[STM32F4]
STM32F407ADC采样实验
634|4
最近公司又做了一款407的样板,正好需要用到407的ADC功能,需要用PC.2来检测RFID芯片的射频电源功率,首先看了下407的数据手册
可以配置到ADC1/2/3任何一个控制器的信道12上面.我打算将PC.2映射到ADC3上面和使用DMA功能,又看了下DMA的请求映射表,ADC3使用的DMA2的流0信道2
编程思路:
首先将DMA和IO以及ADC的时钟使能,其次将相应的IO配置成输入模式,最后配置DMA和ADC
注意
cowboy2014|  楼主 | 2015-9-26 07:34 | 只看该作者
/*定义ADC3的数据寄存器地址,DMA功能要用到外设的数据地址
*ADC3的数据地址为外设基地址+偏移地址,基地址在RM0090 Reference
*manual(参考手册)的地址映射表里,为0x40012200,ADC_DR
*偏移地址为0x4C,故实际地址为0x40012200+0x4C = 0x4001224C */
#define ADC3_DR_Address   ((uint32_t)0x4001224C)
代码详见:
void Adc3_Init(void)
                        /* Enable peripheral clocks ------------------------------------------------*/
                /* Enable DMA1 clock */
                RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
               RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE);
                GPIO_Configuration();
                DMA_Configuration();
void DMA_Configuration(void)
        ADC_InitTypeDef ADC_InitStructure;
  DMA_InitTypeDef DMA_InitStructure;
        ADC_CommonInitTypeDef ADC_CommonInitStructure;
  /* DMA2 Stream0 channel0 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_2;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC3_DR_Address;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  /* ADC Common Init **********************************************************/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  /* ADC3 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(ADC3, &ADC_InitStructure);
  /* ADC3 regular channel12 configuration *************************************/
  ADC_RegularChannelConfig(ADC3, ADC_Channel_12, 1, ADC_SampleTime_3Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
  ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
  /* Enable ADC3 DMA */
  ADC_DMACmd(ADC3, ENABLE);
  /* Enable ADC3 */
  ADC_Cmd(ADC3, ENABLE);
        /* Start ADC3 Software Conversion */
  ADC_SoftwareStartConv(ADC3);   //如果不是外部触发则必须软件开始转换
  * [url=home.php?mod=space&uid=247401]@brief[/url]  Configures the different GPIO ports.
  * @param  None
  * @retval None
void GPIO_Configuration(void)
  /* Configure PC.2 (ADC Channel2) PC.1 (ADC Channel1) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
cowboy2014|  楼主 | 2015-9-26 07:35 | 只看该作者
运行效果图片:
boy1990| | 2015-9-26 10:02 | 只看该作者
哈哈 看的不懂,楼主,这个主要是用来干嘛的呢?,,实现了哪些功能??
mmuuss586| | 2015-9-26 10:50 | 只看该作者
谢谢分享
