- * @file main.c
- * @version V1.00
- * $Revision: 2 $
- * $Date: 15/09/02 10:03a $
- * @brief Display an image on TFT LCD panel via SPI interface and control LED.
- * @note
- * Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M451Series.h"
- #define ILI9341_RESET PB15
- #define ILI9341_DC PB11
- #define ILI9341_LED PB5
- #define LED1 PC3
- #define LED2 PC2
- #define LED3 PB1
- #define LED4 PC7
- #define LED_R PC9
- #define LED_G PC10
- #define LED_B PC11
- extern uint8_t u8Image[153600];
- extern uint8_t Font8x16[];
- #define White 0xFFFF
- #define Black 0x0000
- #define Blue 0x001F
- #define Blue2 0x051F
- #define Red 0xF800
- #define Magenta 0xF81F
- #define Green 0x07E0
- #define Cyan 0x7FFF
- #define Yellow 0xFFE0
- uint8_t LCD_ReadReg(uint8_t u8Comm)
- SPI_ClearRxFIFO(SPI2);
- ILI9341_DC = 0;
- SPI_WRITE_TX(SPI2, u8Comm);
- SPI_WRITE_TX(SPI2, 0x00);
- // wait tx finish
- while(SPI_IS_BUSY(SPI2));
- SPI_READ_RX(SPI2);
- return (SPI_READ_RX(SPI2));
- void LCD_WriteCommand(uint8_t u8Comm)
- ILI9341_DC = 0;
- // wait tx finish
- void LCD_WriteData(uint8_t u8Data)
- ILI9341_DC = 1;
- SPI_WRITE_TX(SPI2, u8Data);
- // wait tx finish
- void ILI9341_LCD_DisplayOnScreen(void)
- uint32_t i,j;
- uint16_t *u16ImgPtr = (uint16_t *) &u8Image[0];
- LCD_WriteCommand(0x2c);
- ILI9341_DC = 1;
- /* Need to disable and then can change data width to 16-bit */
- SPI_DISABLE(SPI2);
- SPI_SET_DATA_WIDTH(SPI2, 16);
- SPI_ENABLE(SPI2);
- /* Load image */
- for (i=0; i<320; i++) {
- for (j=0; j<240; j++) {
- while(SPI_GET_TX_FIFO_FULL_FLAG(SPI2));
- SPI_WRITE_TX(SPI2, *(u16ImgPtr++));
- // wait tx finish
- /* Change data width back to 8-bit */
- SPI_SET_DATA_WIDTH(SPI2, 8);
- SPI_ENABLE(SPI2);
- LCD_WriteCommand(0x29);
- void ILI9341_LCD_SetAddress(uint32_t x1,uint32_t x2,uint32_t y1,uint32_t y2)
- if(x1 >= 240)
- x1 = 239;
- if(x2 >= 240)
- x2 = 239;
- if(y1 >= 320)
- y1 = 319;
- if(y2 >= 320)
- y2 = 319;
- LCD_WriteCommand(0x2a);
- LCD_WriteData(x1>>8);
- LCD_WriteData(x1);
- LCD_WriteData(x2>>8);
- LCD_WriteData(x2);
- LCD_WriteCommand(0x2b);
- LCD_WriteData(y1>>8);
- LCD_WriteData(y1);
- LCD_WriteData(y2>>8);
- LCD_WriteData(y2);
- void ILI9341_LCD_PutChar8x16(uint16_t x, uint16_t y, uint8_t c, uint32_t fColor, uint32_t bColor)
- uint32_t i,j;
- for(i=0;i<16;i++){
- uint8_t m=Font8x16[c*16+i];
- ILI9341_LCD_SetAddress(x+i,x+i,y,y+7);
- for(j=0;j<8;j++){
- if((m&0x01)==0x01){
- LCD_WriteData(fColor>>8);
- LCD_WriteData(fColor);
- else{
- LCD_WriteData(bColor>>8);
- LCD_WriteData(bColor);
- m>>=1;
- void ILI9341_LCD_PutString(uint16_t x, uint16_t y,uint8_t *s, uint32_t fColor, uint32_t bColor)
- uint8_t l=0;
- while(*s){
- if(*s<0x80){
- ILI9341_LCD_PutChar8x16(x,312-y-l*8,*s,fColor,bColor);
- s++;
- l++;
- void ILI9341_LCD_Init(void)
- /* Configure DC/RESET/LED pins */
- ILI9341_DC =0;
- ILI9341_RESET=0;
- ILI9341_LED=0;
- GPIO_SetMode(PB, BIT5, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PB, BIT11, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PB, BIT15, GPIO_MODE_OUTPUT);
- /* Configure LCD */
- ILI9341_DC = 1;
- ILI9341_RESET = 0;
- TIMER_Delay(TIMER0, 20000);
- ILI9341_RESET = 1;
- TIMER_Delay(TIMER0, 40000);
- LCD_WriteCommand(0xCB);
- LCD_WriteData(0x39);
- LCD_WriteData(0x2C);
- LCD_WriteData(0x00);
- LCD_WriteData(0x34);
- LCD_WriteData(0x02);
- LCD_WriteCommand(0xCF);
- LCD_WriteData(0xC1);
- LCD_WriteData(0x30);
- LCD_WriteCommand(0xE8);
- LCD_WriteData(0x85);
- LCD_WriteData(0x78);
- LCD_WriteCommand(0xEA);
- LCD_WriteCommand(0xED);
- LCD_WriteData(0x64);
- LCD_WriteData(0x03);
- LCD_WriteData(0x12);
- LCD_WriteData(0x81);
- LCD_WriteCommand(0xF7);
- LCD_WriteData(0x20);
- LCD_WriteCommand(0xC0);
- LCD_WriteData(0x23);
- LCD_WriteCommand(0xC1);
- LCD_WriteData(0x10);
- LCD_WriteCommand(0xC5);
- LCD_WriteData(0x3e);
- LCD_WriteData(0x28);
- LCD_WriteCommand(0xC7);
- LCD_WriteData(0x86);
- LCD_WriteCommand(0x36);
- LCD_WriteData(0x48);
- LCD_WriteCommand(0x3A);
- LCD_WriteData(0x55);
- LCD_WriteCommand(0xB1);
- LCD_WriteData(0x18);
- LCD_WriteCommand(0xB6);
- LCD_WriteData(0x08);
- LCD_WriteData(0x82);
- LCD_WriteData(0x27);
- LCD_WriteCommand(0xF2);
- LCD_WriteCommand(0x26);
- LCD_WriteData(0x01);
- LCD_WriteCommand(0xE0);
- LCD_WriteData(0x0F);
- LCD_WriteData(0x31);
- LCD_WriteData(0x2B);
- LCD_WriteData(0x0C);
- LCD_WriteData(0x0E);
- LCD_WriteData(0x4E);
- LCD_WriteData(0xF1);
- LCD_WriteData(0x37);
- LCD_WriteData(0x07);
- LCD_WriteData(0x09);
- LCD_WriteCommand(0xE1);
- LCD_WriteData(0x14);
- LCD_WriteData(0x11);
- LCD_WriteData(0x36);
- LCD_WriteCommand(0x11);
- TIMER_Delay(TIMER0, 60000);
- LCD_WriteCommand(0x29); //Display on
- ILI9341_LED = 1;
- void LED_Init(void)
- GPIO_SetMode(PB, BIT1, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PC, BIT2, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PC, BIT3, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PC, BIT7, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PC, BIT10, GPIO_MODE_OUTPUT);
- GPIO_SetMode(PC, BIT11, GPIO_MODE_OUTPUT);
- void LED_Light(uint32_t u32LED)
- LED1 = u32LED;
- u32LED = u32LED>>1;
- LED2 = u32LED;
- LED3 = u32LED;
- LED4 = u32LED;
- LED_R = u32LED;
- LED_G = u32LED;
- LED_B = u32LED;
- void SYS_Init(void)
- /* Init System Clock */
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Enable External XTAL (4~24 MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
- /* Waiting for 12MHz clock ready */
- CLK_WaitClockReady( CLK_STATUS_HXTSTB_Msk);
- /* Switch HCLK clock source to HXT */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT,CLK_CLKDIV0_HCLK(1));
- /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
- CLK->PLLCTL |= CLK_PLLCTL_PD_Msk;
- /* Set PLL frequency */
- CLK->PLLCTL = CLK_PLLCTL_72MHz_HXT;
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
- /* Switch HCLK clock source to PLL */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL,CLK_CLKDIV0_HCLK(1));
- /* Enable IP clock */
- CLK_EnableModuleClock(UART0_MODULE);
- CLK_EnableModuleClock(TMR0_MODULE);
- CLK_EnableModuleClock(SPI2_MODULE);
- /* Select IP clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
- CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, 0);
- CLK_SetModuleClock(SPI2_MODULE, CLK_CLKSEL2_SPI2SEL_PLL, 0);
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set GPG multi-function pins for UART0 RXD and TXD */
- SYS->GPD_MFPL = SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD ;
- /* SPI2: GPD12=SS, GPD15=CLK, GPD14=MISO, GPD13=MOSI */
- SYS->GPD_MFPH = SYS_GPD_MFPH_PD12MFP_SPI2_SS | SYS_GPD_MFPH_PD13MFP_SPI2_MOSI | SYS_GPD_MFPH_PD14MFP_SPI2_MISO | SYS_GPD_MFPH_PD15MFP_SPI2_CLK;
- /* Lock protected registers */
- SYS_LockReg();
- int main(void)
- uint32_t u32temp = 0;
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- LED_Init();
- /* Init UART to 115200-8n1 for print message */
- UART_Open(UART0, 115200);
- /* Configure SPI3 as a master, MSB first, 8-bit transaction, SPI Mode-0 timing, clock is 4MHz */
- SPI_Open(SPI2, SPI_MASTER, SPI_MODE_0, 8, 4000000);
- /* Configure SPI1 as a low level active device. */
- SPI_EnableAutoSS(SPI2, SPI_SS, SPI_SS_ACTIVE_LOW);
- /* Start SPI */
- SPI_ENABLE(SPI2);
- /* Init LCD */
- ILI9341_LCD_Init();
- /* Setup display address */
- ILI9341_LCD_SetAddress(0, 239, 0, 319);
- /* Show the image on the screen */
- ILI9341_LCD_DisplayOnScreen();
- while(1)
- CLK_SysTickDelay(200000);
- LED_Light(u32temp++);
- if(PA8 == 0)
- ILI9341_LCD_PutString(50,60,"Hello World!",Red,Yellow);
- if(PD2 == 0)
- ILI9341_LCD_PutString(50,60,"I Love You!",Red,Yellow);
