一个vb 串口问题!急!!!!!!!!
2050|1
 楼主| krdzw 发表于 2007-4-28 08:33 | 显示全部楼层 |阅读模式
我要做一个发送和接受简单程序<br />我软件发送时我用导线把发送和接受端短接应该是发送什么在文本里面应该显示什么可是什么也没有请大家看看是什么原因呀!<br />Private&nbsp;Sub&nbsp;Command2_Click()<br />Text1.Text&nbsp;=&nbsp;buf<br />End&nbsp;Sub<br /><br />Private&nbsp;Sub&nbsp;Form_Load()<br />Dim&nbsp;instring&nbsp;As&nbsp;String<br />MSComm1.InputMode&nbsp;=&nbsp;comInputModeText<br />MSComm1.InBufferSize&nbsp;=&nbsp;1024<br />MSComm1.CommPort&nbsp;=&nbsp;1<br />If&nbsp;Not&nbsp;MSComm1.PortOpen&nbsp;Then<br />MSComm1.PortOpen&nbsp;=&nbsp;True<br />End&nbsp;If<br />MSComm1.Settings&nbsp;=&nbsp;&quot;2400,N,8,1&quot;<br />MSComm1.InputLen&nbsp;=&nbsp;0<br />MSComm1.InBufferCount&nbsp;=&nbsp;0<br />MSComm1.RThreshold&nbsp;=&nbsp;8<br />End&nbsp;Sub<br />Private&nbsp;Sub&nbsp;Command1_Click()<br />Dim&nbsp;buf1&nbsp;As&nbsp;Variant<br />Dim&nbsp;Data1(8)&nbsp;As&nbsp;Byte<br />If&nbsp;Not&nbsp;MSComm1.PortOpen&nbsp;Then<br />MSComm1.PortOpen&nbsp;=&nbsp;True<br />End&nbsp;If<br />Data1(0)&nbsp;=&nbsp;&H0<br />Data1(1)&nbsp;=&nbsp;&H11<br />Data1(2)&nbsp;=&nbsp;&H22<br />Data1(3)&nbsp;=&nbsp;&H33<br />Data1(4)&nbsp;=&nbsp;&H44<br />Data1(5)&nbsp;=&nbsp;&H55<br />Data1(6)&nbsp;=&nbsp;&H66<br />Data1(7)&nbsp;=&nbsp;&HAA<br />buf1&nbsp;=&nbsp;Data1<br />MSComm1.Output&nbsp;=&nbsp;buf1<br />MSComm1.PortOpen&nbsp;=&nbsp;False<br />End&nbsp;Sub<br /><br />Private&nbsp;Sub&nbsp;MSComm1_OnComm()<br />If&nbsp;Not&nbsp;MSComm1.PortOpen&nbsp;Then<br />MSComm1.PortOpen&nbsp;=&nbsp;True<br />End&nbsp;If<br />Select&nbsp;Case&nbsp;MSComm1.CommEvent<br />Case&nbsp;comEvReceive<br />&nbsp;&nbsp;&nbsp;buf&nbsp;=&nbsp;MSComm1.Input<br />End&nbsp;Select<br />MSComm1.PortOpen&nbsp;=&nbsp;False<br /><br />End&nbsp;Sub
独占一江秋 发表于 2007-4-28 11:20 | 显示全部楼层
还没等它发呢,你就给关了
