[DemoCode下载]
mini51通过PWM控制直流风扇
728|5
643757107|  楼主 | 2017-6-23 20:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 3 $
* $Date: 13/10/07 3:54p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    PWM sample for Mini51 series MCU
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Mini51Series.h"
void SYS_Init(void)
/* Init System Clock        */
    /* Unlock protected registers */
    while(SYS->RegLockAddr != 1) {
        SYS->RegLockAddr = 0x59;
        SYS->RegLockAddr = 0x16;
        SYS->RegLockAddr = 0x88;
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK->PWRCON = CLK_PWRCON_IRC22M_EN_Msk;
    /* Waiting for clock ready */
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_IRC22M_STB_Msk));
    /* Enable IP clock */
    CLK->APBCLK = CLK_APBCLK_UART_EN_Msk | CLK_APBCLK_PWM23_EN_Msk;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
/* Init I/O Multi-function        */
    /* Set P1 multi-function pins for UART RXD, TXD */
    SYS->P0_MFP = SYS_MFP_P00_TXD | SYS_MFP_P01_RXD;
    /* Set P2 multi-function pins for PWM Channel */
    SYS->P2_MFP = SYS_MFP_P24_PWM2;
    /* Lock protected registers */
    SYS->RegLockAddr = 0;
void UART_Init(void)
    // Set UART to 8 bit character length, 1 stop bit, and no parity
    UART->LCR = UART_LCR_WLS_Msk;
    // 22.1184 MHz reference clock input, for 115200 bps
    // 22118400 / 115200 = 192. Using mode 2 to calculate baudrate, 192 - 2 = 190 = 0xBE
    UART->BAUD = UART_BAUD_DIV_X_EN_Msk | UART_BAUD_DIV_X_ONE_Msk | (0xBE);
int32_t main (void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART_Init();
    printf("\nThis sample code will output PWM channel 0 to output waveform\n");
    printf("using double buffer feature.\n");
        PWM channel 0 wave form of this sample showns below:
        |<-        CNR + 1  clk     ->|  CNR + 1 = 199 + 1 CLKs
                       |<-CMR+1 clk ->|  CMR + 1 = 99 + 1 CLKs
                                      |<-   CNR + 1  ->|  CNR + 1 = 99 + 1 CLKs
                                               |<CMR+1>|  CMR + 1 = 39 + 1 CLKs
         ______________                ________         _____
      __|      100     |_____100______|  60    |__40___|     PWM waveform
    // Set channel 0 perscaler to 2. Actual value fill into register needs to minus 1.
    PWM->PPR = 0x0100;
    // Set channel 0 clock divider to 1
    PWM->CSR = PWM_CLK_DIV_1 << PWM_CSR_CSR2_Pos;
    // Enable PWM channel 0 auto-reload mode
    PWM->PCR = PWM_PCR_CH2MOD_Msk;
      Configure PWM channel 1 init period and duty.
      Period is HCLK / (perscaler * clock divider * (CNR + 1))
      Duty ratio = (CMR + 1) / (CNR + 1)
      Period = 22.1184 MHz / (1 * 1 * (1B9 + 1)) =  25000 Hz
      Duty ratio = (99 + 1) / (199 + 1) = 50%
    PWM->CMR[2] = 0xB9;
    PWM->CNR[2] = 0x1B9;
    // Enable PWM channel 2 output
    PWM->POE = PWM_POE_PWM2_Msk;
    // Start
    PWM->PCR |= PWM_PCR_CH2EN_Msk;
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
643757107|  楼主 | 2017-6-23 20:16 | 只看该作者
PWM在控制上用的非常广泛的
稳稳の幸福| | 2017-6-23 20:22 | 只看该作者
其实难点就是怎么配置使用这个外设额
huangcunxiake| | 2017-6-24 13:22 | 只看该作者
准备总结一下,封装成两个函数。一个配置,一个使用。
wahahaheihei| | 2017-6-24 19:23 | 只看该作者
今晚认真学习PWM。
dongnanxibei| | 2017-6-24 21:59 | 只看该作者
感觉都是寄存器的操作,有点头疼。。
