有错!!!!
1403|2
cunwmy|  楼主 | 2009-3-8 00:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TE, USB, AC, DAC, ST
extern BYTE SOF_Flag;
BYTE  Count;
BYTE  OutReport[2];
//unsigned char Power
void main() {
    M8C_EnableGInt;
    USB_Start(0,USB_5V_OPERATION);
    DAC8_Start(DAC8_HIGHPOWER);
    DAC8_1_Start(DAC8_1_HIGHPOWER);
    DAC8_1_WriteBlind(0);
    while (!USB_bGetConfiguration());
    USB_INT_REG |= USB_INT_SOF_MASK;
    USB_EnableOutEP(4);
    while(1) {
        if (SOF_Flag) {
            SOF_Flag = 0;
            if (USB_bGetEPAckState(4))
                Count = USB_bReadOutEP(4, OutReport, 2);
                DAC8_WriteBlind(OutReport);
                USB_EnableOutEP(4);
编译出错:
!EC:\Documents and Settings\Administrator\桌面\w6\w6\main.c(40): type error in argument 1 to `DAC8_WriteBlind'; found `pointer to unsigned char' expected `unsigned char'
C:\PROGRA~1\Cypress\Common\CY3E64~1\tools\make: *** [obj/main.o] Error 1
yuxyoo| | 2009-3-8 13:25 | 只看该作者
代码里
统一DAC8_1 和DAC8为其中的一个就好了
ni_labview| | 2009-3-8 23:14 | 只看该作者
DAC8_WriteBlind(OutReport);好像有问题
应该是DAC8_WriteBlind(OutReport[0]);
或者是DAC8_WriteBlind(OutReport[1]);
