qtopia的笔记 https://bbs.21ic.com/?584104 [收藏] [复制] [RSS]
日志
昨天把上篇日志中的问题解决了……
已有 3104 次阅读2009-7-3 10:29 |系统分类:嵌入式系统
   第一个问题:
PCY2410 # nand write.yaffs 32000000 300000 2800000
NAND write: device 0 offset 0x300000, size 0x2800000
Input block length is not page aligned
Data did not fit into device, due to bad blocks
41943040 bytes written: ERROR
    就是因为上面的2800000没有对齐。yaffs文件系统的block大小为512+16,因此需要对齐。直接使用$(filesize)代替2800000就可以解决这个问题。
    这个问题解决了,第二个问题也就解决了。
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
VFS: Mounted root (yaffs filesystem).
Freeing init memory: 128K
Warning: unable to open an initial console.
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.
    下面是我昨晚弄好Linux后的完整的启动界面。
U-Boot 1.1.6 (Feb 18 2009 - 21:58:05)
DRAM:  64 MB
Flash: 512 kB
NAND:  64 MiB
In:    serial
Out:   serial
Err:   serial
Hit any key to stop autoboot:  0
NAND read: device 0 offset 0x100000, size 0x200000
2097152 bytes read: OK
## Booting image at 30007fc0 ...
   Image Name:   Linux-2.6.22.6
   Created:      2009-02-26  12:13:39 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1530276 Bytes =  1.5 MB
   Load Address: 30008000
   Entry Point:  30008000
   Verifying Checksum ... OK
OK
Starting kernel ...
Uncompressing Linux.................................................................................................... done, booting the kern.
Linux version 2.6.22.6 (root@localhost.localdomain) (gcc version 3.4.5) #5 Thu Feb 26 20:12:32 CST 2009
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=00007177
Machine: SMDK2410
Memory policy: ECC disabled, Data cache writeback
CPU S3C2410A (id 0x32410002)
S3C2410: core 200.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists.  Total pages: 16256
Kernel command line: noinitrd console=ttySAC0 root=/dev/mtdblock2 rootfstype=yaffs
irq: clearing pending ext status 00000200
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
timer tcon=00500000, tcnt a2c1, tcfg 00000200,00000000, usec 00001eb8
Console: colour dummy device 80x30
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61616KB available (2824K code, 307K data, 128K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2410: Initialising architecture
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
yaffs Feb 18 2009 22:32:31 Installing.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
s3c2410-lcd s3c2410-lcd: no platform data for lcd, cannot attach
s3c2410-lcd: probe of s3c2410-lcd failed with error -22
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
s3c2410-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2410
s3c2410-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2410
s3c2410-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2410
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: module loaded
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand s3c2410-nand: Tacls=3, 30ns Twrph0=7 70ns, Twrph1=3 30ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 4 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00100000 : "U-Boot"
0x00100000-0x00300000 : "Kernel"
0x00300000-0x02b00000 : "yaffs"
0x02b00000-0x04000000 : "jffs2"
usbmon: debugfs is not available
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-i2c s3c2410-i2c: slave address 0x10
s3c2410-i2c s3c2410-i2c: bus frequency set to 390 KHz
s3c2410-i2c s3c2410-i2c: i2c-0: S3C I2C adapter
TCP cubic registered
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
init started: BusyBox v1.7.0 (2009-02-24 21:27:36 CST)
starting pid 732, tty '': '/etc/init.d/rcS'
ifconfig: SIOCSIFADDR: No such device
mount: can't find ??–a in /etc/fstab
Please press Enter to activate this console.
starting pid 737, tty '/dev/ttySAC0': '/bin/sh'
# ls
bin         home        lost+found  root        tmp
dev         lib         mnt         sbin        usr
etc         linuxrc     proc        sys         var
# ls
pcy.c
    其中,pcy.c是我在usr目录下建立的一个简单的C文件。下面是我截取的几张图片。
路过
鸡蛋
鲜花
握手
雷人
发表评论 评论 (1 个评论)
回复 lop 2009-7-24 07:48
恭喜……
