我的板子一直挂不上,一修改参数就会启动不起来系统,不知道怎么回事?<br />问题如下:<br />按照说明书想NFS方式mount主机,所有按照说明书上的办,但是出现下面问题:<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />portmap:server 192.168.253.1 not responding,timeout<br />root-NFS:unable to get nfsd port number from server,using default<br />looking up port of RPC 100005/1 on 192.168.253.1<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />NETDEV WATCHDOG: eth0: transmit timed out<br />root-NFS:sever returned error -5 while mounting /arysys2410/root<br />VFS:unable to root fs via NFS,trying floppy<br />VFS:cannot open root device "nfs" or unknown-block(2.0)<br />一系列的错误的,怎么解决啊?是不是还是网络不通畅造成的?怎么解决?谢谢。有的人说是主机的网络设置有问题,但是怎么来做才能设置正确呢?谢谢 |
