[N32G430]
【N32G430C8L7开发板体验】+SPI外设通讯速度测试
1183|5
根据用户手册,SPI接口的最高速度,在主模式下可以达到28 Mbps(不带CRC),20Mbps(带CRC),从模式可以达到32Mbps。
按照这个说明,启动SPI的通讯例程,选择的是SPI_INT例程,为了能顺利捕捉波形,稍微修改了代码,是SPI的收发处理一直被循环。
Main处理被修改为:
int main(void)
    /* At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_N32G430.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_N32G430.c file
    /* System clocks configuration ---------------------------------------------*/
    RCC_Configuration();
    /* GPIO configuration ------------------------------------------------------*/
    GPIO_Configuration();
    NVIC_Configuration();
    /* log configuration ------------------------------------------------------*/
    log_init();
    log_info("This is SPI INT demo!\r\n");
    /* SPI_MASTER configuration ------------------------------------------------------*/
    SPI_Initializes_Structure(&SPI_InitStructure);
    SPI_InitStructure.DataDirection = SPI_DIR_SINGLELINE_TX;
    SPI_InitStructure.SpiMode       = SPI_MODE_MASTER;
    SPI_InitStructure.DataLen       = SPI_DATA_SIZE_16BITS;
    SPI_InitStructure.CLKPOL        = SPI_CLKPOL_LOW;
    SPI_InitStructure.CLKPHA        = SPI_CLKPHA_SECOND_EDGE;
    SPI_InitStructure.NSS           = SPI_NSS_HARD;
    /* It is recommended that the SPI master mode of the C version chips should not exceed 18MHz */
    SPI_InitStructure.BaudRatePres  = SPI_BR_PRESCALER_8;
    SPI_InitStructure.FirstBit      = SPI_FB_MSB;
    SPI_InitStructure.CRCPoly       = 7;
    SPI_Initializes(SPI_MASTER, &SPI_InitStructure);
    SPI_SS_Output_Enable(SPI_MASTER);
    /* SPI_SLAVE configuration ------------------------------------------------------*/
    SPI_InitStructure.SpiMode = SPI_MODE_SLAVE;
    SPI_InitStructure.DataDirection = SPI_DIR_SINGLELINE_RX;
    SPI_Initializes(SPI_SLAVE, &SPI_InitStructure);
    /* Enable the master and slave SPI interrupts ----------------------------------*/
    SPI_I2S_Interrupts_Enable(SPI_MASTER, SPI_I2S_INT_TE);
    SPI_I2S_Interrupts_Enable(SPI_SLAVE, SPI_I2S_INT_RNE);
    /* Enable SPI_SLAVE */
    SPI_ON(SPI_SLAVE);
    /* Enable SPI_MASTER */
    SPI_ON(SPI_MASTER);
    /* Transfer procedure */
    while (RxIdx < BufferSize);
    /* Check the received data with the send ones */
    TransferStatus = Buffercmp(SPI_Slave_Buffer_Rx, SPI_Master_Buffer_Tx, BufferSize);
    if(TransferStatus == PASSED) {
        log_info("Test PASS!\r\n");
    } else {
        log_info("Test ERR!\r\n");
    TxIdx = 0;
    RxIdx = 0;
    SPI_I2S_Data_Transmit(SPI1, SPI_Master_Buffer_Tx[0]);
    while(1) {
        while (RxIdx < 1);
        // 为了测试发送速度,不断重复发送
        TxIdx = 0;
        RxIdx = 0;
中断处理被改为:
*\*\name    SPI1_IRQHandler.
*\*\fun     This function handles SPI1 Handler.
*\*\param   none
*\*\return  none
void SPI1_IRQHandler(void) {
    if(SPI_I2S_Interrupt_Flag_Status_Get(SPI1, SPI_I2S_INT_FLAG_TE) != RESET) {
        /* Send SPI_MASTER data */
        SPI_I2S_Data_Transmit(SPI1, SPI_Master_Buffer_Tx[TxIdx++]);
        if(TxIdx == BufferSize) {
            /* Disable SPI_MATER TXE interrupt */
            //SPI_I2S_Interrupts_Disable(SPI1, SPI_I2S_INT_TE);
*\*\name    SPI2_IRQHandler.
*\*\fun     This function handles SPI2 Handler.
*\*\param   none
*\*\return  none
void SPI2_IRQHandler(void) {
    if(SPI_I2S_Interrupt_Flag_Status_Get(SPI2, SPI_I2S_INT_FLAG_RNE) == SET) {
        /* Store SPI_SLAVE received data */
        SPI_Slave_Buffer_Rx[RxIdx++] = SPI_I2S_Data_Get(SPI2);
然后测试,捕捉的通讯SCK脉冲波形如下:
波形不是方波,时钟周期是120ns的样子,确实比用GPIO模拟的方式快啊,差别很明显。
weifeng90| | 2024-4-7 19:27 | 只看该作者
这肯定的啊,软件模拟怎么能比硬件快。
suncat0504|  楼主 | 2024-4-7 22:26 | 只看该作者
weifeng90 发表于 2024-4-7 19:27
这肯定的啊,软件模拟怎么能比硬件快。
确实快,但是时钟波形和预想的方波差太多了。差点以为自己的示波器出了问题。哈哈哈。
chenqianqian| | 2024-4-8 07:57 | 只看该作者
因为SPI是边沿采样捕获数据
这要是驱动屏幕效果也是不错的
黑心单片机| | 2024-4-10 15:03 | 只看该作者
在用这款,巨好用
认证:大连伊飞特信息技术有限公司软件工程师
简介:本人于1993年毕业于大连理工大学。毕业后从事单片机开发工作5年,之后转入软件开发工作至今。
88
