28335外部接口XINTF无法写入数据
3888|16
 楼主| vazer 发表于 2016-4-13 20:29 | 显示全部楼层 |阅读模式
这两天在学DSP28335的XINTF,用的TI官方的默认配置。
void InitXintf(void)
    EALLOW;
    XintfRegs.XINTCNF2.bit.XTIMCLK = 1;
    // No write buffering
    XintfRegs.XINTCNF2.bit.WRBUFF = 0;
    // XCLKOUT is enabled
    XintfRegs.XINTCNF2.bit.CLKOFF = 0;
    // XCLKOUT = XTIMCLK/2
    XintfRegs.XINTCNF2.bit.CLKMODE = 1;
    XintfRegs.XTIMING0.bit.XWRLEAD = 3;
    XintfRegs.XTIMING0.bit.XWRACTIVE = 7;
    XintfRegs.XTIMING0.bit.XWRTRAIL = 3;
    // Zone read timing
    XintfRegs.XTIMING0.bit.XRDLEAD = 3;
    XintfRegs.XTIMING0.bit.XRDACTIVE = 7;
    XintfRegs.XTIMING0.bit.XRDTRAIL = 3;
    // double all Zone read/write lead/active/trail timing
    XintfRegs.XTIMING0.bit.X2TIMING = 1;
    // Zone will sample XREADY signal
    XintfRegs.XTIMING0.bit.USEREADY = 1;
    XintfRegs.XTIMING0.bit.READYMODE = 1;  // sample asynchronous
    XintfRegs.XTIMING0.bit.XSIZE = 3;
    XintfRegs.XTIMING6.bit.XWRLEAD = 3;
    XintfRegs.XTIMING6.bit.XWRACTIVE = 7;
    XintfRegs.XTIMING6.bit.XWRTRAIL = 3;
    // Zone read timing
    XintfRegs.XTIMING6.bit.XRDLEAD = 3;
    XintfRegs.XTIMING6.bit.XRDACTIVE = 7;
    XintfRegs.XTIMING6.bit.XRDTRAIL = 3;
    XintfRegs.XTIMING6.bit.X2TIMING = 1;
    XintfRegs.XTIMING6.bit.USEREADY = 1;
    XintfRegs.XTIMING6.bit.READYMODE = 1;  // sample asynchronous
    XintfRegs.XTIMING6.bit.XSIZE = 3;
    XintfRegs.XTIMING7.bit.XWRLEAD = 3;
    XintfRegs.XTIMING7.bit.XWRACTIVE = 7;
    XintfRegs.XTIMING7.bit.XWRTRAIL = 3;
    // Zone read timing
    XintfRegs.XTIMING7.bit.XRDLEAD = 3;
    XintfRegs.XTIMING7.bit.XRDACTIVE = 7;
    XintfRegs.XTIMING7.bit.XRDTRAIL = 3;
    XintfRegs.XTIMING7.bit.X2TIMING = 1;
    XintfRegs.XTIMING7.bit.USEREADY = 1;
    XintfRegs.XTIMING7.bit.READYMODE = 1;  // sample asynchronous
    XintfRegs.XTIMING7.bit.XSIZE = 3;
    XintfRegs.XBANK.bit.BANK = 7;
    XintfRegs.XBANK.bit.BCYC = 7;
    EDIS;
   InitXintf16Gpio();
   asm(" RPT #7 || NOP");
定义了三个地址如下:
#define        ZONE7 (*((volatile  Uint16 *)0x200000))
#define ZONE6_1 (*((volatile  Uint16 *)0x100001))
#define          VO0        (*((volatile  Uint16 *)0x4010))
然后在主程序中分别给他们赋值:
           ZONE7 = 0x7532;
           ZONE6_1 = 0x4321;
           VO0 = 0x4567;
结果发现只有ZONE7对应地址的存储器写入了数据,而zone0和zone6无法写入。
所以想请问一下是不是我这样操作有问题?该如何正确操作这3个zone?
zhangmangui 发表于 2016-4-13 22:13 | 显示全部楼层
0x200000应该属于外扩存储区啊    你看看有没有外扩存储芯片啊
有的话就可以进行操作
zhangmangui 发表于 2016-4-13 22:14 | 显示全部楼层
zhangmangui 发表于 2016-4-13 22:17 | 显示全部楼层
这个主要要看你的映射区有没有外扩SDRAM等没
 楼主| vazer 发表于 2016-4-14 17:00 | 显示全部楼层
经过反复查找问题我发现其实XINTF只要用默认的配置,然后对各zone的地址进行操作就对了,但是通过memory只能看到zone7的存储器有变化而zone0和zong6一直是FFFF。我之前之所以认为写不进存储器是因为在memory中看不到数据的变化。
 楼主| vazer 发表于 2016-4-14 17:23 | 显示全部楼层
zone7在memory里能看到是不是因为我zone7连接了一个外部SRAM?
tongbu2015 发表于 2016-4-15 21:53 | 显示全部楼层
这个我表示还没用到的,支持
zhangbo1985 发表于 2016-4-16 10:50 | 显示全部楼层
先对照下芯片等硬件的,看你定义的地址是否有效?不同的芯片的内存地址是有差别的
firstblood 发表于 2016-4-16 21:26 | 显示全部楼层
这个我还没整过的,标识不清楚的。
chenci2013 发表于 2016-4-17 22:27 | 显示全部楼层
楼主问题解决了吗
Garen2 发表于 2016-4-18 23:05 | 显示全部楼层
映射区有没有外扩SDRAM
 楼主| vazer 发表于 2016-4-20 15:16 | 显示全部楼层
楼主问题解决了吗
我这里数据通信是没问题了
 楼主| vazer 发表于 2016-4-20 15:18 | 显示全部楼层
映射区有没有外扩SDRAM
我外扩的SRAM是通过Zone7来连接的
FireRiver9 发表于 2016-4-22 19:26 | 显示全部楼层
定义的地址是否有效
豆腐块 发表于 2016-4-27 21:35 | 显示全部楼层
外扩的SRAM是通过Zone7来连接的
映射区能否找到
dididi112233 发表于 2020-6-4 17:13 | 显示全部楼层
楼主你做的事与FPGA的通信吗  我看你对变量写数据  你怎么从FPGA读取这个地址了 怎么实现的能说一下吗
