数组汇编之应用(增强内功的常规武器之一)
2965|2
 楼主| hotpower 发表于 2008-6-23 05:43 | 显示全部楼层 |阅读模式
1.中断向量表
#pragma DATA_SECTION("vectors")
uVectorEntry g_pfnVectors[32] = {
 ISR_Reset(),           //reset      0x0080 #0
 HotBIOS_ISR(Tsk_F_isr, 0, 1), //nmi        0x0084 #1
 HotBIOS_ISR(Tsk_F_isr, 0, 2), //sint17     0x0088 #2
 HotBIOS_ISR(Tsk_F_isr, 0, 3), //sint18     0x008c #3
 HotBIOS_ISR(Tsk_F_isr, 0, 4), //sint19     0x0090 #4
 HotBIOS_ISR(Tsk_F_isr, 0, 5), //sint20     0x0094 #5
 HotBIOS_ISR(Tsk_F_isr, 0, 6), //sint21     0x0098 #6
 HotBIOS_ISR(Tsk_F_isr, 0, 7), //sint22     0x009c #7
 HotBIOS_ISR(Tsk_F_isr, 0, 8), //sint23     0x00a0 #8
 HotBIOS_ISR(Tsk_F_isr, 0, 9), //sint24     0x00a4 #9
 HotBIOS_ISR(Tsk_F_isr, 0,10), //sint25     0x00a8 #10
 HotBIOS_ISR(Tsk_F_isr, 0,11), //sint26     0x00ac #11
 HotBIOS_ISR(Tsk_F_isr, 0,12), //sint27     0x00b0 #12
 HotBIOS_ISR(Tsk_F_isr, 0,13), //sint28     0x00b4 #13
 HotBIOS_ISR(Tsk_F_isr, 0,14), //sint29     0x00b8 #14
 HotBIOS_ISR(Tsk_F_isr, 0,15), //sint30     0x00bc #15
 HotBIOS_ISR(Tsk_F_isr, 0,16), //int0       0x00c0 #16
 HotBIOS_ISR(Tsk_F_isr, 0,17), //int1       0x00c4 #17
 HotBIOS_ISR(Tsk_F_isr, 0,18), //int2       0x00c8 #18
 HotBIOS_ISR(Tsk_F_isr, 0,19), //tint       0x00cc #19
 HotBIOS_ISR(Tsk_F_isr, 0,20), //rint0      0x00d0 #20
 HotBIOS_ISR(Tsk_F_isr, 0,21), //xint0      0x00d4 #21
 HotBIOS_ISR(Tsk_F_isr, 0,22), //rint1      0x00d8 #22
 HotBIOS_ISR(Tsk_F_isr, 0,23), //xint1      0x00dc #23
 HotBIOS_ISR(Tsk_F_isr, 0,24), //int3       0x00e0 #24
 HotBIOS_ISR(Tsk_F_isr, 0,25), //hpint      0x00e4 #25
 HotBIOS_ISR(Tsk_F_isr, 0,26), //           0x00e8 #26
 HotBIOS_ISR(Tsk_F_isr, 0,27), //           0x00ec #27
 HotBIOS_ISR(Tsk_F_isr, 0,28), //           0x00f0 #28
 HotBIOS_ISR(Tsk_F_isr, 0,29), //           0x00f4 #29
 HotBIOS_ISR(Tsk_F_isr, 0,30), //           0x00f8 #30
 HotBIOS_ISR(Tsk_F_isr, 0,31) //           0x00fc #31
#define ISR_Reset()   {
                      ASMCodeArrayAEx(ASMCODE_BD_K, (pfnVectorEntry)c_int00),
                      ASMCodeArrayEx(ASMCODE_LD_K_SP, 0x200u)
#define ISR_Return()  {
                        ASMCode16i(ASMCODE_RETE),
                        ASMCode16((pfnVectorEntry)ASMCODE_NOP),
                        ASMCode16i(ASMCODE_NOP),
#define ISR_Default() {
                        ASMCodeArrayAEx(ASMCODE_BD_K, (pfnVectorEntry)DefaultIsr),
#define ISR(addr)     {
                        ASMCodeArrayAEx(ASMCODE_BD_K, (pfnVectorEntry)addr),
2.数组汇编
typedef void (*ASMCodeArray_FPtr)(void);//定义数组可执行汇编的函数指针
int main(void)
HotBIOS_State iState;
TI_IREG AsmCodeArray_IsrFunction[]=//汇编数组首地址实际为汇编入口地址
{//下面的"数据"实际为汇编代码
 ASMCode16i(ASMCODE_POPM_A),//psha
// ASMCodeArrayEx(ASMCODE_B_K, Tsk_F_isr),//b Tsk_F_isr
    __asm_goto__(Tsk_F_isr),
 ASMCodeArray(ASMCODE_LD_k_A, 0x01u),//ld #1, a
TI_IREG AsmCodeArray_Function[]=//汇编数组首地址实际为汇编入口地址
{//下面的"数据"实际为汇编代码
 ASMCode16i(ASMCODE_PSHM_A),//psha
//bd xxxh ->loop
// ASMCodeArrayEx(ASMCODE_BD_K, &AsmCodeArray_IsrFunction[1]),//bd AsmCodeArray_IsrFunction
// ASMCodeArrayEx(ASMCODE_B_K, &AsmCodeArray_IsrFunction[1]),//bd AsmCodeArray_IsrFunction
    __asm_goto__(&AsmCodeArray_IsrFunction[1]),
//声明函数指针ASMCodeExec来实际运行数组内的汇编代码
ASMCodeArray_FPtr ASMCodeExec = (ASMCodeArray_FPtr)AsmCodeArray_Function;
 ASMCodeExec();//调用数组内的汇编代码
3.在MCU/ARM/DSP上实现动态链接
哈哈~~数组要比代码好管理(删除,移动,变换,加密等等)的多~~~
DSX_STM32 发表于 2008-6-23 11:32 | 显示全部楼层
请hotpower帮个忙
请您写一篇关于 ARM Cortex-M3 启动代码及其执行过程的大作!
******不胜感激!
 楼主| hotpower 发表于 2008-6-23 12:45 | 显示全部楼层
很对不起DSX_STM32同志,菜农正在闭关修炼,"人间鲜果俺快找到
