动态改变占空比 加上刹车功能就有问题
4610|8
 楼主| selina1983 发表于 2009-12-31 17:38 | 显示全部楼层 |阅读模式
我做了一个动态改变占空比的程序  现在要加上刹车功能  故障时封锁SPWM输出
但是我一使能刹车   SPWM就出不来
高手帮忙看一下  我哪设置不对吗
修给占空比我是在 TIM5的中断中做的
void Timeconfig(void)
/* Time Base configuration */
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1 ;
  TIM_TimeBaseStructure.TIM_Period = TIM1_Period;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  //TIM_ARRPreloadConfig(TIM1, ENABLE);
  /* Channel 1,  Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 680;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  //死区设置
  TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
  TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
  TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
  TIM_BDTRInitStructure.TIM_DeadTime = 20;  //这里调整死区大小0-0xff
  TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;
  TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;
  TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
  TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
  //启用CCR1寄存器的影子寄存器(直到产生更新事件才更改设置)
  //TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Disable);
  //TIM1_OC2模块设置(设置2通道占空比)
  TIM_OC2Init(TIM1, &TIM_OCInitStructure);
  //启用CCR2寄存器的影子寄存器(直到产生更新事件才更改设置)
  //TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  TIM_TimeBaseStructure.TIM_Prescaler= 0;
  TIM_TimeBaseStructure.TIM_CounterMode= TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_Period= 4000;
  TIM_TimeBaseStructure.TIM_ClockDivision= 0;
  TIM_TimeBaseInit( TIM5, &TIM_TimeBaseStructure );
  TIM_ITConfig( TIM5, TIM_IT_Update, ENABLE );
  TIM_Cmd( TIM5, ENABLE );
  TIM_TimeBaseStructure.TIM_Prescaler= 719;
  TIM_TimeBaseStructure.TIM_Period= 20;
  TIM_TimeBaseInit( TIM3, &TIM_TimeBaseStructure );
  TIM_SelectOutputTrigger( TIM3, TIM_TRGOSource_Update );// ADC Trigger  5KHz
  TIM_Cmd( TIM3, ENABLE );
  /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* TIM1 Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
 楼主| selina1983 发表于 2009-12-31 17:43 | 显示全部楼层
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
时  出来的SPWM只有180度的有
hsbjb 发表于 2010-1-2 16:29 | 显示全部楼层
你使能了刹车,此时应该是不需要输出PWM吧
 楼主| selina1983 发表于 2010-1-16 13:06 | 显示全部楼层
是的  现在问题解决了   硬件没有上拉电阻
txcy 发表于 2010-1-16 21:44 | 显示全部楼层
哪个需要上拉?
baidudz 发表于 2010-1-16 22:08 | 显示全部楼层
嗯,楼主还是说具体点,对我们也有点帮助
 楼主| selina1983 发表于 2010-1-31 11:38 | 显示全部楼层
就是刹车引脚
sz_Ban 发表于 2010-1-31 17:03 | 显示全部楼层
刹车的时候,就是把电机的2端都接地.可以刹的很死!!!注意别把电源和地短了
sinadz 发表于 2010-2-1 16:44 | 显示全部楼层
???不是很明白
