[活动专区]
【AutoChips 7801x MCU评测报告】+串口nr_micro_shell移植测试
21054|69
      移植了一个串口shell程序nr_micro_shell。顺便测试了I2C接口的读写AT24Cxx。移植很简单,主要在nr_micro_shell_config.h文件内配置,以及串口发送接收函数。主函数main内初始化和接收串口数据处理。
代码如下:
/*************<include>****************/
#include "string.h"
#include "ac780x.h"
#include "system_ac780x.h"
#include "ac780x_gpio.h"
#include "ac780x_uart.h"
#include "elog.h"
#include "nr_micro_shell.h"
#include "i2c.h"
/*************<macro>******************/
#define LED2_PORT                        (GPIOC)
#define LED2_PIN                        (GPIO_PIN9)
#define LED3_PORT                        (GPIOC)
#define LED3_PIN                        (GPIO_PIN7)
#define LED2_ON()                                do{GPIO_SetPinLevel(LED2_PORT, LED2_PIN, GPIO_LEVEL_HIGH);}while(0)
#define LED2_OFF()                                do{GPIO_SetPinLevel(LED2_PORT, LED2_PIN, GPIO_LEVEL_LOW);}while(0)
#define LED2_TOGGLE()                        do{if(GPIO_GetPinLevel(LED2_PORT, LED2_PIN)){LED2_OFF;}else{LED2_ON;}}while(0)
#define LED3_ON()                                do{GPIO_SetPinLevel(LED3_PORT, LED3_PIN, GPIO_LEVEL_HIGH);}while(0)
#define LED3_OFF()                                do{GPIO_SetPinLevel(LED3_PORT, LED3_PIN, GPIO_LEVEL_LOW);}while(0)
#define LED3_TOGGLE()                        do{if(GPIO_GetPinLevel(LED3_PORT, LED3_PIN)){LED3_OFF;}else{LED3_ON;}}while(0)
/*************<enum>*******************/
/*************<union>******************/
/*************<struct>*****************/
/*************<variable>***************/
/*************<prototype>**************/
void shell_ls_cmd(char argc, char *argv)
                unsigned int i = 0;
        if (argc > 1)
                if (!strcmp("cmd", &argv[argv[1]]))
                        for (i = 0; nr_shell.static_cmd[i].fp != NULL; i++)
                                shell_printf(nr_shell.static_cmd[i].cmd);
                                shell_printf("\r\n");
                else if (!strcmp("-v", &argv[argv[1]]))
                        shell_printf("ls version 1.0.\r\n");
                else if (!strcmp("-h", &argv[argv[1]]))
                        shell_printf("useage: ls [options]\r\n");
                        shell_printf("options: \r\n");
                        shell_printf("\t -h \t: show help\r\n");
                        shell_printf("\t -v \t: show version\r\n");
                        shell_printf("\t cmd \t: show all commands\r\n");
        else
                shell_printf("ls need more arguments!\r\n");
* [url=home.php?mod=space&uid=247401]@brief[/url] test command
void shell_test_cmd(char argc, char *argv)
        unsigned int i;
        shell_printf("test command:\r\n");
        for (i = 0; i < argc; i++)
                        shell_printf("paras %d: %s\r\n", i, &(argv[argv[i]]));
void shell_led_cmd(char argc, char *argv)
        if (argc > 1)
                if (!strcmp("on", &argv[argv[1]]))
                        if (!strcmp("1", &argv[argv[2]]))
                                LED2_ON();
                        }else if (!strcmp("2", &argv[argv[2]]))
                                LED3_ON();
                        }else
                                shell_printf("useage: led [on/off] [1/2/3/4]\r\n");
                }else if (!strcmp("off", &argv[argv[1]]))
                                LED2_OFF();
                                LED3_OFF();
                        }else
                }else{
void at24cxx_cmd(char argc, char *argv)
        if (argc > 1)
                if (!strcmp("read", &argv[argv[1]]))
                                        I2C_RdDataFromAT24C();
                }else if (!strcmp("write", &argv[argv[1]]))
                    I2C_WrDataToAT24C();
                }else{
                    shell_printf("useage: at24 [read/write] \r\n");
        }else{
NR_SHELL_CMD_EXPORT(at24, at24cxx_cmd);
#ifdef NR_SHELL_USING_EXPORT_CMD
NR_SHELL_CMD_EXPORT(ls, shell_ls_cmd);
NR_SHELL_CMD_EXPORT(test, shell_test_cmd);
NR_SHELL_CMD_EXPORT(led, shell_led_cmd);
#else
const static_cmd_st static_cmd[] =
                {"ls", shell_ls_cmd},
                {"test", shell_test_cmd},
                {"led", shell_led_cmd},
                {"\0", NULL}
#endif
* [url=home.php?mod=space&uid=555622]@prototype[/url] main(void)
* @param[in] void
* @return         void
* @brief           main entry.
*                         mainº¯Êý.
int main(void)
        uint8_t ch;
        InitDelay();        //sysclk  Delay
        InitDebug();         //Uart Debug printf
        //ÉèÖÃLEDÒý½ÅΪGPIOÊä³ö.
        GPIO_SetDir(LED2_PORT, LED2_PIN, GPIO_OUT);
        GPIO_SetDir(LED3_PORT, LED3_PIN, GPIO_OUT);
        I2C_InitHw();
        elog_init();
        shell_init();            /* nr_micro_shell*/
        while(1)
                if (UART_RxIsDataReady(UART2))
            ch = UART_ReceiveData(UART2);
                        shell(ch);
/*************<end>********************/
I2C程序:
/* Copyright Statement:
* This software/firmware and related documentation ("AutoChips Software") are
* protected under relevant copyright laws. The information contained herein is
* confidential and proprietary to AutoChips Inc. and/or its licensors. Without
* the prior written permission of AutoChips inc. and/or its licensors,  any
* reproduction,  modification,  use or disclosure of AutoChips Software,  and
* information contained herein,  in whole or in part,  shall be strictly
* prohibited.
* AutoChips Inc. (C) 2018. All rights reserved.
* BY OPENING THIS FILE,  RECEIVER HEREBY UNEQUIVOCALLY ACKNOWLEDGES AND AGREES
* THAT THE SOFTWARE/FIRMWARE AND ITS DOCUMENTATIONS ("AUTOCHIPS SOFTWARE")
* RECEIVED FROM AUTOCHIPS AND/OR ITS REPRESENTATIVES ARE PROVIDED TO RECEIVER
* ON AN "AS-IS" BASIS ONLY. AUTOCHIPS EXPRESSLY DISCLAIMS ANY AND ALL
* WARRANTIES,  EXPRESS OR IMPLIED,  INCLUDING BUT NOT LIMITED TO THE IMPLIED
* WARRANTIES OF MERCHANTABILITY,  FITNESS FOR A PARTICULAR PURPOSE OR
* NONINFRINGEMENT. NEITHER DOES AUTOCHIPS PROVIDE ANY WARRANTY WHATSOEVER WITH
* RESPECT TO THE SOFTWARE OF ANY THIRD PARTY WHICH MAY BE USED BY,
* INCORPORATED IN,  OR SUPPLIED WITH THE AUTOCHIPS SOFTWARE,  AND RECEIVER AGREES
* TO LOOK ONLY TO SUCH THIRD PARTY FOR ANY WARRANTY CLAIM RELATING THERETO.
* RECEIVER EXPRESSLY ACKNOWLEDGES THAT IT IS RECEIVER'S SOLE RESPONSIBILITY TO
* OBTAIN FROM ANY THIRD PARTY ALL PROPER LICENSES CONTAINED IN AUTOCHIPS
* SOFTWARE. AUTOCHIPS SHALL ALSO NOT BE RESPONSIBLE FOR ANY AUTOCHIPS SOFTWARE
* RELEASES MADE TO RECEIVER'S SPECIFICATION OR TO CONFORM TO A PARTICULAR
* STANDARD OR OPEN FORUM. RECEIVER'S SOLE AND EXCLUSIVE REMEDY AND AUTOCHIPS'S
* ENTIRE AND CUMULATIVE LIABILITY WITH RESPECT TO THE AUTOCHIPS SOFTWARE
* RELEASED HEREUNDER WILL BE,  AT AUTOCHIPS'S OPTION,  TO REVISE OR REPLACE THE
* AUTOCHIPS SOFTWARE AT ISSUE,  OR REFUND ANY SOFTWARE LICENSE FEES OR SERVICE
* CHARGE PAID BY RECEIVER TO AUTOCHIPS FOR SUCH AUTOCHIPS SOFTWARE AT ISSUE.
/*************<start>******************/
#include "i2c.h"
#define AT24C02_DEV_ADDR                (0x50)
uint8_t g_wrAT24CDataBuf[9];
uint8_t g_rdAT24CDataBuf[9];
* @prototype I2C_InitHw(void)
* @param[in] void
* @return         void
* @brief           ³õʼ»¯I2C.
void I2C_InitHw(void)
        I2C_ConfigType i2cConfig = {0};
        /*³õʼ»¯Òý½Å¹¦ÄÜΪI2C.*/
        GPIO_SetFunc(I2C0_SCL_PORT, I2C0_SCL_PIN, GPIO_FUN3);
        GPIO_SetFunc(I2C0_SDA_PORT, I2C0_SDA_PIN, GPIO_FUN3);
        /*³õʼ»¯I2CÍâÉè.*/
        i2cConfig.masterConfigs.ARBEn         = ENABLE;/*ÉèÖÃÖ÷»úÖٲù¦ÄÜ.*/
        i2cConfig.masterConfigs.SYNCEn        = ENABLE;/*ÉèÖÃÖ÷»úSCLͬ²½¹¦ÄÜ.*/
        /*ÉèÖò¨ÌØÂÊΪ100Kbps,bandrate = 24M / (10 * 12 * 2) = 100Kbps;*/
        i2cConfig.masterConfigs.sampleCnt        = 9;
        i2cConfig.masterConfigs.stepCnt                = 11;
        i2cConfig.slaveConfigs.addExtEn                = DISABLE;/*½ûÄÜÀ©Õ¹µØÖ·.*/
        i2cConfig.slaveConfigs.addRangeEn        = DISABLE;/*½ûÄÜ·¶Î§µØÖ·.*/
        i2cConfig.slaveConfigs.monitorEn        = DISABLE;/*½ûÄÜ´Ó»ú¼à²â¹¦ÄÜ.*/
        i2cConfig.slaveConfigs.stretchEn        = DISABLE;/*´Ó»úSCLÑÓÉ칦ÄÜ.*/
        i2cConfig.slaveConfigs.gcaEn                = DISABLE;/*´Ó»úSCL¹ã²¥µØÖ·.*/
        i2cConfig.slaveConfigs.wakeupEn                = DISABLE;/*»½Ðѹ¦ÄÜ,½ö´Ó»úʱÓÐЧ.*/
        i2cConfig.slaveConfigs.RXFInterruptEn        = DISABLE;/*½ÓÊÕ»º´æÂúÖжÏ.*/
        i2cConfig.slaveConfigs.RXOFInterruptEn        = DISABLE;/*½ÓÊÕ»º´æÒç³öÖжÏ.*/
        i2cConfig.slaveConfigs.TXEInterruptEn        = DISABLE;/*·¢ËÍ»º´æ¿ÕÖжÏ.*/
        i2cConfig.slaveConfigs.TXUFInterruptEn        = DISABLE;/*·¢ËÍ»º´æÒç³öÖжÏ.*/
        i2cConfig.slaveConfigs.slaveAddress                = AT24C02_DEV_ADDR;/*´Ó»úµØÖ·.*/
        i2cConfig.slaveConfigs.slave7BitRangeAddress = 0;/*´Ó»ú·¶Î§µØÖ·.*/
        i2cConfig.glitchFilterCnt        = 0;/*ë´Ì¹ýÂË.*/
        i2cConfig.interruptEn                = DISABLE;/*I2CÈ«¾ÖÖжÏ.*/
        i2cConfig.nackInterruptEn        = DISABLE;/*NACKÖжÏ.*/
        i2cConfig.ssInterruptEn                = DISABLE;/*×ÜÏßstart»òstopÖжÏ.*/
        i2cConfig.dmaRxEn                        = DISABLE;/*ÉèÖÃDMA½ÓÊÕÊý¾Ý.*/
        i2cConfig.dmaTxEn                        = DISABLE;/*ÉèÖÃDMA·¢ËÍÊý¾Ý.*/
        i2cConfig.mode                                = I2C_MASTER;/*ÉèÖÃÖ÷´Ó»úģʽ.*/
        i2cConfig.i2cEn                                = ENABLE;/*ʹÄÜÄ£¿é.*/
        i2cConfig.callBack                        = NULL;/*Öжϻص÷º¯Êý.*/
        I2C_Init(I2C0, &i2cConfig);
* @prototype I2C_WrDataToAT24C(void)
* @param[in] void
* @return         void
* @brief           Ð´Êý¾Ýµ½EEPROM.
void I2C_WrDataToAT24C(void)
        g_wrAT24CDataBuf[0] = 0x00;//дÈëµØÖ·
        for (uint8_t ii = 0; ii < 8; ii++)
                g_wrAT24CDataBuf[ii + 1] = ii+10;
                printf("%02X ", g_wrAT24CDataBuf[ii + 1]);
        }printf("\r\n");
        I2C_MasterBurstWrite(I2C0, AT24C02_DEV_ADDR, g_wrAT24CDataBuf, 9, ENABLE);
* @prototype I2C_RdDataFromAT24C(void)
* @param[in] void
* @return         void
* @brief           ´ÓEEPROM¶ÁÈ¡Êý¾Ý.
void I2C_RdDataFromAT24C(void)
        g_wrAT24CDataBuf[0] = 0x00;//¶ÁÈ¡µØÖ·
        I2C_MasterBurstWrite(I2C0, AT24C02_DEV_ADDR, g_wrAT24CDataBuf, 1, DISABLE);
        I2C_MasterBurstRead (I2C0, AT24C02_DEV_ADDR, g_rdAT24CDataBuf, 8);
                printf("%02X ", g_rdAT24CDataBuf[ii]);
        printf("\r\n");
工程代码:
游客,如果您要查看本帖隐藏内容请回复
今晚跟你睡| | 2020-6-17 10:52 | 只看该作者
先占下楼
marginer| | 2020-6-17 11:00 | 只看该作者
不错不错,这个很有用。
caizhiwei| | 2020-6-17 19:16 | 只看该作者
厉害了,学习学习
JasonLee27| | 2020-6-18 13:17 | 只看该作者
做shell应该挺占空间吧
Transformers| | 2020-6-18 14:38 | 只看该作者
学习一下
WoodData|  楼主 | 2020-6-18 15:27 | 只看该作者
JasonLee27 发表于 2020-6-18 13:17
做shell应该挺占空间吧
这个还好,占用空间比较小。
e_007| | 2020-6-20 16:51 | 只看该作者
看似很不错的
zhlu| | 2020-6-28 14:28 | 只看该作者
很有用
dream886| | 2020-6-28 17:04 | 只看该作者
顶一个
lihuasoft| | 2020-6-29 19:08 | 只看该作者
学习!
zeshoufx| | 2020-6-29 20:20 | 只看该作者
谢谢分享,,,,,,
ATC2019| | 2020-6-30 20:04 | 只看该作者
高人
比神乐| | 2020-7-1 08:09 | 只看该作者
看看
desk1983| | 2020-7-3 21:01 | 只看该作者
不错不错,这个很有用
不错不错,这个很有用
flymxd2008| | 2020-8-13 10:53 | 只看该作者
zhdm| | 2021-1-23 22:19 | 只看该作者
谢谢分享
zx5290| | 2021-1-30 17:11 | 只看该作者
跟着楼主多多学习
tuying1982811| | 2021-4-21 12:06 | 只看该作者
厉害了,学习学习
zgy_chenxin| | 2021-9-23 12:25 | 只看该作者
谢谢分享!
