at freescale.com using your registered email address and password
b.Click on Software Licensing — The "Software Licensing Home” page appears.
Take note of the subscription expiration date and entitlement ID for the CodeWarrior Suite
------------------------------------------------------------------------------------------------------------------------------------------ c.Click on the ‘Renew’ button beside the suite for which the annual subscription is being renewed
d.You will see a pop-up window asking if you’ve previously purchased the renewal. Since you are purchasing online, choose no
e.Follow the prompts to purchase your annual subscription renewal
f.Your subscription end date will automatically be updated at the conclusion of your purchase. I. You should confirm that the annual subscription renewal has been properly applied by following the link to the ‘Suite Details Page’ and reviewing the new expiration date for the suite.
II.After confirming that the annual subscription end date has been updated, you can proceed to download licenses from your suite.
2. If you wish to purchase your subscription renewal through a distributor.
1.Order the appropriate part number (selected from the chart below) from your selected distributor.
Suite Level
Support Renewal Part Number
Professional
CWA-PRO-R
Standard
CWA-STANDARD-R
Basic
CWA-BASIC-R
2.After placing your order, you will receive a physical shipment of a certificate with a unique entitlement ID for your annual subscription renewal.
3.You must register your annual subscription renewal to link it to your CodeWarrior suite. See process number 3 below for instructions for registering your annual subscription renewal.
3. How to register an annual subscription renewal once you have the entitlement ID
Take note of the subscription expiration date on the CodeWarrior Suite you are renewing
d.You will see a pop-up window asking if you’ve previously purchased the renewal. Choose yes.
e.Follow the prompts to register your annual subscription renewal
f.You should confirm that the renewal has been properly applied by following the link to the ‘Suite Details Page’ and reviewing the new expiration date for the suite.
g.After confirming that the subscription end date has been updated, you can proceed to download licenses from your suite.
FSL_TICS_Lunmin 发表于 2014-9-26 14:25 | 显示全部楼层
续费价格请参照:
freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-SUITE-STANDARD&cof=0&am=0&tab=Buy_Parametric_Tab
由于我发不了链接,所以把上面链接做了处理,请copy到地址栏并在前面加上http和3W
