分享:C5000系列McBSP寄存器初始化代码
1180|1
 楼主| 拿起书本 发表于 2014-10-29 15:32 | 显示全部楼层 |阅读模式
void InitMcBSP0(void)
    SetMcBSPReg(0,SPCR1,0x00);
    SetMcBSPReg(0,SPCR2,0x00);
    /*SET McBSP0*/
    SetMcBSPReg(0,SPCR2,0x0200);
    SetMcBSPReg(0,PCR,0x0A00);
    SetMcBSPReg(0,RCR1,0x40);
    SetMcBSPReg(0,RCR2,0x41);
    SetMcBSPReg(0,XCR1,0x40);
    SetMcBSPReg(0,XCR2,0x41);
      SetMcBSPReg(0,SRGR1,0x1027);  ////FWID=1+1;CLKDGV=39+1,SCLK = CPU CLK /(CLKDGV+1) =1MhZ
    SetMcBSPReg(0,SRGR2,0x02027);
void StartMcBSP0(void)
    /* 开始McBSP0发送和采集数据   */
      SetMcBSPReg(0,SPCR2,0xC0);
    SetMcBSPReg(0,SPCR1,0x01);
    SetMcBSPReg(0,SPCR2,0xc1);
void StopMcBSP0()
void StartDataCollect(void)
    SetMcBSPReg(1,SPCR2,0xC0);
     SetMcBSPReg(1,SPCR1,0x01);
      SetMcBSPReg(1,SPCR2,0xc1);
void StopDataCollect()
     SetMcBSPReg(1,SPCR1,0x0);
      SetMcBSPReg(1,SPCR2,0x0);
void SetMcBSPReg(unsigned int McBSPNo,unsigned int McBSPReg,unsigned int Value)
   switch(McBSPNo)
       case 0:        {
                               SPSA0 = McBSPReg;
                               C_NOP;C_NOP;C_NOP; C_NOP;C_NOP;C_NOP;
                               SPSD0 = Value;
                               break;
           case 1:        {
                               SPSA1 = McBSPReg;
                               SPSD1 = Value;
                               break;
           default:
                               break;
小木欧尼 发表于 2014-10-29 17:32 | 显示全部楼层
这个 是这样的吗
个人签名:好好学习,天天向上!
519
