[技术问答]
求助大侠M453的UART初始化
1715|6
Jack67|  楼主 | 2017-1-22 11:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助大侠帮忙看看初始化UART0串口有什么错误的地方,就收进不了终端。
/* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
        UART_EnableInt(UART0, (UART_INTSTS_RDAINT_Msk | UART_INTSTS_RLSINT_Msk));
        UART0->INTEN |= UART_INTEN_RDAIEN_Msk;
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
598330983| | 2017-1-22 16:56 | 只看该作者
建议楼主下载这个系列的库函数和例程,官方网站有。非常给力。
捉虫天师| | 2017-1-22 19:02 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 9 $
* $Date: 15/09/02 10:04a $
* @brief
*           Show how to use auto baud rate detection function.
*           This sample code needs to work with UART_AutoBaudRate_Slave.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#define PLLCTL_SETTING  CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK       72000000
#define RXBUFSIZE 1024
/* Define functions prototype        */
extern char GetChar(void);
int32_t main(void);
void AutoBaudRate_TestItem(void);
void AutoBaudRate_TxTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(UART1_MODULE);
    /* Select UART module clock source as HIRC and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HIRC, CLK_CLKDIV0_UART(1));
    CLK_SetModuleClock(UART1_MODULE, CLK_CLKSEL1_UARTSEL_HIRC, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD(PD.0) and TXD(PD.1) */
    /* Set PB multi-function pins for UART1 RXD(PB.2) and TXD(PB.3) */
    SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk);
    SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB2MFP_UART1_RXD | SYS_GPB_MFPL_PB3MFP_UART1_TXD);
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 module */
void UART1_Init()
    /* Init UART        */
    /* Reset UART1 module */
    SYS_ResetModule(UART1_RST);
    /* Configure UART1 and set UART1 Baudrate */
    UART_Open(UART1, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init UART1 for testing */
    UART1_Init();
    /* SAMPLE CODE        */
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("\nUART Sample Program\n");
    /* UART auto baud rate sample master function */
    AutoBaudRate_TxTest();
    while(1);
/*  Auto Baud Rate Function Test Menu        */
void AutoBaudRate_TestItem()
    printf("\n");
    printf("+-----------------------------------------------------------+\n");
    printf("|     Auto Baud Rate Function Test (Master)                 |\n");
    printf("| [1] baud rate 38400 bps                                   |\n");
    printf("| [2] baud rate 57600 bps                                   |\n");
    printf("| [3] baud rate 115200 bps                                  |\n");
    printf("|                                                           |\n");
    printf("| Select baud rate and master will send 0x1 to slave ...    |\n");
    printf("| Quit                                              - [ESC] |\n");
    printf("+-----------------------------------------------------------+\n\n");
/*  Auto Baud Rate Function Tx Test        */
void AutoBaudRate_TxTest()
    uint32_t u32Item;
    printf("\n");
    printf("|     Pin Configure                                         |\n");
    printf("|  ______                                            _____  |\n");
    printf("| |      |                                          |     | |\n");
    printf("| |Master|--UART1_TXD(PB.3)  <==>  UART1_RXD(PB.2)--|Slave| |\n");
    printf("| |______|                                          |_____| |\n");
    printf("|                                                           |\n");
    printf("\n");
    printf("|     Auto Baud Rate Function Test                          |\n");
    printf("|  Description :                                            |\n");
    printf("|    The sample code needs two boards. One is Master and    |\n");
    printf("|    the other is slave.  Master will send input pattern    |\n");
    printf("|    0x1 with different baud rate. It can check if Slave    |\n");
    printf("|    calculates correct baud rate.                          |\n");
    do
        AutoBaudRate_TestItem();
        u32Item = getchar();
        printf("%c\n", u32Item);
        /* Set different baud rate */
        switch(u32Item)
            case '1':
                UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 38400);
                break;
            case '2':
                UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 57600);
                break;
            default:
                UART1->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HIRC, 115200);
                break;
        /* Send input pattern 0x1 for auto baud rate detection bit length is 1-bit */
        UART_WRITE(UART1, 0x1);
    while(u32Item != 27);
玛尼玛尼哄| | 2017-1-22 19:23 | 只看该作者
下载官方例程的,用库函数写的,比较好明白。
天灵灵地灵灵| | 2017-1-23 16:32 | 只看该作者
春节了,楼主还在忙工作啊?
heisexingqisi| | 2017-1-25 15:52 | 只看该作者
找个开发板试试看,看看是哪儿的错误。
598330983| | 2017-1-25 21:35 | 只看该作者
