请问各位:PWM输出问题???
1698|8
bhsdlmj|  楼主 | 2009-5-12 20:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
库3.0给的例子PWM_Output中,main.c中有函数
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
我将GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;改为
GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0 | GPIO_Pin_1;
为什么看不到pin0和pin1的波形??
难道只有pin6和pin7这两个管脚可以使用PWM1模式么?
bhsdlmj|  楼主 | 2009-5-12 20:21 | 只看该作者
请问TIM2 TIM4可以用么PWM1方式输出么?
bhsdlmj|  楼主 | 2009-5-12 21:40 | 只看该作者
自己顶一下,哪位同仁有时间的话 指点一下
bhsdlmj|  楼主 | 2009-5-12 22:04 | 只看该作者
程序如下!
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
uint16_t CCR1_Val = 500;
uint16_t CCR2_Val = 250;
uint16_t CCR3_Val = 250;
uint16_t CCR4_Val = 125;
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program
  * @param  None
  * @retval : None
int main(void)
  /* System Clocks Configuration */
  RCC_Configuration();
  /* GPIO Configuration */
  GPIO_Configuration();
    TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
    TIM3CLK = 36 MHz, Prescaler = 0x0, TIM3 counter clock = 36 MHz
    TIM3 ARR Register = 999 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
    TIM3 Frequency = 36 KHz.
    TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
    TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
    TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
    TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM3, ENABLE);
  /* TIM3 enable counter */
  TIM_Cmd(TIM3, ENABLE);
  while (1)
  * @brief  Configures the different system clocks.
  * @param  None
  * @retval : None
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/4 */
    RCC_PCLK1Config(RCC_HCLK_Div4);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  /* TIM3 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  * @brief  Configure the TIM3 Ouput Channels.
  * @param  None
  * @retval : None
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d ", file, line) */
  while (1)
#endif
渤海三叠浪| | 2009-5-13 09:22 | 只看该作者
关注中...........
lut1lut| | 2009-5-13 09:38 | 只看该作者
PA.0/1和TIM3又没有什么关系咯
渤海三叠浪| | 2009-5-13 10:41 | 只看该作者
请问楼上 你的这个图在哪个手册找到的???
lut1lut| | 2009-5-13 11:16 | 只看该作者
在数据手册中啊
一个参考手册<reference manual>
一个收据手册<data sheet>
必备啊!
渤海三叠浪| | 2009-5-13 12:24 | 只看该作者
哦 感谢楼上啊!!!!
忽视了data.sheet了
以前知道RM0008 和UM0427了!
