[其他ST产品]
STR710 下载提示FLASH下载有问题
1723|0
lindream|  楼主 | 2009-8-14 10:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ST, flash, TE, AD, ni
IAR + IAR j-link download出错!
请问怎么解决,以前都是好好的,最近一批板子下载不了!
Sun Apr 29 15:51:45 2007: J-Link firmware: V1.20 (J-Link compiled Mar 22 2007 16:08:22 ARM Rev.5)
Sun Apr 29 15:51:45 2007: JTAG speed is initially set to: 32 kHz
Sun Apr 29 15:51:45 2007: Resetting target using RESET pin
Sun Apr 29 15:51:45 2007: HARDWARE reset with strategy 0 was performed
Sun Apr 29 15:51:45 2007: Initial reset was performed
Sun Apr 29 15:51:45 2007: J-Link found 1 JTAG DEVICE. ARM core Id: 3F0F0F0F(ARM7)
Sun Apr 29 15:51:45 2007: DEVICE at TAP0 selected
Sun Apr 29 15:51:45 2007: Auto JTAG speed: 8000 kHz
Sun Apr 29 15:51:46 2007: 688 bytes downloaded and verified (1.13 Kbytes/sec)
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080C8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080CC
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080D0
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080D2
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080E8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008128
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000812C
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008130
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008132
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008150
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008158
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000815A
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008160
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000817D
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008180
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008182
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000081A4
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008242
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008001
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008004
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008038
Sun Apr 29 15:51:46 2007: There were warnings during download, see Log Window
