[PIC®/AVR®/dsPIC®产品] PIC18驱动LCD 5110屏幕不显示东西是怎么回事啊?
1519|4
 楼主| 15907726754 发表于 2016-1-13 19:00 | 显示全部楼层 |阅读模式
如题,屏幕会亮但是没有显示,求大神看看程序!
#define uint unsigned int
#define uchar unsigned char
#define res     PORTCbits.RC5
#define sce     PORTCbits.RC4        //片选PORTAbits.RA0
#define dc      PORTCbits.RC3         //1些数据,0写指令
#define sdin    PORTCbits.RC6         //数据
#define sclk    PORTCbits.RC7         //时钟
void LCD_init(void);
void init(void);
void LCD_write_byte(unsigned char dt,unsigned char command);
void delay(uint x);
void LCD_set_XY(unsigned char X,unsigned char Y);
void LCD_clear(void);
void LCD_write_char(unsigned char x,unsigned char y,unsigned char c);
void LCD_write_english_string(unsigned char X,unsigned char Y,char *s);
void main(void)
    init();
    LCD_init();//初始化LCD模块
    LCD_clear();//清屏
    while(1)
          LCD_write_english_string(0,0," Welcome to  ");
        LCD_write_english_string(0,1," Amy  studio ");
        LCD_write_english_string(0,2,"amy-studio.com");
        LCD_write_english_string(0,3," Nokia5110 LCD");
//    while(1)
//        asm("CLRWDT");
void init(void)  //单片机初始化
    asm("CLRWDT");
    ADCON1=0x06;
    TRISC=0x00;
    PORTB=0x00;
    unsigned char i;
    sce = 0;        //片选
    dc = command;   //1写数据,0写指令
    for(i=0;i<8;i++) //循环传送8个bit
        if(dt&0x80)
            sdin=1;
        else
            sdin=0;
        dt=dt<<1;
        sclk = 0;
        asm("CLRWDT");
        asm("CLRWDT");
        sclk=1;     //在时钟上升沿采样
    dc=1;
    sce=1;
    sdin=1;
void LCD_init(void)     //LCD初始化
    res=0;
    delay(10);
    res=1;
    sce=0;      //sce为高时,串行口被初始化。sce为高时忽略始时钟信号。
    delay(10);
    sce=1;
    LCD_write_byte(0x21,0);//0b0010 0001LCD功能设置:芯片活动,水平寻址,使用扩展指令
    LCD_write_byte(0xc6,0);//设置VOP值
    LCD_write_byte(0x06,0);//温度校正
    LCD_write_byte(0x13,0);//1:48
    LCD_write_byte(0x20,0);//LCD功能设置:新品活动,水平寻址,使用基本指令
    LCD_clear();
    LCD_write_byte(0x0c,0);//设定显示配置:普通模式
    sce=0;
void LCD_set_XY(unsigned char X,unsigned char Y)// 位置选择
    LCD_write_byte(0x40|Y,0);
    LCD_write_byte(0x80|X,0);
void LCD_clear(void)    //清屏
    unsigned char t;
    unsigned char k;
    LCD_set_XY(0,0);
    for(t=0;t<6;t++)
        for(k=0;k<84;k++)
            LCD_write_byte(0x00,1);
            asm("CLRWDT");
void LCD_write_char(unsigned char x,unsigned char y,unsigned char c)//写数据
    unsigned char line;
    c -= 32;
    LCD_set_XY(x*6,y);
    for(line=0;line<6;line++)
        LCD_write_byte(font6x8[c][line],1);
void delay(uint x)//延时程序
    uint a,b;
    for(a=x;a>0;a--)
        for(b=110;b>0;b--);
    LCD_set_XY(X,Y);
    while(*s)
        LCD_write_char(X,Y,*s);
        s++;
 楼主| 15907726754 发表于 2016-1-13 22:07 | 显示全部楼层
沉下去了!!!
JY-DX-JY 发表于 2016-1-14 12:56 | 显示全部楼层
多半时序的问题。
mzb2012 发表于 2016-1-14 22:06 | 显示全部楼层
1.确保硬件焊接,没问题
2.对于PIC单片机 LAT是输出口,PORT是输入口,建议更改
3.时序可参考我项目的例程,欧了
你没找死啊 发表于 2017-9-11 23:45 | 显示全部楼层
1.确保硬件焊接,没问题
3.时序可参考我项目的例程 ...
还有呢?中文显示要如何写?
