是STR710坏了还是什么原因,J-Link下载出错
1533|0
lindream|  楼主 | 2009-8-14 15:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
IAR + IAR j-link download出错! 请问怎么解决,以前都是好好的,最近一批板子下载不了! Sun Apr 29 15:51:45 2007: J-Link firmware: V1.20 (J-Link compiled Mar 22 2007 16:08:22 ARM Rev.5) Sun Apr 29 15:51:45 2007: JTAG speed is initially set to: 32 kHz Sun Apr 29 15:51:45 2007: Resetting target using RESET pin Sun Apr 29 15:51:45 2007: HARDWARE reset with strategy 0 was performed Sun Apr 29 15:51:45 2007: Initial reset was performed Sun Apr 29 15:51:45 2007: J-Link found 1 JTAG DEVICE. ARM core Id: 3F0F0F0F(ARM7) Sun Apr 29 15:51:45 2007: DEVICE at TAP0 selected Sun Apr 29 15:51:45 2007: Auto JTAG speed: 8000 kHz Sun Apr 29 15:51:45 2007: Auto JTAG speed: 8000 kHz Sun Apr 29 15:51:46 2007: 688 bytes downloaded and verified (1.13 Kbytes/sec) Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080C8 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080CC Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080D0 Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080D2
