[ZLG-MCU]
IAR调试.s文件遇到问题,求助
2907|3
seeokok|  楼主 | 2009-6-3 10:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
chrainbow| | 2009-8-15 21:53 | 只看该作者
不知楼主的问题解决了没有,我这有个方法,请楼主试试。
我试了是可以的。
这个问题只是在IAR ARM5.4中才有,5.2的就没有。
OS_CPU_PendSVHandler
    CPSID   I                                                   ; Prevent interruption during context switch
    MRS     R0, PSP                                             ; PSP is process stack pointer
    CBZ     R0, OS_CPU_PendSVHandler_nosave                     ; Skip register save the first time
    SUBS    R0, R0, #0x20                                       ; Save remaining regs r4-11 on process stack
    STM     R0, {R4-R11}
    LDR     R1, =OSTCBCur                                       ; OSTCBCur->OSTCBStkPtr = SP;
    LDR     R1, [R1]
    STR     R0, [R1]                                            ; R0 is SP of process being switched out
    ;加入下面的这个"THUMB"就可以了
    THUMB
        ; At this point, entire context of process has been saved
    PUSH    {R14}                                               ; Save LR exc_return value
    LDR     R0, =OSTaskSwHook                                   ; OSTaskSwHook();
    BLX     R0
    POP     {R14}
    LDR     R0, =OSPrioCur                                      ; OSPrioCur = OSPrioHighRdy;
    LDR     R1, =OSPrioHighRdy
    LDRB    R2, [R1]
    STRB    R2, [R0]
    LDR     R0, =OSTCBCur                                       ; OSTCBCur  = OSTCBHighRdy;
    LDR     R1, =OSTCBHighRdy
    LDR     R2, [R1]
    STR     R2, [R0]
    LDR     R0, [R2]                                            ; R0 is new process SP; SP = OSTCBHighRdy->OSTCBStkPtr;
    LDM     R0, {R4-R11}                                        ; Restore r4-11 from new process stack
    ADDS    R0, R0, #0x20
    MSR     PSP, R0                                             ; Load PSP with new process SP
    ORR     LR, LR, #0x04                                       ; Ensure exception return uses process stack
    CPSIE   I
    BX      LR                                                  ; Exception return will restore remaining context
    END
linhai1986| | 2009-8-16 23:19 | 只看该作者
不错,学习了
xiaoxin1986| | 2009-8-17 18:00 | 只看该作者
学习了
