[STM32] 基于STM32F103上的232通讯问题
1852|5
 楼主| henyuyu123 发表于 2016-11-17 14:16 | 显示全部楼层 |阅读模式
我用232通讯,发现仿真时候,IO口接收不到数据。用示波器捕捉了下 MAX232的输出口  有时序的变化。想请问下大婶们  这个问题可能发生在什么位置,我以前是弄485的 232通讯是第一次用。不知道这两个在编程上面有什么区别?
void UART3_Init(unsigned short baudrate)
        USART_InitTypeDef USART_InitStructure;
//        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE);
//        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
//        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
//        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
//        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//推挽输出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
        USART_DeInit(USART3);
        USART_InitStructure.USART_BaudRate = baudrate;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;        //字长8
        USART_InitStructure.USART_StopBits = USART_StopBits_1;//1位停止位
        USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无流控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//打开rx跟tx功能
        USART_Init(USART3, &USART_InitStructure);//初始化
        USART_Cmd(USART3, ENABLE);//启动串口
        while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);
        USART_ClearFlag( USART3, USART_FLAG_TC );//发送完成标志
这个是配置口
这个是优先级配置
void NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        #ifdef  VECT_TAB_RAM
        NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
        #else
        NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
        #endif
          NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
          NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
          NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
          NVIC_Init(&NVIC_InitStructure);
          NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
//          NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
//          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
//          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
//          NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//          NVIC_Init(&NVIC_InitStructure);
//    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
//                NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0 ;
//    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
    USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
void SYS_Init(void)
        uchar i;
        IO_Init();        //将相关IO口初始化
        UART3_Init(9600);        //将串口3波特率设为9600,且将其初始化
        TIM2_Int_Init(10000-1,7200-1);//1s                   //将定时器2定时时间设为1秒,并将其初始化
        TIM3_Int_Init(208-1,72-1);//20ms/96                   //将定时器3定时时间设为20/96ms,并将其初始化
//        TIM4_Int_Init(10000-1,4800-1);//0.667s        //将定时器4定时时间设为0.667s
        NVIC_Configuration();        //设置中断嵌套优先级
        RTCInit();        //初始化RTC实时时钟,显示初始时间为2014年1月1日
        Iwdg_Init();        //初始化独立看门狗
        for(i=0;i<9;i++)
                power_rule[i]=0;
                power_Delay[i]=0;
 楼主| henyuyu123 发表于 2016-11-17 15:37 | 显示全部楼层
在仿真过程中,程序一直没有进到串口中断服务程序中。。。
void USART3_IRQHandler(void)
        unsigned char UART_BUF3;
        if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
                UART_BUF3 =USART_ReceiveData(USART3);
                if(POINT3==0)
                        if(UART_BUF3)
                                Rec_BUFDATA3[POINT3] = UART_BUF3;
                        POINT3++;
                else
                        POINT3++;
 楼主| henyuyu123 发表于 2016-11-17 16:14 | 显示全部楼层
怎么都木有人呢  我自己先顶下
gaocuntong 发表于 2016-11-18 14:49 | 显示全部楼层
编程上区别不大
硬件电路会有些不同
无外乎硬件电路
以及寄存器配置
这种问题只能一步步排除
 楼主| henyuyu123 发表于 2017-6-16 11:08 | 显示全部楼层
问题已经解决了,是我不小心将将中断定义错误
xyy211502 发表于 2020-4-25 22:02 | 显示全部楼层
加个QQ,有事请教,409320825
