请问谁有ucos-ii 在LPC2378上的移植?
2742|2
 楼主| cressw 发表于 2009-4-29 21:36 | 显示全部楼层 |阅读模式
找了很久了, 都没找到. 在ucos-ii的官方网站上下载了一个, 可是编译不通过.是不是因为RealView 是评估版? 请高手指点. 多谢了!!!
roger_lj 发表于 2009-5-4 09:21 | 显示全部楼层
建议先注册RealView MDK
评价版的RealView&nbsp;MDK确实有很多限制的,比如映像大小限制:<br />-Programs&nbsp;that&nbsp;generate&nbsp;more&nbsp;than&nbsp;32&nbsp;Kbytes&nbsp;of&nbsp;code&nbsp;and&nbsp;data&nbsp;will&nbsp;not&nbsp;compile,&nbsp;assemble,&nbsp;or&nbsp;link.<br />-The&nbsp;debugger&nbsp;supports&nbsp;programs&nbsp;that&nbsp;are&nbsp;32&nbsp;Kbytes&nbsp;or&nbsp;smaller.<br />映像位置限制:<br />The&nbsp;base&nbsp;address&nbsp;for&nbsp;the&nbsp;code&nbsp;and&nbsp;constants&nbsp;in&nbsp;memory&nbsp;must&nbsp;be&nbsp;0x000080000,&nbsp;0x000100000,&nbsp;0x000200000,&nbsp;0x000300000,&nbsp;0x000400000,&nbsp;0x010400000,&nbsp;0xXX000000,&nbsp;or&nbsp;0xXX800000&nbsp;(where&nbsp;XX&nbsp;is&nbsp;a&nbsp;Hexadecimal&nbsp;number&nbsp;from&nbsp;00-FF).&nbsp;When&nbsp;the&nbsp;base&nbsp;address&nbsp;is&nbsp;0x0&nbsp;the&nbsp;linker&nbsp;places&nbsp;the&nbsp;code&nbsp;at&nbsp;the&nbsp;start&nbsp;of&nbsp;on-chip&nbsp;Flash&nbsp;of&nbsp;most&nbsp;ARM&nbsp;processor-based&nbsp;microcontrollers.<br />详见:&nbsp;http://www.keil.com/demo/limits.asp<br />另外,&nbsp;&micro;C/OS-II在LPC2300上的移植可以参考NXP官方推荐的:<br />http://www.micrium.com/nxp/LPC23xx.html<br />
junze 发表于 2009-5-5 19:22 | 显示全部楼层
UCOS官网下一个
然后,该下就可以了.<br />我用WINARM,是从那IAR的PORT改来的.<br />如果想省事,直接弄个MDK来.
