[DemoCode下载]
WDT_TimeoutINT定时器超时中断
959|5
gejigeji521|  楼主 | 2016-10-29 19:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 15/02/06 10:23a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Implement periodic WDT time-out interrupt event.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M058S.h"
#define PLL_CLOCK           50000000
/* Global Interface Variables Declarations        */
volatile uint8_t g_u8IsWDTTimeoutINT = 0;
* @brief       IRQ Handler for WDT and WWDT Interrupt
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The WDT_IRQHandler is default IRQ of WDT and WWDT, declared in startup_M058S.s.
void WDT_IRQHandler(void)
    if(WDT_GET_TIMEOUT_INT_FLAG() == 1)
        /* Clear WDT time-out interrupt flag */
        WDT_CLEAR_TIMEOUT_INT_FLAG();
        g_u8IsWDTTimeoutINT = 1;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz and LIRC 10KHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk);
    /* Waiting for external XTAL and LIRC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC10K_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(WDT_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(WDT_MODULE, CLK_CLKSEL1_WDT_S_LIRC, 0);
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD, TXD */
    SYS->P3_MFP = SYS_MFP_P30_RXD | SYS_MFP_P31_TXD;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    uint32_t u32IntCnts = 0;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+---------------------------------------+\n");
    printf("|    WDT Time-out Period Sample Code    |\n");
    printf("+---------------------------------------+\n\n");
    printf("# WDT Settings:\n");
    printf("  Clock source is 10 kHz; Enable interrupt; Time-out interval is 2^14 * WDT clock.\n");
    printf("# When WDT statr counting, system will generate a WDT time-out interrupt after 1.6384 ~ 1.7408 s.\n");
    printf("  Measure P0.0 period time to check time-out interval.\n\n");
    /* Use P0.0 to check time-out period time */
    GPIO_SetMode(P0, 0, GPIO_PMD_OUTPUT);
    P00 = 1;
    P00 = 0;
    /* Because of all bits can be written in WDT Control Register are write-protected;
       To program it needs to disable register protection first. */
    SYS_UnlockReg();
    /* Select WDT time-out interval to 2^14 * WDT clock then start WDT counting */
    WDT_Open(WDT_TIMEOUT_2POW14, 0, FALSE, FALSE);
    /* Enable WDT interrupt function */
    WDT_EnableInt();
    /* Enable WDT NVIC */
    NVIC_EnableIRQ(WDT_IRQn);
    while(1)
        /* Check if WDT time-out interrupt occurred or not */
        while(g_u8IsWDTTimeoutINT == 0);
        P00 ^= 1;
        printf("WDT time-out interrupt occurred. INT counts: %d      \r", ++u32IntCnts);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
捉虫天师| | 2016-10-30 12:50 | 只看该作者
关键在这里怎么配置。。
跟那个复位的很像,只不过这里第三个参数是FALSE。
huangcunxiake| | 2016-10-30 15:19 | 只看该作者
  • void WDT_IRQHandler(void)
  •     if(WDT_GET_TIMEOUT_INT_FLAG() == 1)
  •         /* Clear WDT time-out interrupt flag */
  •         WDT_CLEAR_TIMEOUT_INT_FLAG();
  •         g_u8IsWDTTimeoutINT = 1;
中断触发后,检测是不是这个看门狗超时中断,如果是,清楚中断标志,然后那个职位那个中断超时的变量。
643757107| | 2016-10-30 17:56 | 只看该作者
中断里对全局变量操作,在主函数对全局变量判断
heisexingqisi| | 2016-10-30 20:17 | 只看该作者
xuexi了,这些例程都是很经典的。
gejigeji521|  楼主 | 2016-11-12 22:51 | 只看该作者
都是官方提供的,肯定很经典。
