[DemoCode下载]
APROM 编程数据Flash
1090|13
643757107|  楼主 | 2017-1-26 10:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technology Corp.
//  E-mail: MicroC-8bit@nuvoton.com
//  Application: APROM program Data Flash Function
//  ISP_AP.bin need to program to APROM
//  Config0 bit0(DFEN) =0 (enable DFEN)
//  Config1(CHBDA)=0x30
//  Output : Test OK                  =>  P0 = 0
//           Erase Data Verify err    =>  P0 = ~0xA1
//           Program Data Verify err  =>  P0 = ~0xA2
//------------------------- <<< Use Configuration Wizard in Context Menu >>> --------------------------------
// <h> UART pin Select
//     <o0.6> UART pin
//          <0=> Select P1.0, P1.1 as UART pin(default)
//          <1=> Select P2.6, P2.7 as UART pin(28 pin only)
// </h>
//-------------------------------- <<< end of configuration section >>> -------------------------------------
#define Uart_Port_Sel   0x00
#include "N79E715.h"
#include "Typedef.h"
#include "Define.h"
#include "Common.h"
#include "Delay.h"
#include "Version.h"
#include <intrins.h>
#include <stdio.h>
#include <string.h>
#define   ERASE_ALL_DATA        0x22
#define   FLASH_READ_DATA       0x00
#define   BYTE_PROGRAM_DATA     0x21
#define   ERASE_ALL_CONFIG      0xE2
#define   FLASH_READ_CONFIG     0xC0
#define   BYTE_PROGRAM_CONFIG   0xE1
bit EA_Save_bit;
void Clear_BOF(void)
    EA_Save_bit = EA;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    PMCR &= CLR_BIT3;
    EA = EA_Save_bit;
void Enable_ISP_Mode(void)
    /* Enable ISP  */
    EA_Save_bit = EA;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    CHPCON |= 0x01;
    EA = EA_Save_bit;
void Disable_ISP_Mode(void)
    /* Disable ISP */
    EA_Save_bit = EA;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    CHPCON &= 0xFE;
    EA = EA_Save_bit;
void Trigger_ISP(void)
    EA_Save_bit = EA;
    EA = 0;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    ISPTRG |= 0x01;
    EA = EA_Save_bit;
void Erase_DATA(void)
    UINT16 u16Count;
    Enable_ISP_Mode();
    P0 = ~0x01;
    ISPCN = ERASE_ALL_DATA;
    for(u16Count=96;u16Count<128;u16Count++)
        ISPAL = LOBYTE(u16Count*128);               // 96*128=12288=0x3000
        ISPAH = HIBYTE(u16Count*128);               // 96*128=12288=0x3000
        Trigger_ISP();
    Disable_ISP_Mode();
void Erase_DATA_Verify(void)
    UINT16 u16Count;
    Enable_ISP_Mode();
    P0 = ~0x02;
    ISPAL = 0x00;
    ISPAH = 0x30;
    ISPCN = FLASH_READ_DATA;
    for(u16Count=12288;u16Count<16384;u16Count++)
        ISPFD = 0;
        Trigger_ISP();
        if(ISPFD != 0xFF)
            printf ("\nEV err.");
            P0 = ~0xA1;
            while(1);
        ISPAL++;
        if(ISPAL == 0)
            ISPAH++;
    Disable_ISP_Mode();
void Program_DATA(void)
    UINT16 u16Count;
    Enable_ISP_Mode();
    P0 = ~0x03;
    ISPAL = 0x00;
    ISPAH = 0x30;
    ISPFD = 0xFF;
    ISPCN = BYTE_PROGRAM_DATA;
        ISPFD++;
        Trigger_ISP();
        ISPAL++;
        if(ISPAL == 0)
            ISPAH++;
    Disable_ISP_Mode();
void Program_DATA_Verify(void)
    UINT16 u16Count;
    UINT8  u8Read_Data;
    Enable_ISP_Mode();
    P0 = ~0x04;
    ISPAL = 0x00;
    ISPAH = 0x30;
    u8Read_Data = 0x00;
        Trigger_ISP();
        if(ISPFD != u8Read_Data)
            printf ("\nPV err.");
            P0 = ~0xA2;
            while(1);
        ISPAL++;
        if(ISPAL == 0)
            ISPAH++;
            u8Read_Data++;
    Disable_ISP_Mode();
void main (void)
    Clear_BOF();
    AUXR1 |= Uart_Port_Sel;             // Select P10/P11 as UART pin(default)
    InitialUART0_Timer1(9600);          // 9600 Baud Rate [url=home.php?mod=space&uid=72445]@[/url] 11.0592MHz
    Show_Version_Number_To_PC();
    printf ("\n N79E84x ISP APROM Program Data Flash Sample Code.");
    Erase_DATA();
    Erase_DATA_Verify();
    Program_DATA();
    Program_DATA_Verify();
    printf ("\n N79E715 ISP APROM Program Data Flash OK!\n");
    P14 = 0;
    P21 = 0;
    while(1);
643757107|  楼主 | 2017-1-26 10:25 | 只看该作者
那些无参函数实际上就是固定的形式,直接拿来用就行了。
643757107|  楼主 | 2017-1-26 11:23 | 只看该作者
编程后,还要编程核验。
捉虫天师| | 2017-1-26 13:55 | 只看该作者
编写和擦除都要进行校验
zhuomuniao110| | 2017-1-26 17:59 | 只看该作者
这个功能可以用多余的空间存储一些数据。
734774645| | 2017-1-26 19:04 | 只看该作者
Flash memory for program memory(FLASH中的用户程序存储器)=APROM Flash memory for loader(FLASH中的程序管理区)=LDROM
dongnanxibei| | 2017-1-26 19:55 | 只看该作者
搞明白这几个操作顿时就高大上了,还可以节约成本。
heisexingqisi| | 2017-1-26 20:04 | 只看该作者
用这个功能可以利用没有被使用的空间啊
gejigeji521| | 2017-1-26 20:20 | 只看该作者
其实有多种编程的方法,不过归根结底是相同的。
huangcunxiake| | 2017-1-26 20:33 | 只看该作者
根据这个例程可以很好的理解这个操作的方法和原理。
wahahaheihei| | 2017-1-27 13:42 | 只看该作者
利用这个可以做Bootloader吧。
dongnanxibei| | 2017-1-27 15:18 | 只看该作者
对存储空间编程确实可以啊。
天灵灵地灵灵| | 2017-1-27 17:08 | 只看该作者
大过年的来看看有什么好玩的没
zhuotuzi| | 2017-1-28 09:48 | 只看该作者
通过这些在程序的编程可以做很多事情。
