[DemoCode下载]
N79E715系列中断使用方法
751|5
zhuotuzi|  楼主 | 2016-12-29 23:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technology Corp.
//  E-mail: MicroC-8bit@nuvoton.com
//  Application: Use interrupt service routine
//  Set individual flag of each interrupt to execute ISR .
//  Output : P0 show result
//           P1.4 flash when all interrupt pass
//           P2.1 flash when all interrupt pass
//           P0.7 flash when interrupt error
#include <stdio.h>
#include "N79E715.h"
#include "Typedef.h"
#include "Define.h"
#include "Common.h"
#include "Delay.h"
#include "ISR.h"
#include "Version.h"
bit EA_Save_bit;
void Interrupt_Error(void)
    while(1)
        P07 = 1;
        Delay1ms(500);
        P07 = 0;
        Delay1ms(500);
void main(void)
    uint16_t i;
    InitialUART0_Timer1(9600);                  // 9600 Baud Rate [url=home.php?mod=space&uid=72445]@[/url] 11.0592MHz
    Show_Version_Number_To_PC();
    printf ("\n*==========================================================================");
    printf ("\n*  N79E715 Series Interrupt Sample Code.");
    printf ("\n*==========================================================================\n");
    TR1 = 0;                                    //Stop Timer1 for Interrupt Demo
    IE   = 0x7F;
    EIE  = 0xFF;
    EA   = 1;
    //********************** INT0 Test ***********************
    P0 = 0xFF;
    IT0 = 1;
    set_IE0;                             // Trigger Interrupt
    PCON |= SET_BIT0;                    // Enter Idle Mode
    if(P0 != ~0x01)                      // Check ISR return value
        Interrupt_Error();
    for(i = 0 ; i < 60000 ; i++);        // Delay time
    //********************* Timer0 Test **********************
    P0 = 0xFF;
    set_TF0;                             // Trigger Interrupt
    if(P0 != ~0x02)                      // Check ISR return value
        Interrupt_Error();
    //********************** INT1 Test ***********************
    P0 = 0xFF;
    IT1 = 1;
    set_IE1;                             // Trigger Interrupt
    if(P0 != ~0x03)                      // Check ISR return value
        Interrupt_Error();
    //********************* Timer1 Test **********************
    P0 = 0xFF;
    set_TF1;                             // Trigger Interrupt
    if(P0 != ~0x04)                      // Check ISR return value
        Interrupt_Error();
    //********************** UART0 Test **********************
    P0 = 0xFF;
    set_RI;                              // Trigger Interrupt
    if(P0 != ~0x05)                      // Check ISR return value
        Interrupt_Error();
    //********************* Timer2 Test **********************
    P0 = 0xFF;
    set_TF2;                             // Trigger Interrupt
    /* Check ISR return value */
    if(P0 != ~0x06)                      // Check ISR return value
        Interrupt_Error();
    //********************** I2C Test ************************
    P0 = 0xFF;
    set_SI;                              // Trigger Interrupt
    if(P0 != ~0x07)                      // Check ISR return value
        Interrupt_Error();
    //********************** KBI Test ************************
    P0 = 0xFF;
    set_KBIF0;                           // Trigger Interrupt
    if(P0 != ~0x08)                      // Check ISR return value
        Interrupt_Error();
    //********************** BOD Test ************************
    P0 = 0xFF;
    set_BOF;                             // Trigger Interrupt
    if(P0 != ~0x09)                      // Check ISR return value
        Interrupt_Error();
    //********************** SPI Test ************************
    P0 = 0xFF;
    set_SPIF;
    if(P0 != ~0x0A)                      // Check ISR return value
        Interrupt_Error();
    //******************* Watch Dog Test *********************
    P0 = 0xFF;
    set_WDTF;                            // Trigger Interrupt
    if(P0 != ~0x0B)                      // Check ISR return value
        Interrupt_Error();
    //********************** ADC Test ************************/
    P0 = 0xFF;
    set_ADCI;                            // Trigger Interrupt
    if(P0 != ~0x0C)                      // Check ISR return value
        Interrupt_Error();
    //******************** Capture Test **********************
    P0 = 0xFF;
    set_CAPF0;                           // Trigger Interrupt
    if(P0 != ~0x0D)                      // Check ISR return value
        Interrupt_Error();
    //********************** PWM Test ************************
    P0 = 0xFF;
    set_BKF;                             // Trigger Interrupt
    if(P0 != ~0x0E)                      // Check ISR return value
        Interrupt_Error();
    EA = 0;                              // Disable all interrupt
    InitialUART0_Timer1(9600);           // 9600 Baud Rate @ 11.0592MHz
    printf("\nInterrupt Test OK!");
    while(1)
        P14 = 1;
        P21 = 1;
        Delay1ms(500);
        P14 = 0;
        P21 = 0;
        Delay1ms(500);
void INT0_ISR(void) interrupt 0          // Vector @  0x03
    P0 = 0xFF-1;
    clr_IE0;
void Timer0_ISR(void) interrupt 1        // Vector @  0x0B
    P0 = 0xFF-2;
    clr_TF0;
void INT1_ISR(void) interrupt 2          // Vector @  0x13
    P0 = 0xFF-3;
    clr_IE1;
void Timer1_ISR(void) interrupt 3        // Vector @  0x1B
    P0 = 0xFF-4;
    clr_TF1;
void UART0_ISR(void) interrupt 4         // Vector @  0x23
    P0 = 0xFF-5;
    clr_RI;
void Timer2_ISR(void) interrupt 5        // Vector @  0x2B
    P0 = 0xFF-6;
    clr_TF2;
void I2C_ISR(void) interrupt 6           // Vector @  0x33
    P0 = 0xFF-7;
    clr_SI;
void KBI_ISR(void) interrupt 7           // Vector @  0x3B
    P0 = 0xFF-8;
    clr_KBIF0;
void BOD_ISR(void) interrupt 8           // Vector @  0x43
    P0 = 0xFF-9;
    clr_BOF;
void SPI_ISR(void) interrupt 9           // Vector @  0x4B
    P0 = 0xFF-10;
    clr_SPIF;
void WDT_ISR(void) interrupt 10          // Vector @  0x53
    P0 = 0xFF-11;
    clr_WDTF;
void ADC_ISR(void) interrupt 11          // Vector @  0x5B
    P0 = 0xFF-12;
    clr_ADCI;
void Capture_ISR(void) interrupt 12      // Vector @  0x63
    P0 = 0xFF-13;
    clr_CAPF0;
void PWM_Brake_ISR(void) interrupt 14    // Vector @  0x73
    P0 = 0xFF-14;
    clr_BKF;
zhuotuzi|  楼主 | 2016-12-29 23:53 | 只看该作者
我们可以从例程看出来,该例程包含了所有的中断源的中断使用方法。
dongnanxibei| | 2016-12-30 00:00 | 只看该作者
没想到这个芯片支持这么多种中断方式。
gejigeji521| | 2016-12-30 00:07 | 只看该作者
竟然还可以用于捕获的操作,给力。
zhuotuzi|  楼主 | 2016-12-30 17:11 | 只看该作者
备注里给出了中断向量地址,可以明显的看清楚是多少个中断源可以触发
墙上的咖啡| | 2016-12-30 19:55 | 只看该作者
中断看上去和51没什么区别的
